Question about Whirlpool Duet GHW9150P Front Load Washer
F28 appearing on display. What does it mean? how do I fix or override? Washer begins cycle as normal but at some point stops leaving clothes soaking wet. Can not spin either. Attempted to intiiate clean cycle. That also showed F28 sometime during the cycle.
    President:
  • Whirlpool Master
  • 662 Answers
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Posted on May 19, 2010
LG washer makes start/stop sounds at beginning of cycle. Is this normal?
If it works and washes the cloths most likely it is normal.
Oct 07, 2016 | LG Washing Machines
Washing stops in cycle with an F28 code.
Hi
This code indicates an electronics communication problem with the washer.Please check this link to get a detailed idea related to the lists of codes and the resolutions to them:-
http://whirlpool.custhelp.com/app/answers/detail/a_id/2885/~/display-shows-an-error-code---front-load-washer
The error code F28 means one or both of these parts are bad.
Motor Control Unit ,Microcomputer Machine Control Unit .
It would be a good idea to order both, as both components have been problematic for error code F28.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 02, 2011 | Whirlpool Washing Machines
My Whirlpool Duet Front Load Washing Machine is showing a F28 error. What does that mean?
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Jan 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    F28 error / water starts to fill then quits in 15 sec's
    F28 is a communication error which usually means there is a connection that has come loose.Check the wires on the control board.
    Nov 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
    My washer stopped and was flashing F21 (drainage issue) so I called a plumber. He checked the hoses and removed the panel and cleaned the drain trap. It didn't fix the problem it's still won't drain. It...
    The SUD message relates to overdose of detergent detected during the Wash Cycle.
    This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds.
    If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
    Check the drain hose and make sure it is not plugged or kinked. this seems to be the reason as to why your unit is not fixed even after trying to solve F21......
    F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28.
    Good luck
    Aug 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Smell in washer
    Vinegar will fix this! Try pouring a quart of white vinegar into the washer, then run a cycle with no clothing in the washer. When the rinse cycle begins, stop the washer. Let it sit for about 30 minutes, then complete the cycle. That should do it! Afterwards, be sure to leave the door open to air dry it.
    Oct 27, 2008 | Kenmore Elite 45986 Front Load Washer
    New Whirlpool Duet Washer(WFW9300VU02) F28 error
    You can call whirlpool for service but the tech sheet f28 has a communication problem from you computer to the motor..
    The communication between the Central Control Unit (CCU) and
    the Motor Control Unit (MCU) cannot be sent correctly.
    Possible Causes/Procedure
    1. Unplug washer or disconnect power.
    2. Check wire harness connections to the MCU, the motor, and
    Central Control Unit (CCU).
    Check connections of the CCU board within the housing.
    Make sure all grounding switches are engaged.
    3. Check the drive system for any worn or failed components.
    4. Plug in washer or reconnect power.
    5. Verify CCU operation by running a Diagnostic Test or any
    cycle.
    6. Check the MCU by looking for operations of the drive motor.
    7. Check the drive motor for powered rotations.
    8. Check that the serial harness at the MCU is not mounted
    upside down. The wires should be to the left when facing
    the MCU connectors.
    Sep 20, 2008 | Washing Machines
    F28 error
    Jul 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    We just had a flood in our basement and our Whirlpool Duet Sport HE front load washer is displaying F28 which I know means something electrical. Is there any way I can disengage the electronics to get the...
    Unplug the machine. Remove the bottom access panel (three torx screws along the bottom). Reach up under the area where the door lock is and feel for a round door release mechanism. Pull down and the door will unlock
    Jun 08, 2008 | Whirlpool Washing Machines
    Not finishing wash cycle
    you have a clogged water pump,thats  why water is left behind
    May 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    201 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
