Question about Gateway MT6705 Notebook
My gateway laptop will not turn on sometimes by jiggling the cord it would but nothing now i got a new ac adapter and it turned on for a second and off again , but by moving the cord it came on and off what else could be the problem, i know i need a new battery already , but the adapter won't stay on
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
    Problem Solver:
  • 11 Answers
You can get more laptop battery tips from http://www.okakku.de and http://battery-store.com.au
Posted on May 14, 2010
Will not power on
MPC has since dissolved, leaving thousands of customers without dedicated support when their Gateway laptop won't start.
Remove the AC adapter from the laptop and attempt to boot the laptop from battery alone. Attempt to turn on the laptop.
Replace the AC adapter and remove the battery from your laptop.
Ensure the adapter is plugged in. Attempt to turn on the laptop.
Disconnect the AC adapter and leave the battery removed from the laptop.
Hold down the power button for 30 seconds.
Nothing should happen on the screen.
Reconnect the AC adapter to the laptop.
Attempt to power on the laptop.
If the laptop boots, replace the battery once the operating system loads.
Try the process again with a new AC adapter and battery if possible.
Contact Gateway support if you aren't a former MPC customer.
Alternatively, take the laptop to a computer specialist if it still won't start.
Nov 19, 2013 | Gateway 17.3" NE71B06u Laptop PC with AMD...
My Gateway computer is plugged in but not charging. The ac adapter is brand new. Why?
Try this- Unplug the laptop, take out the battery, and hold the power button down for 30-45 seconds. After that, put your battery back in, plug in the AC adapter and turn it on. It's usually the solution in your type problem
Apr 18, 2011 | Gateway MX8711 Notebook
My gateway laptop note book, will not power up, I have checked the cord, battery etc. Went to turn it on one day and no power? someone mentioned that it over heated?
First of all, take the battery off and try to turn it on with the ac adapter (power cord) connected. If it comes up without the battery then it's your battery.
If it doesn't turn on without the battery and with just the ac adapter, try a different ac adapter. You can find one to try at your local pc shop or electronics store. If it comes up with another ac adapter then all you need to do is purchase an ac adapter at the store or order one online (cheaper).
If it still doesn't come on then it's either your dc jack or your motherboard. Normally if it's just the dc jack it will turn on or attempt to turn on when you wiggle the connecter in the ac adapter connection. If it's your dc jack it's relatively inexpensive to purchase online. The problem comes with having to take apart the laptop, desoldering the old and soldering the new dc jack, and putting the computer back together.
Good luck and let me know if you have any other questions.
Oct 23, 2010 | Computers & Internet
My gateway laptop will not hold a charge unless the power cord is jiggled and placed in ackward positions. i assumed it was the ac adapter, replaced it, and now im still having the same problem. does my...
it looks like the battery is already defective. try to remove the battery and use only the ac adapter. if your computer works fine using only the ac adapter, then the battery is already degraded and needs to be replaced.
Jun 11, 2010 | Gateway MT3705 Notebook
I have an hp dv2500 and it won't power on. Purchased a new power cord and battery still nothing. Reseeded the hard drive and ram nothing. Tried to power on without the battery and then restart nothing. The...
There's a lot of causes why this has happened in your laptop. Here are some possible causes and solutions to this problem:
Since you bought a new laptop battery, probably it is good and your AC power adapter also, because you said that the power cord light remains on. I think what you mean for the power cord is that it is the AC power adapter.
First, try to power up your laptop through the new laptop battery that you recently bought if you believe it is holding a charge and make sure you don't plug in the AC power adapter into your laptop. But before you turn on the laptop, make sure that the contacts between your laptop battery and your laptop motherboard is making a good connection. Because sometimes it will not, maybe something spilled in there or there's some dust covering the contacts or some sort of dirt and they're not making a clean connection. To be sure that this is not happening to the contacts or your laptop battery and the motherboard of your laptop, pull the battery out, take a toothbrush and just scrub in between the pins of the battery there and also scrub down the the pins where the motherboard connection is (which is the contacts between the battery and your laptop motherboard, where you install the battery). If you are done doing this, put the battery in and turn the laptop on.
If the steps above doesn't solve your problem, try this one:
* Pull the battery out
* Remove main supply
* Hold power button down for 30 seconds. This will drain the charges in your battery.
* Put only power supply in
* Do not put battery in
* Turn laptop on
* Put the battery in
If you're done doing the steps above and did not solve your problem you can try the steps below:
You have to test if there's a fix voltage on your AC power adapter by using a voltmeter, usually 18 to 19V DC depending on the registered voltage written on your AC power adapter. If there is, kinda bend or jiggle the power cord a little bit to make sure the connections is tight. If the voltage remains steady, then probably your AC power adapter is good. Now we have come to the point that we need to deal with your laptop motherboard. There's a lot of reasons why your laptop won't power on even if you have a good laptop battery and AC power adapter. Maybe your laptop motherboard is partially bad, like for example if the dc jack on your laptop is bad and is not making a connection to the motherboard then it might look like the battery is bad as well because the battery is now now holding a charge or even taking a charge. Now this has happened a lot to plenty of laptop owners where their dc jack goes bad. They think their batteries gone bad because is not taking a charge anymore, they got and buy a new battery and then decide to bring their laptop to a laptop repair company because of the battery's not charging even with the new battery, that's because the dc jack is bad. You're going to probably right into this a lot where the battery's not charging because the dc jack is bad and until you fixed that, the battery's never going to charged. So how do you test if your dc jack is bad? It's simple, plug in the AC power adapter, take the battery out of the computer. If the computer doesn't power on then you know you have a problem with the dc jack. The only way to solve this, is that you have to disassemble your laptop, start taking components out one by one and finally, take the laptop motherboard out. Afte you've taken the motherboard out, look where the dc jack is connected. After you will find it, take a file tool and file off a spot on the motherboard where you can reattach the power jack and use a wire to reattach the power jack to the motherboard.
Hope you will find this answer helpful. God bless
http://compunics.blogspot.com/2010/06/podnutz-high-definition-laptop-repair.html
May 14, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Gateway Laptop M350WVN- not booting at all
it may need to be left on charge for a while...
when u first boot by pressing power wait for a minute or so and press and hold power button til shut down then try reboot..also try boot from disk....need to distinguish whether motherboard or software issue.
Feb 05, 2009 | Gateway Computers & Internet
Cx2620 gateway wont turn on
Possibly Need a New DC Jack In Your Laptop... the DC JAck Is The Port Where Your AC Adapter Plugs Into...
Though You SHould as well Check For Proper Power To Your CHarger Cord.. Not all AC Cords That Have Their Lights On Are Able To Charge...
To CHeck If It's The DC Jack... Remove Your Battery..... Plug In the AC Adapter Cord... Power On... If You Get No Lights/ No Power/ No Fans Etc..... It's Your DC Jack
Nov 20, 2008 | Gateway Convertible CX2620 Notebook
Gateway 400SD4 Power Problem
Faulty Battery.
Get a new one.
If that is not the problem check the ram.
Jul 01, 2008 | Gateway 400SD4 Notebook
Gateway MT6705 Notebook Logo
100 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
