Question about Dell Inspiron 1525 Notebook
Will not connect to wireless network Dell inspiron 1525 wii not connect to my wireless network says connecting status unknown the dependency service or group failed to start
    Sergeant:
  • 356 Answers
Hi there. Try these simple steps:
Click Start, then click Run if you're using XP and type services.msc then click OK. If you're running on vista, Type services.msc on Start Search field then click the icon on top that says Services.
Double click Wireless zero configuration on XP and WLAN on Vista. click dependencies and see the services where it is dependent on.
Inside the services window, click the name where your wireless is dependent upon and click start. Check for other dependencies and start reconnecting to your wireless network.
^_^
Posted on Jun 05, 2010
Cannot access internet or no network connection.
Dell Inspiron 1525: Unable to Connect Wireless Network
setting up the right option for wireless network connection at Dell 1525. Here's the following:
  1. Go to Control panel
  2. Select Windows Security Center
  3. Select Windows Firewall
  4. Click on Change settings
  5. Here you might see User Account Control will ask for your permission to continue, simply grant it.
  6. Click on the Exception tab at the middle
  7. Scroll down to Wireless Portable Devices and check the box next
  8. Click Apply, then hit OK
  9. After close the program now you can try to connect again and watch the result.
With assumption you're already make the wireless enable in BIOS setting. In the device manager you should see what the type of wireless wlan card you used and make sure it's already turned on via your switch on your laptop. If it was, then you need to find out the right wireless device driver for Dell Inspiron 1525. Here's the following:
  1. Visit Dell Support site and open the Network tab in the table.
  2. Find your wireless device and download the driver for it.
  3. Aim to a folder on your computer or any external drive if you have it.
At the Inspiron 1525 laptop
  1. go to start
  2. Right click at My Computer
  3. Click Properties
  4. Click Device Manager and Network Adapter .Here you should see a WLAN Mini-Card or might you only see "Unknown Device".
  5. Right Click on it and go to properties to select the Update Driver. Now you should browse the folder to select the driver you're already download at the first step.
NOTE:
Just follow the instruction appears completely. After installation the wireless wlan driver at Dell Inspiron 1525 finish, then reboot the machine and know your wireless connection should be works properly.
Jun 07, 2011 | Dell Inspiron 1525 Laptop
Issue here is i am able to connect through wired connection. Only wireless doesn't work. I have 2 laptops and have problem in connecting wireless only for my Dell Inspiron Laptop. The other Lenovo Laptop...
hi there...
1: goto Control Panel > Network and Sharing Center > check the Status it should be like this under Activity http://oi56.tinypic.com/ims8cz.jpg if it has a cross X on it ,then click on Diagnose it will tell you what is the issue.. 2: Download newer SP of your Operation System can also resolve the issue.
Dec 24, 2010 | Dell Inspiron 1525 Laptop
Got a dell inspiron 1525,no internet saying http 404 not found. what do i do?
This generally indicates a lack of connectivity with your network or internet service provider's network, whether it's wired or wireless. Check to make sure you have an established connection to your internet service provider.
Knowing what operating system and your connection status would help to assist you further.
Apr 14, 2010 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
My wireless will not work
Check your Settings in the Control Panel (Network Connections, as well as Hardware (to be sure the device is enabled!)
Also Check Power Settings in the Control Panel.
Go to Dell.com, Download the Drivers and Software (Everything Relative to Networking)
Reinstall them,
Apr 21, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Wireless Internet wont work unless I plug in a wire
QuickSet utility Wireless options can cause these issues.
There is a setting to always deactivate on battery. Make sure this is not set up. The correct setting would be Always active on battery or Always On, or no power saving options for Wi-Fi. Depending on the version of QuickSet which you have.
Apr 21, 2009 | Dell Inspiron 1525 Laptop
Dell 1525 , wireless adapter
Go to http://www.halfdone.com and download unknown devices to get the correct wireless card info.
Apr 17, 2009 | Dell Ethernet Card Network Adapter
Dell inspiron 1525 wireless problem
Go to http://support.dell.com and under the drivers and downloads section, enter your Service Tag, and download and install the latest Wireless Card driver for your model. Update to latest BIOS version as well.
Jan 10, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Inspiron 1525 Notebook Logo
637 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
