Question about Kodak EasyShare ZD8612 Digital Camera
CAMERA WILL NOT TURN ON. I HAVE KODAK RECHARGBLE BATTERIES. I THOUGH I NEEDED BATTERIES AND PUT THEM IN THE CAMERA DID NOT COME ON CHARGE BATTERIES IT CAME ON AGAIN FOR AWHILE AND THEN CUT OFF. WILL NOT COME BACK ON
I guess the memory card you have is not compatible with your camera, try removing your memory then turn on and see.
Posted on Oct 13, 2011
  • Moe Hussein Apr 27, 2014
    Also you may consider Li-Ion Rechargeable Battery KLIC 8000 this is what worked for me after trying many other kinds.
  • 198 Answers
You don't state how old the batteries are, but rechargeable batteries have a limit on how many times they will take a charge.
Posted on May 14, 2010
I cant charge the battery through computer
The C183 isn't a battery charger. If you use rechargeable AA batteries in it, you must charge the batteries outside the camera using a separate battery charger.
Aug 01, 2012 | Kodak C183 Digital Camera
I have a camera kodak af. But for some reason does not working. I tried to use different battery to use but it is not working.
In order to clearly determine the fault the model of your KODAK camera is needed
However hope this will help:
If your cam use AA batt.:
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or new cable.
Contact KODAK:
Nov 26, 2009 | Kodak 80-210mm f/4.5-5.6 Lens for Canon AF
Camera keeps going off even after I put in new batteries
1. Remove the batteries from the camera and then clean the battery contacts
2. Remove the memory card
3. Verify the batteries your using
Recomended batteries are
CRV3 lithium (non-rechargeable)
Ni-MH rechargeable digital camera batteries
2 AA lithium
4. Make sure to use a brand new batteries or fully charge batteries
5. inserted the battery correctly
6. Place the camera in Auto Mode [it's the green camera on the top of the camera beside the flash.]
7. Turn on the camera
**if issue was not resolved contact Kodak support line at 1 800 235 6325 (23KODAK) or visit the website www.kodak.com/go/stepbystep
Nov 16, 2009 | Kodak EasyShare Z650 Digital Camera
I have a Kodak Easyshare C180 digital camera. I open ity, take a picture and then it closes. I then cannot get it open again. I see the on/off button but nothing happens
Is the camera LENs won't retract? Try to use a brand new different recomended batteries like alkaline batteries or lithium batteries. If your using a rechargable batteries make sure that they are fully charge. You can also try to turn the camera ON without using memory card. Remove the memory card on the camera. Then put a new recomended battery, try to turn it ON if the camera will not turn ON or stay ON call kodak support line. Support in English and Spanish is available at 1-800-235-6325 (23KODAK)
Nov 15, 2009 | Kodak EasyShare C180 Digital Camera
The lens of my kodak easyshare is not working when i turned it on....
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Here are the steps:
Contact KODAK:
Here are the steps:
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Aug 30, 2009 | Kodak Cameras
The camera wont turn on
The camera will not come and I change the battery. The camera want come back on.
Nov 23, 2008 | Kodak EasyShare C613 Digital Camera
Can i use alkaline batteries
Hey there
Usually the manufacurer will say that because he wants you to use the rechargable which are stornger and lasts for more time, I persnally uses the rechargble they are better and save you a lot of money
Hoepe this helps
Jul 04, 2008 | Kodak EasyShare One Digital Camera
No power
Has it always been that way? You may want to use the same type of batteries; exp: alkaline, rechargble?, that came with the camera. If I'm not mistaken this camera has a battery type setting that has to match the type of batteries you are using.
May 21, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Battery charge
I called Kodak last night, they told me to turn the camera off, then remove the batteries and the memory card then wait ten seconds then reinstall both. Then turn the camera back on.... IT WORKED~ try it!!
Dec 01, 2007 | Kodak EasyShare CX7530 Digital Camera
Wont Turn ON!
I returned mine to Kodak (warranty) and they replaced it - was not fixable. :(
Sep 17, 2007 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare ZD8612 Digital Camera Logo
247 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
