Question about Kitchen Ranges
Kenmore free standing range /model 911.61771790 . Light to tell you burners are on allways stays on when burns are off. went to replace receptacle block for buner and with burner off it still has power to it.
    Sergeant:
    Champion:
  • 333 Answers
The light will stay on until the burner cools down.Sometimes takes about 15 minuets
Posted on May 13, 2010
I replaced a burner receptacle block on my Kenmore classic grille range ( model #911.4698815), now when I turn on that burner on both front and back burners come on . What is wrong?
You have wired it back wrongly. My guess is that you reversed the negative and positive, and the power is going to both burners via the common negative.
Dec 02, 2015 | Kenmore Kitchen Ranges
Burner light stays
you must sure is the burner contacts are o.k or the receptacle is faulty see the diagram 5c7250e3-ba3e-4b5d-944d-b7cdaa1cbc4f.gifb9fcce0a-595b-4298-aa22-aecec61be306.jpg. You must clean the receptacle, and see if some wires and loose or burn, and repair or replace.
However you must sure too if the switches are o.k look for some loose wires or faulty wires and repair, or the switch are faulty test with VOM continuity see the diagram.911164c0-a3fc-4d92-8b45-f3946e75de93.gif
God bless you
Jul 29, 2013 | Hotpoint RB757 Electric Kitchen Range
I have a Kenmore model 790.95592 30" free standing range with self-cleaning function that I think has an eletronic function problem. The oven burner elements start on its own and fluctuates to danger
Dear Ernie,
I am very glad you asked. As a retired firefighter, and an electrician, I can say you were just about to have a fire.
The most likely problem is a "meltdown".
Something has melted, and is causing a direct short circuit.
Lightning or power surges can do this.
Please turn off the circuit breaker, and unplug, or disconnect the wires to the back of the stove.
Start by looking where the wires go into the back of the stove.
See if there is visible burning or smoke or blackness.
You might be able to fix this, buy re-wiring the stove, but if the controls are melted, you may be needing a replacement stove.
An electric meter will be really helpful to find the problem, but with the way you have described this, you may be able to see or smell the burned part.
God bless your efforts.
Jul 10, 2017 | Kenmore Kitchen Ranges
Kenmore model number 91193412000 burners went out
Its almost impossible to tell you how to repair it without being there to view what is going on. by what you are saying, it looks like you have a short between two or more wires, possibly stuck together from heat. After switching off, remove cover at the back and follow the wiring to the clock and the burner switches and look for anything obvious. Look for a wire possibly burned off and leaning onto another electrical wire.
Jul 19, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore free standing gas oven. Burners will
It sounds like the erc electronic range control has failed. Try this link it will walk you thru checking and replacing the erc http://appliancehelponline.com/ovenerc.html
Jul 16, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
May 30, 2009 | Kitchen Ranges
Electric range surface light stays on
When the burner went, it took out the switch that controls it. The contacts inside the switch have welded together. That switch needs to be replaced. You should also look at the receptacle that the burner plus into. That may have been the original cause of all the problems. The contacts in them often wear causing the burner to src inside the receptacle. These parts should be readily available from Sears: burner control (infinie) switch, Burner receptacle.
Apr 09, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Not a 965 problem but a 956 problem...
shogan, Most likely, the problem is with the circuit breaker. It became too weak for regular load. Replace the circuit breaker and I believe it will solve the problem. Gendos....post back
Jan 05, 2007 | Kenmore 96532 / 96534 / 96539 Electric...
Kitchen Ranges Logo
109 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
