Question about Labtec Axis-712 Headset
No sound, nor able to talk on mic.
It says its installed and is good but its not doing anything
  • 3 Answers
Maybe you have a lose or bad analog connection to the headphones, however my husband got a refurbished wireless game controller that I found to have a lose and dirty plug and the headset was fine after I took the controller apart, gently reconnected to post and cleaned it out with alcohol and q-tips just like you would use for a computer mouse. Peace, Love and Hair Grease from the ToyzRUsKddom
Posted on May 13, 2010
2 Suggested Answers
SOURCE: mic doesnt work
Totally the same with me.. any soloutions anyone?
Posted on Jul 10, 2008
Beaches wont turn mic
I for 1 don't know. But try to go to www.Turtle Beach.com they can help you out. I have Turtle Beach Ear Force XC1 and my mic I can talk but I can't hear anything but if your mic isn't working properly try using a different controller. If that doesn't help try getting a brand new mic.
Jun 23, 2013 | Turtle Beach Ear Force X42 Headset
I have a galaxy dx55v radio in my truck. When i pick up the mic to talk someitmes it works and sometimes it doens't. Have tried different mics with no help. Have taken it to a tech and they changed a...
Hi cb,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
You will need a soldering iron for this. First, remove the cover from the radio.
You will need to check where the mic plugs in the circuit board, check for
loose connection in solder joints, just re-solder this area and you should
be good to go. I hope you find this solution helpful.
Thanks for choosing FixYa.
John
Jan 18, 2011 | Galaxy Radios DX-55V Base CB Radio
Radio transmits fine but the receive volume is way down. Can hardly hear it with volume turned up full.
If you have talk back in this radio.( you hear your self through the radio when you transmit) then its a good bet that the RX wire in the mic plug has broken off.
The mic switch is responsible for putting the radio into receive mode when you release the key. If the RX wire is broken, the radio will not go into receive.
Normally when this happens you have no receive at all no matter what, but you will have very low sound if you have talk back installed in the radio.
Because of this, if you have talk back in your radio, and the volume is faint even at full blast, its a good bet that its a broken RX wire in the mic cord or plug.
You can attempt to see if the break is at the mic plug. if it is, you can re solder it and it will solve your problem. If you have no clue, then you can just go buy new 4 pin mic.
Nov 14, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
My integrated mic is not working how do i check it
Hai,
Right click on my computer, click properties, press hardware tab, then click device manager. Anything with a ? in yellow means the driver is not installed. Is it a mic thats mounted into the laptop? Or did you connect it? If you connected it, try changing mics and see if that works.
Aug 25, 2009 | Computers & Internet
MIC PLAYBACK IS NOT COMING OUT TO THE SPEAKERS
Dear sir/madam,
Go to the sound properties in tray icon, check the Mic is not muted and there is Line in button, u scroll up to high for sound in mic. check all the check box are not MUTED. ok.
thanks
good luck
Don't forget to rate the solution
Jul 23, 2008 | Microsoft Windows Vista Home Premium with...
Sound
Hello Jassimin:
First you have to isolate the problem, you need to check if it's a problem with your hardware of your computer or if it's a problem withn your software.
First try using Microsoft Sound Recorder (usually it's located at Start -> Accessories -> Multimedia -> sound recorder.
Try recording anything using that, If you can do it; then probably it will a problem with your software MSN, try re-isntalling it.
If you cannot record anything, of if you get a message that there's no recording device; then it's something related with the microphone or the driver for the mic....In case you need the driver, please let us know the model number of your laptop (usually it's a the bottom ....
good luck
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Cant talk through mic
Sounds like a bad or miswired mic. Try a new mic ( use the proper cobra mic ). If the problem still continues, check all the swiches on the front of the radio and make sure you don't have any cold solder joints ( broken lead to board connections ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
I cant talk
-> make sure mic is connected correctly in the correct slot to the CPU
->go to control panel-> sound and audio and there is seperate tab for "microphone"-> have th volume to be full
-> you can test whether the mic works there itself.
Nov 10, 2007 | Labtec C-322 Headset
Mic doesnt work
Dec 26, 2006 | Sennheiser PC130 Consumer Headset
Labtec Axis-712 Headset Logo
69 people viewed this question
Top Labtec Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
aravind shet
aravind shet
Are you a Labtec Radio Communication Expert? Answer questions, earn points and help others
