Question about Philips Magnavox 51MP392H Rear Projection Television
Can Not Align RED via single or multip point conversion
Screen looks as though it is in a 3d format. The "guns" are not aligning properly.
  • Philips Master
  • 8,617 Answers
The phillips DPTV305 - DPTV345 convergence repair kit is the right kit for your model which should solve that issue. The kit is available from www.tvrepairworld.com and also contains the CD with instructions.
Posted on May 14, 2010
My picture looks like it is in 3d there shadows on people
Older projection TVs use three separate "light guns" to essentially paint the picture on the screen. What likely happened, is one of your guns went slightly out of alignment.
You can either get it repaired, or attempt to align it yourself. It is doable, though tricky and rather risky. The process would depend on the type of TV you have. If it is a TV that uses the three separate light guns, then it's likely a few years old, and it might be tough to find instructions online for your particular model.
May 10, 2011 | RCA Televison & Video
The picture looks bent and looks 3d...my friend who sold me the tv had the same problem and she was able to fix it but she cant figure out how to do it now ... somthing about the red and blue being off...
In the tv menu settings there should be a convergence menu or alignment menu...you need to go here to re-align the red and the blue guns to display the proper picture...most projection tv's have a setup screen for aligning the colors..you want to line up the red and the blue to get as close to white as you can
Dec 21, 2010 | RCA HD52W59 HDTV Projection Television
The color is way off on the tv. It also looks curved, like if there are words on the tv they go up at an angle toward the edges of the tv. When you try to align the color on the tv you can get the center...
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 01, 2010 | Philips 60PP9202 60" Rear Projection...
Red lines out of alignment
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
Jan 25, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Conversion problem on my Sony projection tv
Convergence problems are common on projection TV sets. After 4-5 years or more the chips will fail and should be replaced.
Here is more info...
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Dec 10, 2009 | Sony KP-51HW40 51" Rear Projection...
I can't align red or green bulbs with the digital array, how can I get them to move left/right they only move up/down.
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Oct 25, 2009 | Hitachi 50UX57B 50" Rear Projection...
The conversion went and also the color blue
There are two common problems with Projection TV2.gif sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
Oct 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
My rca 52'' flat screen tv
It sounds like your TV needs to be aligned. There should be a menu item in your setup menu called "Alignment". Once you choose this the system will either automatically align itself, or the screen will display a graphic that will allow you to align the guns manually. Normally you will move either up or down or side to side until 2 separate lines look like one.
Jul 14, 2009 | Televison & Video
Pictures look like they are in 3D
it sounds like your convergence is off.
you have Red, Greed & Blue projection guns
through your menu's you will find adjustments for them ...
set your green first then align then red and then blue to the green..
when making this adjustment the tv should put up a caliration signal called a crosshatch
a matrix of H and V lines to align
Apr 15, 2009 | RCA HD52W56 52" Rear Projection HDTV
Center adjust on Red gun is not aligning with B&G vert.
frist set blue and green than set red itwill shoew yu single chakall will be focous in single line than than gun will be allign horizontal if it will correct if itisnot comming than cathode problem.
Oct 06, 2007 | Sony VPH D50HTU Multimedia Projector
Philips Magnavox 51MP392H Rear Projection Television Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
