Water continues to drip into tub from inlet after machine is off & water faucet is off or on.
  • Washing Mach... Master
  • 43,501 Answers
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Asker's Testimonial " Thank you, I was also told that it may be the fill valve?? " - dsmith1695
Posted on May 14, 2010
Washing machine drips water from top of tub.
THE WATER INLET FILTER IS MISSING , SO IT ALLOWS SOME FRAGMENTOF DIRTS INTO THE SYSTEM......U HAVE 2 LOSSE WATER INLET VALVE AND CLEAN
Feb 24, 2012 | Fisher and Paykel Washing Machines
Water is continually leaking into the tub from the inlets as a slow drip. This happens while the washer is off and continues forever unless the water supply is turned off. This is a stackable washer/dryer.
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Jan 06, 2011 | Washing Machines
Water continues to drip into the tub even after all cycles have completed. my tub is filling up with water, I have turned off the water to the machine but it continues.
The water inlet valve needs to be replaced. It's not shutting off the water completely. It's located where the water hoses connect to the washer.
Oct 09, 2010 | Maytag Washing Machines
Water drips into the tub from the inlet
Good day,
If water constantly runs or drips into the tub,even if the machine is off, then the water valve in the back of the machine, has one of the seals failing, and the water valve needs to be replaced.
Dec 22, 2009 | Maytag Washing Machines
Water dripping into the tub when washer is not in use
You are right, it is called the water inlet valve assembly. I will attach a photo for reference. You can try to clean the small metal screens inside the opening on the valve, but the problem is most likely in the solenoids. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity means a bad solenoid and the water inlet valve will need replaced. Sorry for your trouble and I hope this helped. Best wishes.
Sep 28, 2009 | Fisher and Paykel GWL11 Top Load Washer
Water continues to drip and fill tub after wash cycle completes
Your water inlet valve where the water supply hooks up to the washer is not sealing good.It can get sediment in it and cause this. Having a well for water supply can cause this more than water that has time to settle.
Sep 02, 2009 | Maytag PAV2300 Top Load Washer
Water drips in tub after washing is completed! kenmore 80 series
Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. A bad solenoid will permit water to leak through to the tub. Hope this helped and best wishes.
Aug 30, 2009 | Washing Machines
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Water leaking into tub from inlet
you need to replace the water valve. Look on line for parts for your model
May 07, 2008 | Washing Machines
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
