Question about ViewSonic VX2025wm 20.1" LCD Monitor
With dvi monitor goes black for 2 second then comes back intermittently
Monitor goes black for 2 second then picture comes back
Ok what happens is as the title say my 20" monitor goes black for about 2 seconds then the picture comes back comes back, the monitor power light does not go out so i know its not the monitor going of and on. It happens while watching movies and just doing every day normal work on the systems. This is happening on 2 system which are being built for friends.
System 1
20" ACER AL2002W 1680 x 1050
Asus M2A - VM not the HDMI version
AMD Athlon 64 x2 4200+ (65W) Dual core socket AM2 2.2Ghz, 512 KB x2 L2 cache
System 1- OCZ DDR2 PC2-6400 800mhz Platinum XTC Revision 2 2 x 1GB sticks
Seagate Barracuda 320GB SATA HD 7200rpm
LG GH20NS10 Black SATA DVD-Writer 20x
350 watt power supply 20/24pins Model number IP-S350AQ2-0 made by POWER MAN
System 2
20" ACER AL2002W LCD 1680 x 1050 60 Hz
Asus M2A - VM X1250 onboard graphics not the HDMI version
Mushkin HP2-6400 DDR2-800 High Performance Series 2 x 1GB sticks
Hauppauge WinTV GO-PLus NTSC 44981 REV E199 TV tuner (the one with the mushkin ram)
- Increased the voltage to the ram to 2.1 volts that solved the ram problems i had.
(would crash everytime i ran memtest86 or any memory test software)
- Replaced the motherboard on one system to eliminate a problem with the on board video or the dvi port.
- Used different ram on one system to make sure it wasn't the ocz ram which is why one has mushkin.
Changed to the vga cable to see if that solved the problem checking now by watch 2 movies one at a time.
Next thing i will do is change to a 19" to see if it happens there.
I want to have both dvi and vga working fine so my friend can use the dvi for the computer, and the vga for here laptop.
Any help would be appreciated
  • kydangngo Dec 06, 2008
    I have the same problem with Acer 22" monitor hooked up to the M2A-VM motherboard via DVI port.
    4 gig Ram
    350W power supply
    Window XP SP2
    2 internal HD
  • 180 Answers
To what I understand. Dvi and vga is only applicable to a system or CPU. Sorry if I am wrong.
Tia.
Posted on Apr 17, 2008
SOURCE:
LG M197WDP, used as a monitor with a Windows 7 computer. Intermittently the monitor goes black for 15 to 20 seconds then the picture returns. I have checked drivers etc all up to date. Anyone able to
Could be a hardware issue, If the screen has a power light, does it change coulor (often green to orange) when the problem happens. If so its the screen inst getting any signal. It could be a connector or cable.
Nov 01, 2014 | Computers & Internet
Screen goes black for 4-5 seconds then comes back on
Go into the Catalyst Control Center and check "reduce DVI frequency on high-res displays" and leave "Alternate DVI operational mode" checked. This should resolve it. It is because of your video card that this problem is occurring. Let me know if you need additional help or if this doesn't fix your problem. Good Luck.
Mar 29, 2008 | Acer AL2016 W 20" TFT LCD Monitor
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Screen goes off.
Is the power led button on, if yes, it means the picture board of your monitor is malfunctioning.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 03, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
VX 910. Goes to black every 10 to 15 seconds then comes back on after 3 to 5 seconds With ''analog'' displayed in the lower right corner. Happens when connected to 2 different computers.
hi my lcd AL1916 acer monitor keeps going black or loosing signal after 2 or 3 sec. i press the moon on my keyboard 2 times it comes on then off again please help
Aug 11, 2009 | ViewSonic VG930m LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
My monitor goes black for about 2 seconds then goes back to pict.
Sounds asif the Xenon tubes that backlight the LCD are losing power. Probable cause, a power invertor or PSU fault.
It can be repaired by a hardware specialist, but best written off.
The cost of repair will be better spent on a new monitor.
Mar 19, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
ProLite E431S - comes on dim for a few seconds - then off!
Probably the power supply is defective.
Most probably the electrolytic capacitors in the secundary circuit heve become bigger then they used to be.
Replace them all...
greetings Drikus
Jun 03, 2008 | iiyama E431S-B 17" LCD Monitor
LCD Monitor blacks in and out for 1-2 seconds
does your monitor have an external transformer as the psu ?
If so, try disconnecting at mains for about 5 seconds and re-connect. failing that we'll need to dig deeper.
Jan 06, 2008 | Samsung SyncMaster 205BW LCD Monitor
Open Questions:
AOL MAIL TECH SUPPORT NUMBER 18OO8O31O69 There are two circumstances that can cause someone to want to change his/her AOL password: 1 forgetting the AOL password and needing to recover it and 2 to change the AOL password. The latter can be because the AOL password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's AOL password at least once in a month. Contact Aol Mail Password Reset. For your convenience to contact Aol Mail Password Reset We have provided all possible information of Aol Mail Password Reset. You can contact Aol Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an AOL Password The following steps show in detail how to change an AOL password when the current password is known: Sign into the AOL Mail Account from AOL Do you want to recover/reset your AOL email password? So you'll be do the some steps to recover your AOL password. We'll help you to fix your problem and we'll guiding the some steps to recover your AOL password. Follow and do the below steps to recover your AOL email password- Go to the AOL - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your AOL mail message on your Gmail account. AOL is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While AOL's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, AOL has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your AOL password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your AOL password.
Oct 22, 2019 | AOL Computers & Internet
See all ViewSonic VX2025wm 20.1" LCD Monitor Questions
ViewSonic VX2025wm 20.1" LCD Monitor Logo
631 people viewed this question
Top ViewSonic Computers & Internet Experts
Ekse
Alun Cox
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
