Question about Whirlpool ACU102PK Air Conditioner
BTU of air conditioner?
What is the BTU of this model of air conditioner? My mother had this unit and she moved into assisted living and we must sell this AC since the apartment complex would not buy it.
Thank you for a reply.
  • 8,197 Answers
Here are all the specs of the air conditioner whirlpool ACU102PK
Key Features Type Thru-Wall/Window Cooling Capacity 10000 BTU/hr Energy Efficiency Rating 8.5 EER Remote Control Without Remote Control Fan Speeds (Cooling) 2 Dimensions Width 25 in. Depth 20.5 in. Height 14.5 in.
Hope this helps you and Good Luck.
Posted on May 13, 2010
Testimonial: "wHAT A gUY!!! I have never had an answer back so quicky from anyone on the web. Also with the facts. We did not know there was a remote, but we will never know what she did with it."
Where can I get a mounting kit for this product? Frames and side panels
Try e-bay or Amazon.
For the part numbers and descriptions, try entering your model number into "Sears Parts Direct".
They will sell the parts if they list them, also.
God bless your efforts.
Apr 12, 2016 | Sharp AF-Q100RX 10,000 BTU Window/Wall...
How do ifind the btu for my cz-10rt32p air con
Air Con Model Numbers normally have the capacity of the unit within the Model Number, but not always. It would look to me as if your unit was a 32,000 BTU unit, but I could be wrong. It should say it on the label. It can be displayed in BTU or Tons. One Ton = 12,000 BTU. For example, if your label says 2.5 Tons, multiply this by 12,000 and you'll get the total of 30,000 BTU.
But if you can't find it on the label or the label is missing, you can get an approximate by measuring the room the unit is cooling/heating. The formula for calculating this varies from place to place due to weather conditions, and maximum/minimum temperatures where you live.
I live in the Caribbean and it is very hot here all year long, so we use this formula: length x width x 85°F
But this formula will be different if you live in the northern parts of the country. Do a research online to find the correct formula for your area if you need to use this method.
Dec 02, 2014 | Panasonic Heating & Cooling
Why is it not blowing air
You said it doesn't blow air - but does it show any sign it is getting power such as a pilot light or LCD display? If not:
First, check the power outlet - is it live? Does the plug fit securely? No extension cord, right?
Second, plug the unit into another outlet - preferably the one where it worked before, if it's not too far away. Don't use an extension cord.
Third, let it sit for 24 hours. Sometimes moving a portable unit can require a waiting period before use.
Fourth, check all the access panels to make sure they are snug. Sometimes they have microswitches that shut off power when opened. Moving the unit could have dislodged one.
May 14, 2014 | Haier Commercial Cool 12,000 BTU...
Need a control remot for my 30000 btu Lennox unit
Hi jean, If you haven't found a remote yet then try Ebay OR Amazon..... The link below is an Ebay page showing a few different lennox remote controls, I hope this helps............CHEERS..
remote control for 30000 btu Lennox
Aug 26, 2012 | Danby DPAC8399 Air Conditioner
Not a problem, just a question. Can you determine from the Model #, 5018QKA1, what size unit I have? Style # is 18MC 000087CR. Thanks.
It is a 18,000 btu unit which is good for 700 to 1000 sq ft of living space. Model# 50*18*QKA1< the 18 stands for 18,000 btu. Hope this helps!
Aug 31, 2010 | Kenmore Heating & Cooling
My LG 7000 BTU Heat / Cool Window Air Conditioner does not cool and the fan speed F1 will not work. Fan runs on F2. The heat works fine. Any suggestions?
You have a control board issue. You can get a new control board by Google searching the make and the model of the unit. There are several sites that sell them
May 24, 2010 | LG Heat cool Window Air Conditioner
Can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
May 21, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
Need btu rating ???
Carrier YCB213D Y Series Window Air Conditioner 21000 BTU 230/208V. No Remote Control. High-efficiency energy-saving units. Quiet cooling for living areas.
Please dont forget to rate ;o)
Aug 17, 2009 | Carrier YCB213D Air Conditioner
Circuit breaker
ngfam1
Happy to assist,
HOW MANY BTU IS THE AIR CONDITIONER?
And is it 110 or 220 line!
If it is using 110 or 115 volts like normal house current and it throws circuit breakers in your electric box,then you need to run a dedicated line just for the Air Conditioner!
Usually this happens to 110 -115 volt air-conditioners that are more than 12,000 BTU and do not have a dedicated electric line in the wall only for the air conditioner!
New air conditioners have a circuit breaker built into the units plug!
And I have seen some that throw that breaker to off frequently even if it's only an electric surge! Which it should not do!
if its the case and it's new, take it back to the store and ask for a different model, size, or brand!
Fedders had an 18,000 BTU/ 110-115 volt unit that did this with every single unit last year! I stopped selling that unit only!!
Ngfam1
PLEASE GIVE ME A GOOD RATING HERE FIXYA.COM BEFORE YOU SIGN OFF!
you can just use it as is as long as it survives!
Aug 29, 2008 | Amana PTH123B35AJ Air Conditioner
Whirlpool ACU102PK Air Conditioner Logo
189 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
