Question about Dishwashers
GE Potscrubber will not drain or cycle.
I have tried the baking soda/vinegar/boiling water already. Removed screens and filters. The rubber cup seems to be holding water in the basin. The unit will only hum when engaged, and won't kick in regardless of setting or cycle selected.
Help!
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
DishwasherGE Potscrubber will not drain or cycle. - 2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on May 14, 2010
Water wont drain every time
Hello
When a dishwasher won't drain, that usually means that the appliance's drain line is clogged. The drain line, which connects the dishwasher to the garbage disposal, must be cleared of debris before the dishwasher will resume its normal operation. If the drain line is the problem, clearing it is simple and requires only a few standard household products.
Turn off the power to the dishwasher, if possible. Remove all the dishes and the racks. Put on a pair of rubber gloves and use towels to soak up most of the standing water in the bottom of the dishwasher.
Unscrew the rotating sprayer arm in the bottom of the dishwasher. Rinse off the arm and all its seals and screws in the sink and set it aside.
Locate the filter screen in the back of the dishwasher's floor. Pop off the screen, using a screwdriver to loosen any bolts that may be holding it in place. Rinse off the screen, then wipe the dishwasher floor with paper towels to remove any large pieces of food or other debris. Wipe the area clean with a damp sponge.
Replace the screen and the sprayer arm. Locate the drain line; it should be near the back of the floor of the dishwasher, right underneath the filter screen. Pour 1/2 cup baking soda into a cup and add enough water to make it into a pourable paste. Pour the paste into the drain line through the screen. Add 1/2 cup vinegar to the drain line and let the solution fizz for 15 minutes.
Boil a quart of water. Remove the pot from the heat, allow the bubbling to subside and pour the water into the drain line to clear the baking soda solution. Watch the water go down the tube; if it seems to be draining slowly or not at all, repeat the baking soda treatment.
Replace the racks and make sure that everything is put back together properly. Turn the power back on and run the empty dishwasher through one normal cycle to see if the drainage problem is fixed. If not, repeat the process a few more times. If the issue still isn't resolved, the problem may be with the pump or another electronic part. A professional is best suited to deal with an issue like that.
Sep 07, 2011 | Dishwashers
Tip
How to Sanitize Your Dishwasher
Step 1 -
Get rid of any odor that may be coming from the plumbing pips your dishwasher shares with the sink. Pour a half of cup of baking soda down each sink drain. Pour cups of vinegar down each drain until all of the baking soda is washed away. After five minutes, run very, very hot water down each of the drains.
Step 2 -
Clean out your garbage disposal. Slice a lemon/lime and put the slices down your disposal drain. Run your disposal with cold water running.
Step 3 -
Pour two cups of vinegar into the dishwasher and let it sit for an hour and then let the dishwasher run through a cycle with the hottest water possible. Repeat the process is that does not clean up all of the build and film. You can use baking soda and bleach instead of vinegar - just sprinkle the baking soda in the bottom of the dishwasher tub, and pour bleach inside the tub as well.
Step 4 - Between washes, pour 1/4 cup of lemon juice into the dishwasher cup and run a short, but complete wash cycle. This will not only deodorize the dishwasher but will also help get rid of any metal build-up.
on Oct 19, 2011 | Frigidaire Dishwashers
The water wont drain from our whirlpool slimline, and the tablet will not come out and wash the dishes
Hello
Aug 09, 2011 | Dishwashers
The water smells bad as if it is not draining correctly. Is there a water filter that needs to be replaced? How do I clean out this washer to get it smelling nice?
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Hope this helps.. Please post back if you need mor information.
Daniel
Nov 26, 2010 | Bosch WFMC 3200 Front Load Washer
Mold smell comming from duet washer
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Hope this helps... Please post back if you need more information.
Daniel
Nov 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We are getting a strong odor from our two compartment dishwasher, would welcome any suggestions
Get rid of any odor that may be coming from the plumbing pipes your dishwasher shares with the sink. Pour a half a cup of baking soda down each sink drain. Pour cups of vinegar down each drain until all the baking soda is washed away. After 5 minutes, run very, very hot water down each of the drains.
Clean out your garbage disposal. Slice a lemon and put the slices down your disposal drain. Run your disposal with the cold water running. You can use just the lemon or an orange rind if you don't have a whole lemon.
Pour two cups of vinegar into the dishwasher and let it sit for an hour and then let the dishwasher run through a cycle with the hottest water possible. Repeat the process if that does not help. You can use baking soda instead of vinegar - just sprinkle it in the bottom of the dishwasher.
Between washes, pour ¼ cup lemon juice into the dishwasher cup, and run a short but complete wash cycle. Is will not only deodorize the dishwasher, but will also help get rid of any metal build-up
Nov 03, 2010 | Fisher and Paykel Dishwashers
LG tromm mold smell.
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Please post back for further assistance. Hope this helps...
Daniel
Sep 01, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Is water suppose to stay in the sump pump of a ge potscrubber dishwasher. The water drains except in the very bottom where I guess the pump is. There is lots of mildew and I have lots of grit on my...
Yes water does stay in the sump all the time. This is normal.
Try running a cycle with a cup of Vinegar or Baking Soda in the dishwasher.
Also check to make sure that your drain line (under the sink) is higher than the sink drain and not allowing some sink drain seepage back into the dishwasher.
Jun 20, 2010 | GE 24 in. GSD2230Z Built-in Dishwasher
Blocked kitchen drain
If you have a wet dry vac, remove all the water in the sink. Then take 1 full cup of baking soda and 2 cups of white vinegar. Pour the baking soda into the drain, then pour the vinegar on top. Let it sit for about 20 minutes, then flush with scolding hot water. If that doesnt work then do it again and let it sit for longer. Baking soda and vinegar make a acid that will eat through most anything that goes down drains.
May 31, 2010 | Plumbing
Water is pouring out of my dispenser drawer
I have read other folks say that this has happened to them when a sock or wash cloth gets stuck behind the rubber seal of the door. There is a pipe that drains the water from your detergent tray and it may be clogged with a sock. Try feeling around behind the rubber seal in proximity to the detergent tray and see if there is a piece of clothing stuck in the pipe that drains the detergent tray. Also remove the tray and check the pipe from that end too.
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Dishwashers Logo
204 people viewed this question
Top Dishwashers Experts
