Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
Built-in flash does not fire off
I had just bought a new canon rebel xti and when I tried the flash, it does not fire off. The flash will pop up when in auto mode or if you push the flash button, but it just won't 'flash'. The busy flash symbol also comes up before taking a picture , and I noticed that the pictures I take (with the flash popped up) are dark, so the camera is assuming the flash is going off, but it's not. Also, I havent used any external on the camera as of yet.
  • 4 more comments
  • rd harris Apr 20, 2008
    same here. Bought my wife a new rebel xti and the flash won't fire at all with no errors or any indication why it wont fire.
  • Anonymous Jun 15, 2008
    The link that "solves" this problem doesn't really -- our flashes still pop up but don't flash. That solution is for flashes that don't even pop up.
  • jwsjohn01 Jun 20, 2008
    I have found a few links that describe how to fix the switches that control the deployment of the pop-up flash, but the problem that I haven't seen any solution for is:
    1. Flash will pop-up, but
    2. Flash will not fire
  • arjun_gaudel Aug 11, 2008
    same problem happen with me also . when i try to shoot picture built in flash does not fire.
  • oasd001 Dec 05, 2008
    I have the same problem described here, but on my EOS 40D (4months old). The flash pops up when exposure is too low (in any of the auto modes), but does not fire. Apparently, the camera expects the built-in flash to fire, since the exposure in the picture it takes is too dark.
    This also occurs in P mode. If I pop up the flash manually, it does not fire, although the exposure is obviously calculated with the flash.
    I reset all the custom function settings, turned the camera on/off many times, took battery and CF card out, and still have the same problem. Argh. I am pretty annoyed.
  • JReese Apr 30, 2013
    Just bought my wife a T3i and the flash pops up but doesn't fire, in ANY mode or setting. Tried removing the battery and chip for 20 minutes as some blogger suggested, tried resetting everything, tried holding down the flash as I shot, but nothing worked. I get the BUSY warning on screen, but no error codes. I set the wheel to Auto mode in dim room and the flash pops up to fire, but doesn't flash. Is there ANYTHING I can do outside of sending it in to be fixed? Would updating camera's firmware (It's at 1.04) do any good? TIA
Not really a solution, and about 3 years late :) my EOS400D also developed the same problem (however it was also coincidence that I had just updated to Firmware 1.1.1 (from 1.0.4), but basically the flash would pop up, but wouldn't fire (so not the standard problem with the microswitches), I found with a bit of forum searching that if you hold the flash down to almost clicking it in and then shoot it does actually fire. I am going to see how much it costs to get this fixed and will post what the actual fault is if I can understand the repairman.
Posted on Oct 30, 2010
    Mooland, did you an understandable answer AND how much did the repair cost? TIA
  • Rosa Rose
    Rosa Rose Aug 20, 2013
    Mine is doing the exact same thing. How much did it cost?
The answer is here
http://photo.net/bboard/q-and-a-fetch-msg?msg_id=000xmg
i just followed the instructions and got it working. pop off the black metal cover, undo the screws (you may have to take the silver plate off entirely) and allow the black plunger switch free (on the site it suggests there are more than one plunger... my camera only has one on the right side) replace the silver foot, ensuring the plunger goes through the hole, and then pop the black plate back on. should work fine.
Posted on May 09, 2008
I have the same problem with the non-firing flash. My camera shows an error and tells me to turn it off and on again, but it doesn't help. How can we fix this problem?
Posted on Apr 20, 2008
I've been having the same problem with my old Canon EOS 1000F. I only bought it last year, so obviously it's used. I can't get my head around this problem. It isn't going off in Beginner mode or P mode. As for the other modes, no luck either.
Once when I was at a show of my girlfriends I found that holding down the shutter on P mode so it took two shots, the flash would go off on the second and not the first. Of course, this is not convenient to anyone unless you want to only have half of the photos you could.
Posted on Mar 31, 2008
I just Bought a Canon Speedlite 540EZ it will not fire in the hot shoe of My Rebel XTI are they compatible
No. The rebel, or any digital canon camera requires the use of the EX or EX II series flashes.
Jan 19, 2010 | Canon Speedlite 540EZ TTL Flash
Canon rebel xti flash pops up but says it was obstructed
This is a problem known by Canon, you will have to have it serviced.
Oct 30, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
The built-in flash on the Canon Rebel XTI won't flash.
i am having the same problom try this i just found this ... http://www.fixya.com/support/t1021194-flash_not_working
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I just bought the 430ex II flash and it won't fire on my Rebel XTI.... i read the manual but I'm not sure whats wrong, have any advice?
I assume that flash is turned on. 430ex flash will fire automatically only in AUTO mode. On manual modes you mus manually force the flash to fire.
If flash doesn't fire at all, consider to claim the vendor or let the vendor to check the flash mounted on your camera.
Aug 04, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Why does the word, ''busy'' pop up on the canon rebel xti?
If the flash fires a full charge(eg. in a dark environment) then this message will appear whilst it recharges. If the message appears all the time and you cannot take a photo there is most likely a problem. Try taking some pictures without the flash card to eliminate that first.
Apr 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I have a Canon Digital Rebel XTI and the flash pops up but doesn't fire in any mode. Is there something I can do to fix this?
It sounds to me as if the xenon bulb within the built in flash has expired.  It's a quick and easy job for a qualified service engineer to repair this for you.
Dec 11, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Built-in flash does not work
DO NOT MESS with a new camera (or any other new equipment).
Take/send it back to the vendor, The purchaser has rights also. Number one it must work.
I don't know your location but in UK (& Europe) we have very strict consumer legislation.
Mar 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Built-in flash auto pop-up problem
Does the 'pop up' pop up? If it does and still says obstructed- closes it and pop it again If it still persists Canon customer support will advise the next move. If a repair price seems high you could perhaps get a separate flash if the camera accepts them.
May 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
718 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
