Question about Toastmaster TBR20H Bread Maker
The drive shaft in the bread can is stuck solid. Is there a fix-it solution? do I have to buy a new can? if so, where can I find o parts shop? I live in Montreal Canada. Thanks and regards John
How do I get spare parts for a bifinett bread baking machine KH1170
Really by the time yo find a part and pay shipping and handling you may be better off to trash it and buy a new machine on sale.
Best wishes
Nov 05, 2014 | Breadman Bifinett Kompernass Bread Maker...
Stuck drive shaft on bmw motorcycle
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
GS FORUM 1200 GS FIXING DRIVESHAFT
1971 R75 5 rear swing arm removal Vintage BMW Motorcycle Owners
Free BMW Motorcycle Service Manuals for download
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Apr 11, 2014 | 2006 BMW K 1200 R
I have west bend bread maker (new) After 5 perfect loaves, the metal post that the paddle sits on is stuck. It is stuck tight. What happened and how do I get it to move. I turned the pan upside...
we have the same problem with our kenwwod bread machine we was told by kenwood.
you can either buy a new bread pan and bread kneeder or live with it, as in time and use
the new pan and kneeder would do the same agian. the new pan cost around £17.00,
and the bread kneeder around £6.05 from amazon if you do want new parts type in the serch bar at amazon bread maker parts....but if it's not broke don't fix it...........
Feb 22, 2011 | West Bend Kitchen Appliances - Others
The agitator turns very hard - like it is stuck partially siezed. Model 5838
Hi..The sealed bearing that the paddle shaft rotates on is starting to fail. Soon it will freeze up entirely and you will need a new bread pan. Fill the bread pan half way up with hot water a few times and see if you can free it up to "buy some time" Hank
Dec 05, 2010 | Oster 5838 ExpressBake Bread Maker
I have an Oster 5844 bread machine that has a worn out 'O' ring on the blade shaft on the pan. Do you know where I can get one? Brian
If you are having problems with your bread machine you may be able to fix it with replacement parts. That is if it is the paddles or the pan you are having problems with. If it is something within the bread machine that is not working properly then you probably won’t have a lot of luck finding these bread machine replacement parts.
Keep in mind the price of the bread machine replacement parts as well. If they are very expensive you will be better off just buying a new bread machine. But, if your bread machine was really expensive and is still in good shape and the replacement parts aren’t that much, then the replacement parts might be a better option for you.
Most bread machines work well for years without the need for replacement parts and many machines have warranties as well. But, if you are having problems then you will need to decide if replacement parts or a new machine are the right option for you. If you need replacement parts then call the manufacturer of your bread machine
(800) 438-0935
Nov 06, 2009 | Kitchen Appliances - Others
Fozen shaft on breadmaker loaf pan
After further research it seems that Welbilt is out of business (I tried several customer service numbers, all disconnected). Figuring I had nothing to lose if I needed to buy a new machine anyway, I heated the shaft with a propane torch for a minute or so, and used vice grips to loosen the shaft. It still seems a bit 'tight' to me but it turns now, and I'll heat it again and add oil while it's hot to see if that loosens it up a bit. I may have damaged the nylon bushing that keeps the pan watertight. I'll have to test that before I use the machine again.
Mar 30, 2009 | Welbilt ABM3500 Bread Maker
The paddle will not stay on the shaft while mixing dough.
Probably the paddle and shaft are worn. Both are replaceable. Buy a new Paddle and a Kneader mounting shaft unit (Part No. ADA 29A115)
Panasonic Parts
National Parts Center at 800-332-5368 between the hours of 9:00 a.m. and 8:00 p.m. EST Monday through Friday.
Nov 16, 2008 | Panasonic SD-YD250 Bread Maker
Need a new belt for the Regal K6725 bread maker
Hi, I have the same machine and the belt was in tiny rotten pieces...I wound a piece of yarn around the wheel and drive shaft (lie the machine on a kitchen counter, lid open and hanging down off of the counter, bottoms up, and remove the screws from the teardrop shaped brass colored safety cover, remove the cover and expose the wheel and drive shaft) pull the yarn tight and knot it. Then cut the yarn about an inch from the knot. Measure the yarn when pulled on a little. Mine measured 23.5"....I then googled bread machine belt 23.5" and up came one for an Oster Bread Machine (The one I was repairing was a Regal Kitchen Pro 6725) from totalvac.com located at 2 De Bush Ave Unit A8 Middleton, MA 01949
It was $7.95 for the belt, $6.95 S & H to a VA address, total cost $14.90 so I decided to give it a shot. When it got here, I removed the safety cover, held the machine up and shook as much of the old rotten rubber belt pieces out as I could, and replaced the belt by placing it over the sticky string on the drive shaft and teasing it over the wheel. It is an exact fit. Be sure the ribbed side of the belt is down against the wheel. Screw the cover back on and run it through a dough cycle so that the belt will get coated with the sticky stuff from the sticky string on the drive shaft. Until the belt is coated, it will turn the mixing blade, but it will slip. Hope this helps. Patti
Patti Wilson
September 2009
Nov 15, 2007 | Regal Ware K6725 Kitchen Pro Bread Maker
Toastmaster TBR20H Bread Maker Logo
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
troup
Level 1 Expert
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
