Question about Whirlpool GEW9250 Electric Dryer
Dryer quit in the middle of drying a load. The control panel has power but when you push start it just makes a humming sound. Kind of has a burnt wire smell. I took it apart and can't see where anything looks burnt or melted. Drum spins freely.
    Top Expert:
  • Whirlpool Master
  • 79,851 Answers
Hello
this sounds like the dryer drum motor is burnt out, that would be the humming noise, u can also have a problem with the motor start capacitor, suggest if they sell that separately from the motor you replace that 1st, the purpose of the capacitor is to give the AC motor a large jolt of current to get it going, without the motor start capacitor it can't overcome friction to start, a way to test this is to bypass the door switch and and push the start button, while spinning the drum (obviously u will need a helper here) if the dryer starts spinning the start capacitor may be all that is wrong.
Posted on May 13, 2010
  • 1 more comment
  • klmerrill May 13, 2010
    Can this motor be rebuilt or does it have to be replaced?
    Since it quit in the middle of a load would it not make since that it wouldn't be the ac capacitor?
  • yadayada
    yadayada May 13, 2010
    no we just replace them, the cost to rebuild is more then the new one in most cases, but by all means check into it. U can try this site for a parts price www.repairclinic.com
Control Panel turns off
HI,
The PCB unit ie the control panel circuit board has gone bad. The probable cause of the same is moisture on the board.
Thanks
proton
Oct 21, 2008 | GE DCVH515EFWW Electric Dryer
Whirlpool dryer runs, hums, then quits
Sounds like the motor is on it's last legs. Replace it. But, before paying huge money for a motor and the labor to install it, I suggest that you price a new dryer and compare it to the repair costs. It may still be a little more for a new dryer, but....IT'S NEW!
Mar 20, 2017 | Whirlpool Dryers
When I push the start button the dryer will not start
May need to replace the starter swithch behind the control panel. MAKE SURE ALL POWER IS DISCONNECTED. If you still hear a humming sound when you hit the start button then it is not the switch, but the motor and if that is the case you may want to look into your warranty.
Aug 16, 2009 | Kenmore 63942 Dryer
Whirlpool Calypso dryer GEW9868KL2
It is one or two things. Motor start switch or the motor itself.
Aug 11, 2009 | Whirlpool GEW9868K Electric Dryer
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Dryer clicks when start button pushed but does not start.
A quarter was lodged on the thermal fuse , located below the lint screen on the blower exhaust housing, on our dryer. Remove the front lower panel , 2 screw, and you'll see 2 fuses. I suspect that our control board is burnt.
Aug 05, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
77 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
