IntelliFax2750 I changed cartridge today, bought from Staples (original one). However incoming fax or copy are not clear as supposed to be. What should I do? Thank you, Lana
    New Friend:
  • 116 Answers
Just check its drum unit
Posted on Jun 14, 2010
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
Feb 22, 2010 | HP LaserJet 3055 All-In-One Printer
Copy and faxes come out with a black line on the left side about an inch from the side.
If your INCOMING faxes have the same black line as your copies then the problem lies in the toner cartridge. A line on OUTGOING faxes and copies would suggest something on the scanner glass. This is a small strip of glass under the cover where your originals are fed into. Another way of testing is to run a report from the operation panel. If a report generated from the machine is ok then it is the scanner glass. If the report has a line then it is in the toner cartridge.
Good Luck
Feb 20, 2010 | Canon FAXPHONE L80 Laser
When sending a fax to someone the copy they receive has a white line through it. Our fax transmittal report also shows the white line through it. I've cleaned the glass above the scanner unit, blew through...
This is an indication that you still have something on the scan glass. Most likely some white out from an original or something. You can test for this by making a copy. If the white like is present but your incoming faxes are ok then it is in the scanner. You are going to have to look at this section very closely. Pay attention to which way your documents are scanned, is face up or face down. This will tell you which side (top or bottom) the strip glass is on. Sometimes it is stuck to this glass pretty good.
Again tho if you incoming faxes are ok, and you run a copy with a thin blank line then it is in the scanner assembly.
Dec 14, 2009 | Office Equipment & Supplies
Cannon ImageClass mf6590 toner cartridge issue
I have the same question. If you get an answer please send me a reply. aste2426@aol.com Thanks!
Sep 22, 2009 | Canon ImageClass MF5770 Laser Copier...
"remove and check left cartridge", replaced with new + same err m
Carefully read the user manual given with the AIO. Check the settings to keep the AIO in "FaxTel" or "Fax" mode to receive incoming faxes.
Sep 16, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
May 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Setting fax number for my machine
Thanks for the quick return offer. We did get it fixed by taking the machinea and cartridge to Staples and there was a gentleman there that knew the problems fix. Thanks again.
Mar 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
21 people viewed this question
k24674
jasbo
jasbo
