Question about Oster 5838 ExpressBake Bread Maker
Where can I get a replacement bread basket for the 5838? Ours has the teflon coating coming off around the kneading shaft and upper edges and the metal underneath is starting to rust.
Noggin
  • 944 Answers
SOURCE: bread machine pan and kneading blade
here's the manual if you need it http://www.bread-maker.net/Bread-maker-reviews/Product%20Manuals/Betty-Crocker-BCF1690.pdf freefone for spares from manufacturer: 1-866-819-4335 hope this helps :)
Posted on Mar 08, 2007
SOURCE: Bread Machine not kneading
http://www.breadmakerguru.com/search.aspx?s=tr900
This site has bands/belts for breadmakers. I am buying my new paddle for the tr900s breadman pro from there. Perhaps your belt is broken? I personally have never replaced one, but it should not be too hard. Make sure you unplug the breadmaker before opening it up at all.
Try running the breadmaker with no pan in it and see if the paddle shaft turns at all during the cycle. Also, the paddle will not turn at all in the first 30 minutes of certain cycles, like the whole wheat. This is stated on the time chart of the instruction manual for this model.
Hope this helps!
WestHof
Posted on Aug 19, 2009
  • 433 Answers
SOURCE: sqeaking when kneading oster 2 loaf bread machine - how to oil?
Take out the bread pan and go to a kneading cycle. See if it is squeaking. If yes, then it could be the belt squeaking on the pulley or the motor itself. If it does not squeak when the pan is out, then it's the bread pan paddle and sealed bearing. That sealed bearing is lubed and sealed. It can't be oiled. Hank
Posted on Jan 18, 2010
Testimonial: "Thanks, Hank - we will just live with the noise until it dies, then buy a new one."
SOURCE: The kneading blade is stuck in my Welbilt Bread
Put a kettle of hot water on the stove.
After it starts boiling pour about 3 inches of hot water in the bread pan.
Wait about 5 minutes. Dump water out and remove blade.
If this fail. Repeat until the blade come out.
good luck.
Posted on Jan 21, 2010
Breadman pro
If you know the model number of your Breaman Bread Maker you may be able to order a replacement kneading blade online from the following site:
http://www.directpartsandproducts.com/breadman-bread-makers-c-61_129_837_838.html
Click on your model to open a list of available replacement parts.A kneading blade will be about $6.49 plus shipping.
Trust this is helpful. Thank you for using FixYa!
May 17, 2012 | Oster 5838 ExpressBake Bread Maker
Bread pan comes loose from it's mechanism during kneading process
reach in with your fingers and bend the two little clips out a little until they grip your pan snugly. Start with 1/4 " and try that. If it doesn't feel snug go another 1/4 inch.... and so on.... until nice and snug...
Nov 27, 2011 | Oster 5838 ExpressBake Bread Maker
Can't remove paddle
Hi Nancy, If it were one of the metal ones coated with Teflon I would advise something different. Since it is plastic you will need to soak it again overnight with some soapy water. Tomorrow get a toothpick and begin to pick at the bread gunk in the little gap between the post and the flat edge of the post where the bread gunk collects. Once you clear enough of that out a little wiggling side to side and especially up and down should free your paddle. Fortunately B&D's usually have enough of a gap where you can do what I describe. Some paddles fit so snugly there is no gap to work with. Whatever you do don't use anything metal to try and free your paddle, you could damage the teflon coating on your pan and you never want to do that. Let me know how it goes.....
Nov 26, 2011 | Black & Decker Bread Machine
Bread keeps sticking to paddle. Tears a big chunk of bread out of bottom. Happens all the time. Any solutions, Thanks
You might need a new paddle if cleaning yours doesn't work. It needs its release coating. You could also try making sure the paddle moves smoothly on its shaft. If it hangs up when you pull the loaf out, it'll tear a big hole in the bottom of the loaf. Replacement paddles for most makes can be found on eBay. They run around $15, though, so I'd try cleaning and lubrication with vegetable oil first. Good luck.
Mar 04, 2011 | Oster 5838 ExpressBake Bread Maker
How do I remove the stirring paddle to replace it with a new one? I've tried pulling it out with a large pair of pliers
I'm sorry you used pliers. If it has the non-stick coating you may have damaged it.
I have posted a video on you tube of how to remove a severely stuck bread machine paddle.
Just go to you tube and type in ...How to remove a stuck bread machine paddle or kneading blade"
and you will see how to do it without damaging your paddle or pan.
Nov 20, 2010 | Oster 5838 ExpressBake Bread Maker
I need a kneading blade for a model ABM6200 Welbilt bread Machine. Where can I purchase this item? I cannot even find any info on this model...? Any assistance would be appreciated! Thank you in...
I have a kneading blade for the ABM6200 welbilt bread machine. I sent it out to have it teflon coated and it is really great. Unfortunately my bread maker broke and I never installed the blade. I have the blade and the manual if you are still interested.
Oct 04, 2010 | Welbilt Microwave Ovens
Paddle sticking in bread when baked bread is removed. Oster Breadmaker 5838
This is a common problem. The solution is to take the paddle out of the machine after the last kneading cycle and before final rise/bake. You may want to take the pan out of the machine to remove the paddle to be safe...unless your machine has a pause cycle. Hank
May 18, 2010 | Oster 5838 ExpressBake Bread Maker
The driver that operates the kneading blade ( paddle) is falling out of the baking pan from the bottom. It appears a washer has disintegrated. Pieces seemed to fall apart when cleaning. any suggestions? I...
There is a sealed bearing at the bottom of the pan. This allows the paddle to rotate. The bearing has failed and is falling apart. This usually happens with age or use. Time for a new bread pan. If you are lucky you can find one on ebay. Sorry for the bad news....Hank
Dec 09, 2009 | Oster 5838 ExpressBake Bread Maker
Oster 5838 and a good banana nut bread recipe
CookingCindy 1 Solution July 23, 2009 I have made the following recipe in my West Bend machine with great results. I just got a Sunbeam 5895 at a garage sale - it works great - just wanted a different "shape" loaf! I'm going to use this recipe in my Sunbeam - don't see why it won't work! Here's the recipe! 1/2 cup softened butter, cut into small pieces for good blending 1 cup mashed ripe banana (personal note: if my ripe bananas don't measure up to 1 cup, I add enough milk to make it 1 cup. Seems to be okay) 2 eggs, large, slightly beaten 1/2 cup chopped nuts (optional) 2 cups all purpose flour 3/4 cup sugar 1 teaspoon baking powder 1/2 teaspoon baking soda 1/2 teaspoon salt Grease inside of pan and knead bar generously with vegetable shortening (I just spray with Pan Spray). All all ingredients in order listed above to pan. Lock pan into bread machine. Program for quick bread. After a few minutes of mixing, I usually take a rubber spatula and scrape down the sides and stir in any flour that has not been completely mixed. I didn't do this once and ended up with a loaf that had flour coated corners! Good Luck! Enjoy! Just follow the above recipe but if your using the Oster 5838 expressbake put the setting at expressbake 80min. It works flawlessly, also with the oster 5838 expressbake you don't need to use the rubber spatula to mix after a minute because it blends everything together nicely. Thanks bobert.
Jul 13, 2009 | Oster 5838 ExpressBake Bread Maker
Oster 5838 ExpressBake Bread Maker Logo
21 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
