Question about Singer Sewing Machines
Threading bobbin i cannot thread the bobbin
    Genius:
  • 1,116 Answers
These instructions are for modern Singer Sewing Machines - http://www.singerco.com/resources/bobbin_wind.html
If your model is different you can check at sewusa.com for threading and bobbin winding by model.
Posted on May 14, 2010
My bobbin thread breaks too much. How do I fix it.
Be sure you are using the correct bobbin for your machine. Even though it appears to fit the bobbin case, if it is the wrong bobbin, it could cause major headaches.
Try a different bobbin. Try different thread.
Also check that the bobbin thread is wound smoothly and turning the correct direction in the bobbin case. Make sure the thread is threaded through the bobbin tension properly.
AVOID old and inexpensive, bargain bin thread!
There could be a nick or burr somewhere that is catching the bobbin thread and breaking it.
Try loosening the bobbin tension a bit. It could be too tight, especially if the bobbin thread is pulling the upper thread down to the underside of the fabric.
There could also be something wrong with the bobbin case itself that may be resolved by trying a new bobbin case (or borrow one from a friend, etc.)
Dealing with Lower Thread Breaking Sewing
Bobbin Thread Breaking How to Loosen Bobbin Tension
Nov 10, 2016 | Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
I have a Baby Lock Audrey. The bobbin thread is "nesting". I have tried rewinding the bobbin and rethreading the needle and bobbin thread but that hasn't helped.
Check that it is actually the bobbin thread that is nesting. Generally, bobbin thread issues appear on the top of the fabric and upper thread issues appear on the underside of the fabric.
If it is in fact the bobbin thread, the bobbin thread tension may be off or malfunctioning.
If it is the upper thread nesting under the fabric:
1. Remove the thread
2. Install a brand new needle
3. ALWAYS RAISE the presser foot. This releases the thread tension so the thread will seat properly.
4. Rethread from the beginning and check the thread path is correct.
5. Set the upper tension at the midway point.
6. Check that the bobbin thread is loaded properly
7. Retest the machine.
If it continues to create thread nests under the fabric, tighten the upper tension.
Jun 22, 2016 | Baby Lock Sewing Machines
Buttonhole
The needle thread breaks
1. The needle thread is not threaded properly
2. The needle thread tension is too tight
3.the needle is bent or blunt
4. The needle is incorrectly inserted into the needle holder
5. The needle thread and the bobbin thread are not set under the presser foot when starting sewing
6. The threads were not drawn to the rear after sewing
7. The thread is either too heavy or too fine for the needle
Bobbin thread breaks
1. The bobbin thread is not threaded properly in the bobbin holder
2. Lint has collected in the bobbin holder
3. The bobbin is damaged and doesn't turn smoothly
Mar 13, 2015 | Sewing Machines
Thread a bobbin on a 5825c
If you mean the Singer 5285C, the manual is available from Singer here: http://www.singerco.com/uploads/download/449_5_6_8_10_slide.pdf . The diagram for winding the bobbin is on page 14 and inserting the bobbin is on page 15.
I'll attempt to walk through the steps. Push in on the indent on the hand wheel to lock the needle in the current position (note rotate the needle up first). Then with a spool on the spool pin and the cap securely holding the spool on the pin, snap the thread through the thread guide post (near the center back of the top of the machine). Then wind the thread clockwise through the bobbin tension guide (towards the center front of the top of the machine). Next run the thread through the hole in the bobbin (inside to outside). Place the bobbin on the bobbin spindle on the front of the machine near the right hand side of the machine. Hold onto the thread end at the bobbin and start pushing down of the foot controller. Fill the bobbin to the amount of thread that you need, or until it stops. Cut the thread going from the spool to the bobbin.. Remove the bobbin from the spindle and trim the thread end that is sticking through the hole in the bobbin. Press the hand wheel disc on the side opposite from the indent.
Inserting the bobbin requires you to lift the presser foot and have the needle in the highest position. Slide open the face plate and remove the empty or wrong color bobbin. With the hole in the bobbin up, pull about 4" of thread off the bobbin. Place the bobbin in the bobbin case and hold it down lightly with a finger. Guide the thread through the notch near the front of the bobbin case. Then lead the thread down into the slot on the left and then around the second notch. The thread should be heading towards the center of the bobbin (left to right). Pull the thread diagonally back to the back of the machine and slide the bobbin cover closed. The thread should be coming up through the opening between the cover and the needle faceplate. To pull up the bobbin thread, thread the needle and then hold onto this top thread. Rotate the hand-wheel towards you until the needle rises above the needle plate. Gently tug on the top thread to bring up the loop of thread. Separate the needle thread from the bobbin thread with your fingers. Bring the top thread through the left side opening in the presser foot and then pull both threads to the back of the machine.
I hope this helps.
May 24, 2013 | Sewing Machines
Thread breaking
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Aug 13, 2012 | Janome Sewing Machines
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
The upper thread is too loose and the bobbin thread is taken up too much
It is the upper thread which pulls the bobbin thread up. If the bobbin thread is taken up to much, one solution is to loosen the upper thread -- but the upper thread is too loose. Therefore, the same problem needs to be combated from the bobbin side.
The thread from the bobbin should slide through a wedge. On that wedge should be a screw. It needs tightened. The bobbin thread should be tight as follows:
A fully loaded bobbin should tangle by the thread without falling. While dangling the bobbin by the thread, bounce the bobbin (yo-yo style). An easy tug should cause the bobbin to release an inch or two of thread and then the bobbin should stop falling on its own.
Once the bobbin tensioner is correct, you should be able to tighten the upper tensioner.
Jun 02, 2011 | Singer 5050 Mechanical Sewing Machine
How to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Oct 31, 2009 | Singer 3116 Simple
Machine is threaded but thread not sewing into material, just holes!
Check bobbin thread....Insert the bobbin thread into the bobbin case in a clockwise direction...pull the thread through the **** on side of bobbin case and slide up into small opening...make sure you pull through about 2 inches of thread to enable upper thread to loop. Good Luck
May 10, 2009 | Sewing Machines
Sewing Machines Logo
125 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
