Question about Adobe Acrobat 7.0 Professional
I am trying to combine several documents (1 PowerPoint file, 3 Word files) into a single PDF. I am able to turn one document into a PDF. But when I try to use "Options >> Insert Pages" -or- "File >> Create PDF >> From Multiple Files..." option, I get an error message that says: "Missing PDFMaker files. Do you want to run the installer in repair mode?". I click yes. It then says "Please wait while Windows configures Adobe Acrobat 7.0" It then says "You must restart your system for the configuration changes made to Adobe Acrobat 7.0 Professional to take effect. Click Yes to restart now or No if you plan to restart later." I restart, then try the whole process of creating a PDF from multiple files (or adding a file to the PDF that I can make with just one file) I will be adding images of the error message I am getting in a comment to follow. Does anyone have any suggestions, I'm trying to send some documents to one of our Experts, so this is for the good of the community! ;D Thanks!
  • 1 more comment
  • Lauren Chang May 13, 2010
    This is the initial error message that I receive:
    Alright, I figured it out. It turns out that even though Adobe would let me select files in formats other than PDF to combine into one document, it wouldn't actually work with those other formats.
    I had to save each file individually as a PDF (by opening them, then selecting Print, then choosing Adobe PDF as the printer) then combining them.
    Hope this helps someone else!
  • AliTech110
    AliTech110 Jan 24, 2011
    Hi Lauren,
    Kindly correct you email address which you have just posted in the Lounge thread:
    Updated info for Experts using Payoneer in India
    Thanks ;)
4 Suggested Answers
thetaocat
  • 122 Answers
SOURCE: Cannot create PDF from MS word
click yes and you will get the automatic upgrade and then you can save as .pdf
Posted on May 10, 2009
label_chick
  • 407 Answers
SOURCE: I can no longer create 1 pdf file from mulitple files in acrobat 6.0 standard. I have to create a pdf for each file in word or excel and then open up acrobat and create 1 pdf file from multiple pdfs.
Have you tried appending to the document? this should give you the option to add multiple files to..
Posted on May 22, 2009
  • 16 Answers
SOURCE: I have installed Adobe Acrobat 7 on my laptop that
Good Afternoon -
Direct from Adobe, they state that versions 9 and above are compatible with Windows 7, and any versions 8 or prior are not supported and updates to make compatible will not be released. There are two solutions, one that may work and one that will definitely work. The first is to try to install the program under Windows XP compatibilty, natively on Windows 7. To do this, find the executable for installation, right click and select properties. On the comptability tab, click the check box that says: Run this program in compatibility mode for: and select Windows XP (Service Pack #) from the drop down, and proceed to install, running the installer as Administrator. The other guaranteed way is if you have Windows 7 , any version other than starter, you can enable Windows XP Mode which creates a virtual PC of XP on your machine and integrates the program references into Windows 7. Details on this can be found:
http://www.microsoft.com/windows/virtual-pc/download.aspx
Please feel free to contact me with any questions.
Posted on May 04, 2011
Testimonial: "Excellent. This is very helpful. I will now try as you have advised."
Unable to convert into a Word document. It just opens a blank document. What is wrong?
The easiest way to convert a word document to .pdf is to simply right-click on the file to see if there is an option to "convert to .pdf"., then left-click on that option.
Hope this helps. :)
Sep 29, 2010 | ScanSoft PDF Converter Professional...
Tip
Scan multi-paged document and create a single PDF document
1. You need to install a PDF printer driver on your computer first.
There are quite a few freeware PDF writer programs on the Internet you can download one such as CutePDF.
To download CutePDF printer driver (freeware) click on this link :-
http://www.cutepdf.com/
2. Using your computer SCAN the first page then click on File - Save the image as a jpg file Eg. image1.jpg
4. Repeat step 3 for the other pages.
5. Close the scanner when finished scaning.
6. Open a Word document then place each image file on a new page in the Word document
7. Save the Word document if you require but not needed.
8. Click on File - Print then select CutePDF printer (or your PDF printer driver) and save the PDF file. This PDF file will contain the multiple pages of the scanned pages.
on Jul 07, 2011 | Computers & Internet
Using automatic feeder to scan a multiple page doc into 1 PDF
Yes you can scan up to 30 files in one pdf , and you have to put documents in auto feeder (face up) and from the pc, scan menu, scan to files, select destination and extension.
That's all
Mar 04, 2010 | Canon PIXMA MX310 All-In-One Printer
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
Nov 13, 2009 | Konica Minolta bizhub C351 All-In-One...
How can I compile several pdf pages into a single
free convert the pdfs into word by Nemo PDF to word, and then convert them back into one pdf easily.
Oct 08, 2009 | Cosmi Perfect PDF Creator Full Version for...
I cannot scan a document to a single email
file type is probably set to single page. to set the file type to multi page do the following:
1.press the scan button on the op panel
3.select file type
4.select multi page multi page to have the entire scan job sent as a single file.
if you are scanning jpeg as file type they will only scan as single page docs only pdf and tiff can be sent as multi page files
Sep 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Want to scan several pages as one pdf document
Try OCR Terminal,which is an online OCR service that converts scanned images into searchable text. Register an account and you can convert 20 pages for free every month.
Have a try and hope it helps.
Mar 30, 2009 | HP Officejet J6410 All-in-one InkJet...
I need help converting a word document into a fillable form.
You can make use of several softwares like Solid Converter PDF, Adobe Acrobat, Scansoft etc to convert a word document into a fillable form. If you are looking at any specific application please let us know.
May 01, 2008 | ScanSoft PDF Converter Professional...
How to convert jpg to pdf file...
Start your graphics processing software ( for example google picasa or as im demonstrating mircrosoft pait.
2. Open a JPEG picture document
3. Select from main menu "File"->"Print"
4. Select Printer "Virtual PDF Printer"
5. If you need to adjust PDF generation options, click the "Property" button on the right
6. Click "OK"
7. A dialog will pop up, assign the folder and file name of the PDF document to be generated
let me know if this helps
Feb 03, 2008 | ScanSoft PDF Converter Professional...
Adobe Acrobat 7.0 Professional Logo
364 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
