Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Essential 500GB isn't recognized by XP
I had to disconnect all my USBs, including 3 500GB WD externals. When I plugged them back in and rebooted, only 1 was recognized. The other 2 power up and I can hear no scratchy sounds. However, there is no yellow light in either drive and neither show ups in device manager or disk management. (For a while, the yellow light did appear, but still no recognition by XP.) For now I hope to avoid drastic measures... i.e., removing the drive from the case, etc. Very frustrating! Any suggestions?
What do you have them plugged into?
Make sure they are actually plugged into their power supplies.
(I know it sounds silly, but it's sometimes forgotten.)
Also check the power switch on the back of each drive. Press it to power on the drive.
Posted on Apr 29, 2008
My WD Book was spinning and clicking constantly, so i unplugged the USB and the power source from my laptop. After plugging back in, it is no longer recognized on My Computer -- I've rebooted 2x. My...
Let's hope the spinning and clicking was caused by a bad circuit board in the WD Book, and not the Harddrive inside it.
To explain;
Inside the plastic external enclosure (Case) of the WD MyBook is an ordinary harddrive as used in a laptop, or desktop computer.
There is a small circuit board inside the case, that the harddrive plugs into. (Or there are wires from the small circuit board, to the harddrive)
The other end of the circuit board, has a USB cable attached to it.
The circuit board is an Interface Board.
It is this small interface circuit board that USUALLY goes out.
Harddrives are pretty tough, but they are a mechanical device, and are rated in hours of usage. They can fail.
What I would suggest is to buy an economical external enclosure.
Has the circuit board, USB cable, and everything needed, just needs the Harddrive.
Installing is easy. There are instructions included.
Now we come to the technical portion.
What size harddrive is it, and what technology does it use?
Size:
1) There are two sizes of Harddrives. They are measured across the Width.
A 2.5 inch harddrive is a laptop size harddrive.
(2 and a half inches across in width)
A 3.5 inch harddrive is a desktop size harddrive.
Once you open the WD MyBook case, and measure, you will know.
Pretty easy.
Technology:
Looking at the harddrives label, will tell you if it is an IDE (PATA) model, or a SATA model.
If no nomenclature is readily apparent looking at the label, there will be a model number on the label.
Put the model number in your search bar.
Example:
WD2500BEVT
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136387
250GB SATA harddrive. Also is a laptop size harddrive.
(2.5)
If you cannot find the information, just post the Model Number in a Comment, and I'll find out.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
Example of a 3.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Example of a 2.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1086960&CatId=2781
Example of a 3.5 IDE (PATA) enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1337265&CatId=2779
The information on how to open a WD MyBook case, is not something the external harddrive manufacturer states.
For this we'll have to rely on videos that are made,
1) http://www.youtube.com/watch?v=6FlySnyJ0CQ
There are also other related videos to the right.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 09, 2011 | Computers & Internet
How do I use my WD hard drive to store files so I can free up space on my laptop hard drive?
Hi:
That's an easy task:
1) Plug your Hd to your laptop and wait until the laptop recognize it as a new drive and assign a new letter to it. If you have a disc use it if your laptop ask for it.
2) Copy all files you want to transfer to the new HD and paste them on it.
That's it.
Sep 27, 2011 | Western Digital WD My Book Essential 1TB,...
Wont print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 21, 2011 | Lexmark X4550 AllInOne InkJet Printer
I got it hook up to my laptop and i wanted to print out 1 or 2 pictures. And it wont print.
4. Reboot your pc.
Aug 19, 2011 | Lexmark X3550 All-In-One Printer
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
Computer doesn't recognize hard drive
Basic Troubleshooting:
-Check all connections (Ethernet, Power, USB, etc)
-Install the appropriate driver for the device, usually included on a CD
-Double Check compatibility with your system (system requirements usually on packaging of product)
-If you haven't rebooted since you set it up, then reboot, this fixes a lot of things
-Try the product on another computer
-Try different cables/ports on the comptuer.
If nothing works, then send it in if it's under warranty or contact a professional service.
Feb 14, 2010 | Western Digital My Book Essential 1TB...
I need the driver for wd2500me-00,usb external hard disk
The folks over at WD said:
There are no downloadable USB, Firewire, or eSATA drivers available. WD external drives install using the resident USB and Firewire drivers that come in Windows 2000 SP4, XP SP2, Vista, and Mac 10.4 and 10.5. If the drivers are not installing when you connect the WD drive, or you are having driver issues, you will need to contact Microsoft or Apple for their recommendations.
I will search further if you like, just let me know.
Try the old, disconnect (the drive form the computer), reboot, reconnect, reboot once again and see if it picks up the way it was meant to.
Hope this has been of help please leave rating
thank you.
May 08, 2009 | Computers & Internet
Macbook Wont Recognize
Try the drive in another computer.
If it doesn't work it is dead...
May 06, 2009 | Western Digital My Book Essential Edition...
My computer won't recognize my flip cam on the front usb ports
plug in your flip. Click start, control panel, adminitstrative tools, computer management, storage, disk management. right click on flipvideo. Choose 'change drive letter and path' Pick a drive letter, any letter that is not currently being used on your comp (try U). Tada it should read your flip
Apr 29, 2009 | Pure Digital Flip Mino Digital Camera
Usb flash pen drive
Often it is due to electrostatic charges on usb. Unplug all USBs.Unplug PC from power cable for 10/15/ minutes. plug back computer to power outlet and restart. Plug back usb.
If it still does not work , flash memory may be faulty, test it on a different computer.
Mar 17, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
147 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
