Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Magic focus will not line up the blue color right.....the blue color looks like its in 3d
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
If the magic focus does not correct it one or both of the two stk-392-150 convergence chips this set should use are bad.
Both will need to be replaced at the same time and then the set adjusted.
This can be a do it yourself job but requires being able to get at them, unsolder them (18 pins on each), considering parts cost would be under 30 dollars if purchased on EBAY it is a fairly easy repair.
Let me know if you have questions or need help.
SD TECH
Posted on May 14, 2010
  • Hitachi Master
  • 8,457 Answers
Ur tv have convergence problems,it dead.U must have soldering tools,solders,and know how to do soldering to able to fix convergence problems.Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Lookslike the picture is in 3d and when i try ti use magic focus
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 02, 2010 | Hitachi 57F500 57" Rear Projection...
The screen looks as if it is 3D. The colors are all offset.
  • Screen looks 3D
May 31, 2010 | Sony KP-57WS500 57" Rear Projection...
3D effect where the blue color is a little lower than the rest of the colors. More noticeable on words.
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 20, 2010 | Philips 51PW9363 51" Rear Projection...
My tv looks like it is in 3D without 3D glasses,
May 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color seperation
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Feb 25, 2010 | Hitachi 43FWX20B 43" Rear Projection...
My tv went multi colored take it as it looks like a 3d television
  • Screen looks 3D
Feb 20, 2010 | RCA HD61W66 61" Projection HDTV
Colors do not line up on my tv ( left side of sreen looks like 3D) digital array "+" are only white on right side.
  • Screen looks 3D
Jan 11, 2010 | Hitachi 50FX20B 50" Rear Projection...
Red, green, and blue lines at bottom of screen, mirror looking effect, also looks like 3D. Got at a garage sale so no manual.
  • Screen looks 3D
Jan 03, 2010 | Hitachi 43F300 43" Rear Projection...
The picture looks 3D
  • Screen looks 3D
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Have a 53" Hitachi HDTV that bows at the top and the bottom. I was told one of the transitors or transformes blew. I also do not have the regular magic focus just the static focus now. I tried to alli
  • Screen looks 3D
May 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
242 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
