Question about Acer Aspire 5610 Notebook
My acer will not start
I have tried to go on safe mode but it sits there after load drivers it said to please wait but it's been a while and stiil not open
    Sergeant:
  • 313 Answers
Do you have your windows restore disks? Easiest way out of what little information given is to do a windows REPAIR, not an reinstall, but repair with the orginal instal disks. All your programs and documents will be kept intact.
If you need instructions on this, write back.
Posted on Mar 29, 2008
I can not boot up my acer 5735 even in safe mode
Sometimes if you insert a flash drive or your repair disc that you made when you got the computer helps.
Dec 10, 2012 | Acer Aspire 5735 Notebook
My PC acer 5542G, win 7, laptop, after an upgrade programm on the ACER site for the driver sound (realtek), the screen become all black. But some fonction as light on the board and the cd-dvd driver are...
AFTER YOU ON THE SYSTEM BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE. IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 15, 2011 | Computers & Internet
I was updating my avg when my granddaughter touched a button on the computer. She knew she did but does not know which one. Anyhow, the screen went blank. The mouse appears and I can move around but it...
There are a couple ways to fix this , 1. When you turn on the computer as it's booting up start pressing the "F8" button on your keyboard , your pc should load up to a black screen with several options in white text to choose from , try "boot using last known good configuration" , if that is unsuccesfull repeat the previous steps & this time choose "boot safe mode". If you can at least get it to boot into Safe Mode you can undo / repair the changes that occured .
2. If you can't even boot Safe Mode , you can try booting your pc using the operating system installation disc / recovery disc that came with your pc . Once loaded you can select to repair your current installation . Then sit back & wait till it's done , it will reboot & you should be presented with your login screen .
Apr 17, 2011 | Acer Computers & Internet
My Acer Aspire M1201 Desktop will not boot. I turn the power on but all I get is the Acer logo followed by "No Signal" and the monitor goes blank. I keep hoping I will finally hear the beep noise...
If you are seeing the Acer logo on boot up then the machine is working. The problem will be your graphics drivers being corrupt.
Try starting the machine in Safe Mode. To do this repeatedly tap the F8 key as it's just starting up. It should take you to an advanced menu with Safe Mode at the top, select that with the cursor keys.
If it allows you to boot in safe mode then wait until Windows loads and then right click on My Computer/Computer, select manage from the sub menu and then Device Manager.
Click on Display Adapters and uninstall the drivers. When its done unistalling the drivers restart the machine in normal mode. It should boot into Windows. If it lets you boot into Windows I suggest that you download and install the latest drivers from Acer's support website.
If you need anymore help please post back.
Good luck and regards.
Jan 19, 2011 | Acer Aspire L100 PC Desktop
Booting problem
You may have to boot from a CD and make a repair.
Once logged in the CD, choose repair option (Recovery Console), and type these three commands:
1) fixmbr (wait til it finishes)
2) fixboot (wait...)
3) CHKDSK (this will take longer than the previous two.
Your laptop may now boot normally. I think your laptop doesn't have an internal CD-ROM so you may use an external USB CD.
Apr 22, 2009 | Computers & Internet
Lcd screen broke external monitor wont work
Sounds like you resolution is too high or vista doesn't recognise your driver.
Try starting in Safe Mode by powering up your PC and tapping the F8 key until you see a menu. Select Safe Mode from the menu. Once in safe mode change the resolution to 800x600 then restart in normal mode.
If that doesn't work then download and install the correct drivers for your display card here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Once downloaded, you may need to install it in safe made once again.
Thanks
C
Mar 28, 2009 | Acer Aspire 3680 Laptop
I have and acer aspire 5315-2153 laptop one day i turned it on -
try going into safe mode by pushing f8 when you start up
Dec 06, 2008 | Acer Aspire 5315 Notebook
Acer 5610z will not start
I had the same problem with my neices Acer 5100...Went into safe mode, it loaded the drivers and sat that for what seemed forever...almost like it was hung up....I had a few things to do...and a couple hours later, it finally booted into safe mode.
I was able to save her files, but ultimatly ended up wiping everything out because of the corrupt files.
On another Acer, the same hang up "unable to boot into safe mode" even after a long period of time, and that Acer was a total loss..had to format...
I presume nothing was saved to a CD? i.e. her gsce files?
Doing a factory restore/reset will loose everything.
Try to boot into safe mode and allow it to boot up...see if it eventually comes up...I will keep reading for a solution other than the two here...and will post as soon as I find one...
Unfortunately, Acer do not have a good fix for most of their computer problems....
~~Jasta~~
Mar 29, 2008 | Acer Aspire 5610 Notebook
It wont start up
Could be this is a driver error on boot up, when it starts to boot up keep pressing F8, this will bring up the safe mode menu, look for the line and highlight 'Last Known Good Configuration' and press Enter. If this works all is well, but if not press F8 again o boot up but this time highlight the line 'Start Windows in Safe Mode'. If the laptop then boots up in safe mode without shutting down, run your anti virus and spyware programmes. If non found and the laptop still has'nt crashed, then it's a driver problem (as not all the drivers load up in safe mode) and you will need to try a system restore to before the problem started.
Oct 30, 2006 | Acer TravelMate 4150LCi Notebook
Acer Aspire 5610 Notebook Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
