Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Fisher and paykel dishwasher draining problem. It smells very bad when I start a new load. There is always left over water at the bottom. How can I fix this?
reg501
  • 413 Answers
SOURCE: Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Posted on Jun 08, 2008
SOURCE: dishwasher f1 problem on fisher paykel
先谢谢啦
Posted on Feb 21, 2008
futureloginn
  • 734 Answers
SOURCE: My fisher paykel dishwasher is
no problem with our chat sesson...
but your answer is here----
if you pull out the lower drawer, there s aside release pin on either side of bottom corner of hte drawers when extended. a small maybe quarter sized hole( no need to mess with that only removes the face panel) but under it is a release that you can push in and back a little, this will unlock from the drawer hinges(slides) just nee to lift up and over to the left slightly, on the back wall behind hte drawer youll find a pretty good trouble shooter for this model, itll tell you what hte code is and will try to walk you through as to what might of happened as well as recommended repair
Thanks
Posted on Dec 15, 2008
mark_37388
  • 100 Answers
SOURCE: Fisher & Paykel dishwasher:
The F1 code mean that there is water in the bottom of the cabinet one of your drawers are leaking
Posted on Mar 27, 2009
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Posted on Apr 21, 2009
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Fisher paykel cross draining
As the drawers share a common outlet to the kitchen sink drain, it is the drain water from bottom drawer going to top drawer. Can happen if the drain hoses are not following the correct specifications for installation. An air gap kit is available to solve the problems.
Refer
http://www.genuineapplianceparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/?preadd=action&key=WT50
After a cycle the dispenser is filled with water. The dishes are clean, the detergent is gone, but there is water filled in the dispenser. Thanks!
There is a small drain hole in the bottom of the dispenser. Most likely it is blocked. Try a toothpick or similar to unblock it.
Feb 11, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
I have a single draw F&P Dishwasher and get the error F1, turned off the power and still same problem, but in the last 2 or 3 loads of washing dishes not all the water has been gone, always about 2cm...
most likely you have a leaky drain hose.
Have you checked if sink drain is clear (no back flow)
Turn dishwasher power off.
Empty all the water using a small container and towels.
Get the drawer out (remove front cover first by taking the side pins out and carefully lifting it).
Check behind to see water lying on the floor of dishwasher housing. If leaky drain hose you will have to replace it.
Dry the base of the dishwasher (towels and dryer) otherwise F1 will not go away.
Sep 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & paykel 2 drawer unit
yes there is. It is just inside the white hoses that drain the system. 1 per drawer. They cost about $0.50 but are a real pain to get to. This flap will go bad in about 3-5 years and maybe sooner depending on the temp of the water used.
If the bottom flap goes bad, using the top drawer will drain into the bottom drawer.
Oct 12, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Jun 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Broken washer
could be clogged drain. look at my issue "eco smart won't drain, smells hot" on how to remove motor from bottom of washer and check lower drainage area. bail water out first and be ready to catch water when you remove that motor unit.
May 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
241 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
