Question about KitchenAid KT2651X Epicurean Stand Mixer
I need to replace the worm follower gear on kg25h3xsl.
The bevel gear is above and I can not remove the c clip. How do I remove the c clip? This is a 5Qt Kitchen aid 475 watt from Costco.
5 Suggested Answers
ricardok45
  • 135 Answers
SOURCE: I an looking for the intructions on my Kitchen Aid
Hi. Goto kitchenaid.com. Click on the Customer Care button, click on find manuals, in the search window, enter k45sswh. this page will show the operating manual and farther down the page the parts manual. Download both these files.
Go to mendingshed.com and locate their FREE kitchenaid service manual and download it. This manual will greatly assist you or a repair person should your mixer ever need repair.
A word of caution...Do not overload the mixer with too much bread or cookie dough or it will cause damage to the transmission. Use the recommended capacities found in the manual.
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Apr 07, 2009
freetek
  • 5568 Answers
SOURCE: I've the 325 watts its 110V kitchen aid and I
You will need a 'step-down' transformer with a rating of at least 500 watts (~500 VA), a primary designed for 220 Volts and a secondary rated at 110-115 Volts. This type will have four terminals or leads and isolates the input from the output.
There is a non-isolating type called an 'autotransformer' which has one winding with a tap (total of three terminals) roughly in the middle. I use this type for certain devices but it is not as safe as the first-described type.
If you are living in a foreign country that uses the ~220 Volt standard, you can sometimes get one on 'semipermanent' loan from the local utility.
Posted on Oct 07, 2009
hslincoln
  • 235 Answers
SOURCE: Kitchen aid mixer drops metal shavings in the
Hi REDLACQUER. Sorry to hear about the metal shavings. This is probably not to best way to take iron in your diet... My first thought would be to ask if your mixer is still under warranty. If you’ve had the machine less than one year, then I’d let KA replace your mixer with a new one. However, I suspect like many who seek assistance from FIXYA.com, your mixer is out of warranty, so what can you do?
Have you been able to find exactly where the metal shavings are originating? From the symptoms you describe, it appears that the planetary/agitator shaft assembly may be rubbing against its housing and generating the metal shavings at higher speeds. Have you noticed any increased noise levels/squeaking/screeching when the planetary rotates? It’s also possible that the planetary is out of alignment and not rotating true. Could the agitator shaft been jarred or hit hard during set up or moving in or out of you storage cabinet? Or the shavings could be symptomatic of other internal gear problems, but that would be the least likely scenario as the mixers internal gears are pretty much self-contained.
The good news is that this can be troubleshot and fixed quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, and feel adventurous. However, before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KP2671, and select the last file, KP2671XWH3.pdf (325.07 KB) listed under Parts List (24) (check to verify that it matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. I suspect your Planetary Assembly, Illus No. 15, is rubbing somewhere against its housing, Lower Gearcase, Illus. No. 24.
To gain access to these pieces you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. You need to remove the Transmission Housing (Illus No. 7) and remove all the lubricating grease from the transmission housing and gears (when removing the grease be on the lookout for shavings in the grease which would indicate excessive gear wear). This will allow you to remove Illus No. 25, 21, 18 & 19, Retaining Clip, Bevel Gear, Retaining Pin and Worm Gear Follower, respectively.
Once you remove the Retaining Pin (Illus. No. 18) the Planetary Assembly can be tapped down through the Lower Gearcase Assembly (Illus. No 24). With the Planetary removed, you can inspect it and the inside of the Lower Gearcase to determine where the shavings originated. Be sure to look closely at the Planetary Gear in the lower gearcase as well as the Agitator Shaft Pinion Gear (Illus. No. 12). That will also identify what parts need to be replaced, which you can order online.
You’ll need to replace the grease you removed with new grease. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as it may have ‘debris’ in it.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Jan 12, 2010
SOURCE: Hello. I just purchased
What I think you are describing is the snap ring (black) which you cannot move and the washer controlling the up thrust of the mixer. The black snap ring is usually a tight fit into the groove on the shaft and shouldn't move. The washer right above it is required to be there enabling the mixer to used with a spiral dough hook. The spiral dough hooks cause upwards pressure on the gear train that does not exist using a c-type dough hook. I think you mixer is fine............leave it alone, that's the way it was designed.
Posted on Jan 14, 2011
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Planetary dropped
when you replaced the planetary you forgot to put the retaining spring clip back on,
Jun 10, 2013 | KitchenAid KP26M1X Stand Mixer
Kitchenaid Artisan Stand Mixer has stuck hub bevel gear (KSM150PS)
The bevel gear sits above the worm-follower gear. I think you mean the drive attachment gear.
I think I have the same, or similar problem. I ground a piece of meat that stopped it from working. The drive-attachment-gear turns if I push it in, but then it pops out. I am still trying to figure out what part is causing the issue - the drive attachment gear, or maybe even the worm follower gear.
Feb 24, 2013 | KitchenAid KSM150PSGR - Artisan Series...
Kitchen aid professional stops spinning
the pro series 600 has a worm gear, a worm follower gear, a bevel gear, and tree bearings the front rear and thrust bearings any of the above will cause the mixer to halt, to operate noisily, or grind, you need to open it up and look under the transmission cover. If it is an older model it could also be the transmission cover if it is a plastic one, My first thoughts is it is the worm follower gear. hope this helps you in the right direction.
Feb 16, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Bevel gear and worm follower gear no longer stay together
they should be a tight fit as the clip is just to help retain position
if they are ment to be loose replace the clip and inspect the groove for the clip as the edges may be worn to a taper rather than a sharp edge which will allow it to be moved out under load
May 18, 2017 | KitchenAid KP2671 Professional 6 Series...
Hi, I have a Kitchenaid stand up mixer custom edition 500 watt model #Kd2661xmc that sounds fine when I don't have anything in it, but sounds like its crying when I put just a single cake mix in it. ...
Get A Copy of the Repair Parts List for your model at Kitchenaid.com.
Remove the Gearcase Motor Housing (1) & the Transmission Housing (7)
Remove the 2 screws (23) holding down the Motor (2) and lift off way from
the Worm Gear (17). Test run the motor by itself at different speeds.
If it runs fine then it's time to inspect all the gears in the Transmission
Housing(7). Remove all the brown Grease covering the gears.
Pay attention in particular to the teeth of the Worm Follower Gear (19).
(the Bevel Gear (21) sits on top of this gear)
They should not be worn out or chipped. If they are then this is the source
of the noises you're hearing (the Worm Gear is grinding away the teeth of
the Worm Follower Gear). Once the Follower is replaced, your mixer will
be just as new again.
Please Note that this replacement is not an easy task. You need the right
tools and don't use a hard object like a steel screwdriver to pry out the
Planetary plate (15) from the beater shaft. Before re-assembly, use only
fresh new Food Grade Grease from Kitchenaid (the old grease may contain
metal filings from the worn out gear that will damage your new one)
Jul 22, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid mixer leaking oil
Get a copy of the Repair Part List for your model at Kitchenaid.com
Grease inside the Planetary Assembly (the shaft is tight fit to the Planetary
plate at the factory and is not designed to be taken apart, so do not use
any hard object such as a screwdriver to separate them) over times can
turn to liquid and leak down the bowl. Removing the Planetary assembly
and adding Kitchenaid Food Grade Grease is not a task for a novice.
To properly remove the Planetary Assembly, you must work from inside
the Transmission Housing: Remove in this order: Retaining Clip(25), Bevel Gear(21),
Retaining Pin(18), Worm Follower Gear(19). Use a soft mallet to tap out the Shaft
of the Planetary Assembly(15). Re-assemble it in the reverse order.
Note: The Bevel Gear is extremely tightly fit on the shaft, and a pin punch
must be used to remove from the shaft.
Jul 14, 2011 | KitchenAid KP2671 Professional 6 Series...
I have a burning smell when i turn the mixer on and the gears dont change fast enough.
Get a copy of the Repair Part List for your model from Kitchenaid.com
Remove the motor housing, lift the main motor away from the transmission housing and
test run it at different speeds. If it is fully functional, then all your problems are inside
the transmission housing, most likely the Worm Gear Follower ( you may have to remove
all the gear grease to clearly see it). The Bevel Gear sits on top of the Gear Follower.
Inspect the teeth of the Worm Gear Follower (and also all other gears) for signs of damages.
Jul 11, 2011 | KitchenAid ProLine 600 Stand Mixer
Remove shaft/gear on KA 6qt Pro
Beth, First you should have the parts manual (Pt No. 8212278 Rev D) in your possession. You can download a PDF file from Kitchenaid, if you don't have it. Once you've have the manual, turn to page 4 - Case, Gearing and Planetary Unit.
I'm also assuming you're able to disassemble the mixer and access Illus. No. 4 - Transmission Housing. You want to remove the cover and place to the side. (Be careful of all the grease inside the cover and on the gears) Next wipe the gears and shaft clear of the grease. You want to get to Illus. No 10, so first you must remove Illus. No. 7 - Retaining Clip using a pair of external clip ring pliers. Next, lift Illus No. 8 - Bevel Gear off the shaft. Next, remove Illus. No 9 - Retaining Pin. That will finally allow you to lift Illus. No 10 - Worm Gear Follower of the shat.
I hope this helps.
Oct 20, 2009 | KitchenAid KP26M1X Stand Mixer
KitchenAid KT2651X Epicurean Stand Mixer Logo
115 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
