Back to:
Tags:
iLO DVDR04
ILO DVR 04 Will Not read
posted by houstonlady on Mar 29, 2008
I have had my IlO for several years. the only writable disk it will take is Maxell. I have gone through several brand of writtable DVDs Does any one else have this problem? Or am I going to have to put all these Cases of DVDss on ebay? I have had this problem of finding compatible disks since the day I brought it home.
Ginger
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 20, 2008
FixYa! (100)
SOPHIA2005
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
make sure disk speed is 8x or less
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on ILO DVR 04 Will Not read:
I don't want to Accept this solution
Solution #2
posted on Apr 05, 2008
Not Rated (0)
ronpar
Rank:Master Master
Rating: 81%, 21 votes
your dvd writer is bad, because there is not enough air in side the box. it over heated, the fan inside is not big enough. you are one of the lucky ones, if yours even lasted a year. i had 4 go bad on me in six mouths returned to walmart and replaced them.open up your box and unplug the strap from the player and the power line from the back of the dvd recorder. if you have a computor the power and strap hook up the same.way. what you need to do, is order a dvd recorder on- line,a 8 speed and 20 speed will not work. it has to be a 16 speed dvd recorder.and a dual layer chould help. i got mine from sams it was a 16 speed LG internal super multi dvd/cd rewriter, but i think all they carry now is a 20 speed.if you get one, i would just leave the old one in ilo. and do a little carving on the back of the ilo caseing to run the strap and power cord through and ontop of the ilo. just sit the new recorder on top of the ilo it may not look good sitting there but it will last a lot longer that way i went through about 200 different brands of dvds before i found out what was wrong with mine good luck i hope you get it fixed. e-mail me if you have any quistens.thanks ronpar
Thank You!
Can you Help with these DVD Players problems?
iLO DVDR04
I've recorded a dvd from a video camera and the dvd will...
iLO DVDR04
my brother gave me this player with no wires, no...
iLO DVDR04
Cannot unlock timer on above unit and it wont let me do...
iLO DVDR04
can not record to any dvd disk above 8x speed. is there...
iLO DVDR04
what is the bast blake dis to use in my ilo dvdr04. i see...
Loading problems.
Repair Service
Find DVD Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
