Question about Emerson InSinkErator STC-BLK Sink Top Switch Trim Only - Black
Does not chop very good and the food does not flush away The chamber and knives turn but the food does not go away. The drain pipes are clean. not sure about the problem. Please help. Pete.
  • 821 Answers
Hello,Turn the power off and check inside the disposer. Make sure that the two metal impellers on the shredder plate can rotate through 360°. If they are stuck, try tapping the impellers with a wooden tool or utensil to allow them to swivel freely.then you put it on and you insinkerator will work as normal.
wish you good luck,
take care.
Posted on May 13, 2010
When runing petrol is comeing out of the top of number 2 carb then on low revs it spluters and dies
The carb is flooding because of a stuck needle valve in the float chamber. When the bike is running at higher revs, it is probably drawing enough fuel into the engine to run OK, but at low revs, the overflowing petrol will be getting into the engine in far too higher volume and flooding the cylinder, drowning the spark plug.
You will need to remove the float chamber from the carb, take out the pivot pin that the float hinges on in order to release the needle valve and clean it out. 99% of the time simply dropping the needle valve out, giving it a wipe with a lint free cloth and flushing a little clean petol through the inlet pipe to dislodge any obstruction will fix the problem. While the float chamber is off, check that there is no dirt in the bottom and that the entire chamber is clean and free of any muck.
There will probably be a drain valve on the side of the carb (Usually a brass screw set into the base of the carb float chamber at a slight angle). Before you go to the trouble of removing the carb from the bike, try this:
Turn off the fuel supply.
Put a cup under the carb to catch fuel.
Remove the drain plug and allow the fuel in the float chamber to run out.
Now the float is sitting at its lowest possible position inside the float chamber, turn the fuel supply back on and as petrol runs out of the drain hole, tap the carb sharply and repeadedly with the end of a screwdriver as you let about a pint of petrol flush through.
Turn off the fuel supply and replace the drain plug.
The flushing and tapping MAY dislodge the obstruction that is holding the needle valve open and fix the problem without having to remove the carb
Sep 15, 2011 | 2002 kawasaki ZX-6R
My dishwasher is no longer cleaning properly. A
Clean out the area where food gets caught and consider using different dishwashing tablets - especially the Calgon ones which clean out the drains of teh machine whilst cleaning the dishes.
Alternitivly you should call in a plumber to clean the pipes (Or purchase the equiptment to do it yourself, there are often all-in-one cleaners that'll flush out the pipes)
Dec 24, 2009 | KitchenAid Dishwashers
Backed up disposed of pasta. can not get all water etc.. to flush out
the trap in drain is likely plugged with pasta you can take pipes apart and clean out then reassemble. should do trick. first try putting ice cubes in disposle and chopping up this sharpens blades and may free up lodged pasta.
Oct 01, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do i drain my pool with a hayward variflow pump?
To Flush out the filter with the backwash setting. The backwash setting releases trapped particles from the filter back into the swimming pool. You may need to alternate between the rinse and backwash settings until the water runs clear in order to unblock your filtration system and flush out clogs. To Rinse away dislodged items from the backwash setting. The rinse setting flushes clean water through the pipes and carries away any particles or clogs freed during the backwashing. To Drain the pool select waste on the multiport valve. This sends the water directly to the drain rather than back into the swimming pool. Close the filtration equipment and stop the pump with the closed setting. You should only use the closed setting when you turn the pump off. This function allows you to remove the strainer basket, clean the filter tank and perform other swimming pool maintenance on the filtration system.
Aug 08, 2009 | Hayward 1.5 Hp Northstar High Performance...
Fridge drain is overflowing into base of fridge, causing build-up of ice over base, which then 'sticks' the salad boxes to the base of the fridge, making them difficult to draw out. I have to scrape the...
Some insect would have gone into the drain pipe and blocked the outlet for the water to flow and it gets collected inside.
First please clean the drain pipe and remove any block.
Defrost your refrigerator at least once in three days.
Excess ice formed in the freezer chamber will result in less cooling and melting of ice and make it run down.
The above remedies should solve your problem
Jul 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dishwasher won't drain
I rethought your problem and will provide a generic answer that is common to your brand of DW....
GE dishwashers will have a sump entrance screen ( #4 ) that should be removed and checked for any gookus, see 1 or 2 screws on the cover top, which is behind the lower spray arm. Almost all ( some newer GE dishwashers have a separate drain pump and motor - but for our purpose, we will talk about the most common GE dishwashers ) GE dishwashers have a drain solenoid ( #1 ) that can fail and stop the draining. If the solenoid cannot pull in the silver plunger, the drain port will not open to allow the motor and pump assembly to drain the water out. The solenoid can be ohmed with an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GE dishwashers have a self clean filter ( #3 ) inside at the back. The draining water must pass through a plunger in the self clean filter body. This can get clogged up, or the plunger may twist and distort and not allow the draining water to get past. The filter can be removed from the inside and the plunger will twist out of the self cleaning body for testing/checking. Next obstacle for the draining water in the back flush valve ( #2 ). This valve can twist or distort and block the water flow as well. The drain port will need to be accessed to check this flapper valve, the drain port will untwist from the self clean filter body. All hoses in-between the items mentioned above and the drain hose itself all the way to the house plumbing should be checked for restrictions.
Some extra filter, draining tips and pictures....
During the wash and rinse modes of the cycle, soiled water falls down the back of the tub and into the filter area. The water comes through the filter and back into the tub. During the wash and rinse periods all ( we hope! ) the water will pass through the filter. The soil will settle into the collection chamber and is held there. When the dishwasher goes into the pump out mode the water in the sump is pumped through the collection chamber. This closes the piston valve to the inside of the tub. The pump flushes the collection chamber of all the food soil and pumps it down the drain. A check valve is located in the drain line port. This valve allows the water to flow in the drain direction only and prevents the water from coming back into the tub. The drain line check valve must close in the back flow direction or the piston valve in the collection chamber may not reopen into the tub after the pump out is complete. Water should "fall" through the filter and go back into the tub....the heavier food particles go down into the chamber and are collected.
Here is a link for you to check out...I have all this info in my data base but since it is in PDF format it does not translate well to this format...
http://www.applianceaid.com/gedishdrain.html
I hope this helps...good luck and good day...Thanks for rating my effort......thanks....The Fang.
Apr 01, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher will not drain
In order for you to see the diagrams..here is a great link...anyone can use....
http://www.applianceaid.com/gedishdrain.html..you may need to scroll down to get to where you need to be...but these issues are GE specific...and there are other related issues you can see here.
I have all this material in a vast data bank of my own but it is PDF format which does not translate well to these medium.
Good luck and good day...please rate my effort.....The Fang.
Hope this
Mar 28, 2009 | GE Nautilus 24" Built-in Dishwasher
My dishwasher will not drain it is a GE nautilus.
I hope this helps...good luck and ggod day...please rate my effort......thanks....The Fang.
Mar 24, 2009 | GE Nautilus 24" Built-in Dishwasher
Will not drain
Mar 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Grinding/Rubbing noise?
the unit has a "food chopper" inside the pump sump. it is to chop up "food" items and not bones, seeds or other items. you can keep running the unit and see if after 2 or 3 loads the noise goes away. ie: the item get chopped up small enough to go out the drain.
if it doesnt go away, then you will need to get into the wash pump and see what is stuck in the sump.
its not hard to take apart and you will find whatever shouldnt be in there.
Dec 29, 2008 | Dishwashers
Emerson InSinkErator STC-BLK Sink Top Switch Trim Only - Black Logo
62 people viewed this question
Top Emerson Home Experts
Donni Steen
john h
Are you an Emerson Home Expert? Answer questions, earn points and help others
