Question about eMachines ET1641-02w (PT.NA60X.001) PC Desktop
Hello I have an E-machines ET1641-02w turns on in 1 sec.
Hello I have an E-machines ET1641-02w and the machine turns on in 1 second and then shutdown?
Change smps power supply.
jitender sharma
Posted on May 14, 2010
Hello, I have a portable ice maker model 102C igloo . the machine turns on but will not continue the cycle and the ice full red light comes on. Any answers to this problem are welcome.
The tray full may be triggered or stuck or another problem may exist. Look for what senses the ice being full and also check with Curtis support:
(another person was tld to do this and it workd:
1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hours.
I included some links for your convenience. Good Luck
1 How to fix portable ice machine part 1 of 3
Troubleshooting Portable Ice Makers
Igloo ICE102 WHITE User Manual Troubleshooting Guide
Apr 29, 2016 | Freezers
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
How to shutdown photocopy ir3025
The proper way to shutdown the machine is to press and hold the Power button in Control Panel for 3 seconds and wait for the shutdown instruction displayed. And turn off the main power switch located at the lower right side portion of the machine.
Jan 09, 2014 | Canon ImageRunner 3025 Black and White...
I have La Mazocco 2 group and when backflushing,
Machine is saying it cannot get water, turn knob to 0, wait a few seconds and make sure water is turned, then turn it to 1, wait 20 secs, then turn it to 2.
Apr 12, 2010 | La Marzocco Linea Group 1 Espresso Machine
I have Canon IR-C5185i. Just assembled out of the box. Powered on. Message displays with error E0000732-8888 and I am instructed to ''turn switch off and on''. What could be wrong?
When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below.
- E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.)
- E732-8888 can be displayed when a different scanner is connected to this machine.
1. Connect the Color Image Reader to this machine. (Do not connect the DDI cable).
2. Turn ON the main power switch.
3. Change the setting values of the following service mode items.
- Service mode > COPIER > Option > BODY > W/SCNR: from '0' to '1'.
- Service mode > COPIER > Option > BODY > SCANTYPE: from '1' to '0'.
Reference: For the Color Image Reader-E1/F1, this mode has to be set to '0'. On the other hand, it has to be set to '1' for the Duplex Color Image Reader-G1.
- Color Image Reader-E1: Platen cover model
- Duplex Color Image Reader-F1: Two-sided reversal reading type ADF model (DADF-M1)
- Duplex Color Image Reader-G1: Two-sided simultaneous reading type ADF model (DADF-T1: only for the iRC5180)
4. Turn OFF the main power switch, and connect the DDI cable.
5. Turn the main power switch ON.
Note: How to turn OFF the main power switch.
When turning off the main power switch, be sure to follow the steps below to protect the HDD inside this machine.
1. Hold down the control panel switch for 3 sec or more.
2. Following the instruction displayed on the shutdown screen, operate the control panel. (The main power switch is turned OFF automatically.)
3. If there is a need to unplug the power cord (from the wall outlet), perform step1 and 2 above before unplugging it.
Nov 17, 2009 | Canon Office Equipment & Supplies
Projector turns off after 15 or so seconds of startup. The dell logo displays for those 15 or so seconds and roughly 1 second before it turns off, it projects a dialog box. It will shut off much faster if...
The problem you're describing is a classic symptom of a defective fan--some fans simply have + and - power connections. However, other fans have a third, yellow wire, for sending a pulse to the main board to tell it that the fan is indeed running. If the main board doesn't get the signal, it's internal programming instructions perform a shutdown in case of any error condition--protects the unit against excessive heat, current draw, etc. MAKE SURE THE DUST FILTER IS CLEAN! A dirty filter causes the fan to pull harder, increasing current draw, possibly triggering the symptom. The other possibility is a defective power supply causing an over-current condition. Again, the main board senses this and cues a shutdown. You'll need to send the unit out to a repair facility to confirm a diagnosis. Any reputable shop will give you a quote first with an explanation of the problem.
Sep 16, 2009 | Dell 3400MP Multimedia Projector
Mini labtop mouse pad stopped working.
Please Shutdown your machine then remove the battery for a couple or five seconds then plug it back and turn on your machine. It works for me.
Thanks
Aug 26, 2009 | MSI Wind U100-030US Laptop
I am getting an error message "S545"
Fuser unit malfunction code.Check the connectors,thermistors and thermofuses.Reset the code :enter in the service mode (press total clear yellow key and pres 1-0-7 press and hold down more 3 sec.the Clear key (red C key)) turn OFF the machine,umplugged the cords wait 10 sec,plugg the cords amd turn ON the copier.
Aug 14, 2009 | Ricoh Aficio 1035 Copier
DeLonghi EC155 Expresso Maker
THE PROBLEM IS THAT YOU HAVE TO STOP THE MACHINE ONCE YOU HAVE ENOUGH IN YOUR CUP . IS NOT A COMERCIAL MACHINE THAT WOULD GIVE THE RIGHT AMOUNT AND THEN STOP ....
Feb 18, 2009 | DeLonghi EC155 Espresso Machine
Won't turn on
What you have there is a V27 Chassis manufatured in 1999..
But it is the same chassis that was later used in their WS55517 65517 and 73517... Regardless of the outcome here are some common caps that ALWAYS need to be replace:
C979 2.2uf 200v
C531 2.2uf 160v
C551 2.2uf 160v
C981 22uf 50v
C402 47uf 35v
Now to your problem, it could be a number of things. The regulator could be suspect, (Ic951 which is a STRF6628) but you might try the following before taking any gunshot approaches. This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Hope this helps!
Bill
Nov 16, 2007 | Mitsubishi VS-55705 55" Rear Projection...
eMachines ET1641-02w (PT.NA60X.001) PC Desktop Logo
470 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
