Question about Philips 60P8342 60" Rear Projection Television
Flyback? how do you fix the flyback?
  • Philips Master
  • 8,617 Answers
You will need to order a new one its pretty easy repair. We have them for most models in stock on the other site . is your model a 60P8342? If so this should be your flybackflyback? - 0fab5ff.jpg
Posted on Mar 29, 2008
  • Sonny Berry
    Sonny Berry Mar 30, 2008
    the 60P9209 should have this same flyback. But your flyback will have a tag on the righ side with a number stamped on it. That will be the part number
Rca f32645 tv year 1999 has a whistling sound
Leaky flyback causing whistling sound..Sometimes the flyback had poor solders make the flyback tightly fixed from the chassis. also resolder the HOT section.
Sep 27, 2014 | Televison & Video
I'm trying to fix my 21 inch JVC TV, its on standby mode i detected the problem it was Horizontal output transistor, when i replace it with new one it work but after 24 days it got shorted again so i...
depending on circuit design in some TVs when flyback becomes defective then (1) only flyback gets deffective or (2) flyback & 1 transistor big in size fixed near flyback gets deffective or (3) flyback,big transistor & resistor or diodes or some times ICs will get deffective ..........so flyback replacement is compulsory + which ever components gets deffective ....... usually flyback gets deffective after 4yrs (between 4yrs to 12 yrs depending on TV brand & usuage ) .............so in your case along with horizontal transistor replace flyback also ..................... Remove that flyback from main board ? using marker make a mark (1 dot on knob & at the same line put another dot on flyback --- these 2 dots should be in same line ) on all the knobs on fly back ....now turn all the knobs one by one in anticlockwise direction slowly until it stops .... Then observe from the mark which you made before turning .. --- you will get an idea which knob howmuch it was turned in anticlockwise direction.... now take flyback to electronic shop & buy same type ( equivalent will not work )......at the shop itself check part number , number of pins & their position of old flyback with that of new flyback ----- everything should match 100% - nothing less nothing more .... it should be exact .... check many shops...now turn all the knobs of new flyback in anticlockwise direction very very very slowly until it stops....now fix it to mainboard very slowly & carefully....don't forget to connect red wire from flyback to TV TUBE ...again iam repeating don't forget to connect red wire from flyback to TV TUBE .... Now observe mainboard carefully whether any connector is not connected ....now connect only tv powercord & stay at a distance & switch on Tv for 2 seconds & then switch of immediately....during this 2 seconds TV gets on & led also gets on continuosly (won't blink) & there should not be any smoke or sounds on main board ...this confirms you have replaced flyback without disturbing other components & not shorted any joints..... so now again switch on tv ..wait 3 or 4 seconds ...led will be on but there won't be any picture ... Don't worry ....in the beginning you have observed howmuch knobs on your old flyback were turned in anticlockwise direction....remember..? see your old flyback again.... Now using suitable screew driver turn all the knobs on new flyback in clockwise direction one by one very very very slowly ...untill as it was in old flyback ( approximately ) --- remember TV is in on condition ... means high voltage will be there ... bymistake if you touch any part of the tv .. you will get very severe shock.... So be very very very carefull ..now while doing this adjustment observe what is happening on the screen - how brightness is changing ... Now switch off tv....connect signal ( antenna or dvd or cable..) & again switch on TV ....so now depending on brightness & clarity of the picture ..looking at the tv screen again you have to turn 1 or all the knobs on flyback either in clockwise direction or in anticlockwise direction very very very slowly ..once you start doing this adjustment practically then automatically you will come to know which knob should be turned . in which direction - & howmuch it has to be turned .... But remember this adjustment is very important .. Sometimes it will take 30mins to finalise the exact position.of knobs .. so take your owntime & finalise the exact position of those knobs..then switch off tv ..fix back the tv cover .. then switch on tv again ....that's all .......100% GUARANTEE again your tv will work normally ....vishnuswamy_23.jpg
Aug 31, 2011 | JVC Televison & Video
R56WH78 RCA TV FlyBack
Resolder all the pinns on the FBT chances are FBT is Bad they go out alot Call UED for Parts 1-800-648-6657
Oct 19, 2009 | RCA R56WH76 Projection Television
Tv turns on then turns off
you need to replace the flyback its the 259296 flyback which is available at the following link and they send free instalation instructions with detailed photos on how to do the replacement of the flyback.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-flyback-259296/cName/flybacks
Feb 27, 2009 | RCA D52W19 52" Rear Projection Television
Focus leads for Flyback transformer
Just use cutters to cut off small rubber part leave wire sticking out put in FBT.
Jan 18, 2009 | RCA D61W20 61" Rear Projection Television
Flyback replaced
your flyback should still be good get the other parts changed out and go from there
Dec 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
LG TV beeping sound....
i want to lg tv rt-21fa35r model flyback number
Sep 03, 2008 | LG DU-27FB32C TV
Rca d52w19 fix fuse name
thats not a fuse issue, its a defective flyback. You can get a replacement flyback at the following link with free installation instructions so you can easially install it yourself. You need flyback number 259296 here is the link.
Aug 22, 2008 | RCA D52W19 52" Rear Projection Television
Need Flyback Part Number
You need flyback number 259296 you can get a replacement at the following link for under 50.00 with free shipping
May 20, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Flyback transformer BSC 70Y
You will find the flyback on this site.
May 02, 2008 | Apex Digital PF3230 32" TV
Philips 60P8342 60" Rear Projection Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
