Question about SkyGolf SkyCaddie SG4 GPS Receiver
Shows 999 instead of yards etc. Can not get any information re; target distance etc. nothing. other than 999.
Which is a good rangefinder for rifle hunting?
The attractive vertical design of the Bushnell G-Force DX is a combination of high technology integrated with some features in demand that is noticed on different Bushnell models also having a 6x magnification that can be utilized both for bowhunting and rifle hunting.
Fully Loaded
Display - The Bushnell G-Force DX is featured with VDT (Vivid Display Technology). Its red screen display has incompatible with the black screen display which is targeted for their budget customers. The settings for the intensity of red display is manually adjustable to one out of four preference settings. These brightness settings aid the user to adjust with the reticle and give a visual record or display of the output from the device of their preference under any condition of lighting.
MOA and MIL - The G-Force DX displays the readings about angle indemnified relics in mil or moa and the holdover in an inch or cm when the Rifle mode is turned on. Users can set the relics to measure in an inch, moa or mil when the ranging requires in yards. Again, users can set the program to show holdover data in Moa, MIL or cm.
Angle Compensated Readings - Some of the older versions of Bushnell rangefinders displayed the view distance in line or dots at the time of Bow or Rifle mode. Next, the device displays the shooting angle and extends the number. When in Bow mode, the G-Force DX provides the compensated angle range in yardage. Otherwise, it gives the relics information when in the Rifle mode. But, the newer version of the Bushnell displays the readings of site distance at first, then it displays the shooting angle beneath the screen for not more than one second and a half before disappearing from the screen. Eventually, the device provides an important information about angle compensation.
ESP 2 - The G-Force DX rangefinder is featured with the second generation extreme speed precision processor offers precise distance measuring advantage and boosted with speed. The device can provide up to 1/2-yard accuracy out to 199 yards and 1/10-yard display precision out of 125 yards.
Housing - The Bushnell G-Force DX is coating rubberized for easy grip with a metal housing. The length of the metal housing is 4 inches, thickness 1.3-inch and height 3-inch which is a compact design of the rangefinders. This dimension of the G-Force DX allowing it to give a relatively low weight of 8oz.
Range - The Bushnell G-Force DX is a vertical-style rangefinder used for long range shooting and the maximum range of the rangefinder is 1300 yards on highly reflective objects. An expected reading on trees under good conditions is up to 900 yards where the same on deer is maximum 600 yards. But, the flat style Bushnell 1600 Elite is the right one for the users requiring more ranging power.
Legend Legacy
The new G-Force DX is developed from Bushnell's previous G-Force 1300 hundred design. Although this model is a new design, it had to leave backward many wanted features of the Bushnell Legend 1200 version. The new Bushnell G-Force DX is a featured with a Bow Mode, Rifle Mode, and Regular Mode same as its forerunner. Another feature is the VSI (Variable Sight-in) that adds versatility in shooting with the rangefinders set with integrated ballistics charts. At last, the popular Brush and Bullseye targets priority settings has added a new dimension into the new G-Force DX.
Modes
Rifle Mode - By selecting the Rifle mode, users can pick a ranging sight that they prefer. After that, they had to select from a ballistic chart that closely matches the flight path of their bullets holdover. Then the rifle icon will appear at the left-top of the screen confirming that the device is in rifle mood. After ranging the target, the line of sight yardage will appear on the display. The device will display underneath the shooting angle which will be disappeared within a second and a half, and at last, it will display a holdover measurement in any unit of cm, inches, MIL, or MOA
Regular Mode - In this mode, the user will get a line or dot of distance view in yardage from the target and it will facilitate the users in no other ways. That means, the indemnified angle in yardage, he relics data or the shooting angle - nothing can be calculated or displayed.
Mar 19, 2018 | Optics
I compete in 3d archery so I bought a new rangefinder 2 days ago and it reads 19.2 yards at exactly 20 yards is there a way to adjust it to read properly?
Page 5 of the manual states: RANGING ACCURACY The ranging accuracy of the Scoutâ„¢1000 is plus or minus one yard / meter under most circumstances. The maximum range of the instrument depends on the reflectivity of the target. The maximum distance for most objects is 650 yards / 594 meters while for highly reflective objects the maximum is 1000 yards / 914 meters. Note: You will get both longer and shorter maximum distances depending on the reflective properties of the particular target and the environmental conditions at the time the distance of an object is being measured. The color, surface finish, size and shape of the target all affect reflectivity and range. The brighter the color, the longer the range. White is highly reflective, for example, and allows longer ranges than the color black, which is the least reflective color. A shiny finish provides more range than a dull one. A small target is more difficult to range than a larger target. The angle to the target also has an effect. Shooting to a target at a 90 degree angle (where the target surface is perpendicular to the flight path of the emitted energy pulses) provides good range while a steep angle on the other hand, provides limited ranging. In addition, lighting conditions (e.g. the amount of sunlight) will affect the ranging capabilities of the unit. The less light (e.g. overcast skies) the farther the unit's maximum range will be. Conversely, very sunny days will decrease the unit's maximum range.
The difference you are experiencing (20-19.2=.8 yards) is within the device ranging accuracy of 1 yard, and is in fact an error of only 4%. That is pretty accurate
In case you have lost your manual, you can download from here:
http://bushnell.com/getmedia/1761b4a2-f4d9-45f7-b1d3-1e400fead84a/REVISE-20-1932-20-19426LIM.pdf?ext=.pdf
Good luck with your device.
Jun 05, 2015 | Bushnell SCOUT 1000 Rangefinder
What are the marks below the crosshairs
They are used to indicate elevation needed to hit your target at various ranges. The distances should be indicated in your owner's manual. For instance, if calibrated for .223 remington, and sighted in at 100 yards, the first might be 200 yards, the 2nd 300 yards, etc.
Dec 01, 2013 | NcStar 3-12x50e Rifle Scope Illuminated...
Son just bought me a Bushnell Banner Dusk&Dawn 4 Plex, Mil-dot, 3-9x50E. Just looking for an explanation on all the marking on the reticle (inside of the scope) I understand the cross hairs and how to...
Simply put, the Mil-Dot is a way to estimate range with the scopes reticle. This type of reticle was developed for military applications. The space between the dot centers is equal to one milliradian (Mil). hence the name mil-dot. One Mil equals 3.6" inches at 100 yards, or 36" at 1,000 yards. To use this system effectively you must know the size of the target. For instance most people are an average of 6 feet tall or 2 yards. The formula used for determining range to the target is (size of target x 1000 divided by number of mils the target covers). Hope this helps FixYa up.
Aug 28, 2011 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Accurate adjustment of open sights
each notch should move your point of impact back on target for each 25 yards you add to the distance at which you are shooting
Jul 11, 2009 | Sport & Outdoor - Others
Bushnell 1500 Tournament edition No Reading
Bumps and bruises add up.....sounds like its out of alignment. Make sure it is not reading in meters "M'"instead yards:"Y" then, if it will hit a target only at about 150-200 yards....it needs an alignment.
About 50 bucks for align, 15 bucks for LCD if you have those oily looking swiggles. ( or black, brown etc). All other general maintenace is 15. Shipping and handling cost 10.
MTG
rate!
Jun 24, 2009 | Bushnell Pinseeker 1500 Rangefinder
Incorrect distance
Bushnell doesn't work on those anymore, but they still have the manual for them. Make sure when you hit a target you don't see a "M" next to it. This means it's reading in meters instead of yards. Hold down the "mode button" until you see "Y" (yards) if this is the case. If not, the unit will need an alignment and bushnell doesn't do them anymore. They will offer you a newer model. The Pinseeker technology is good......They have three models to choose from.
Good Luck!!!!
mtg
Jun 09, 2009 | Bushnell Yardage Pro 500 Rangefinder
Windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
May 02, 2009 | Optics
Tasco 6-24x42mm rifle scope parallax adjustment
Here's what you need to know about Mil Dots and rangefinding.
When you look through the scope you should see 5 mil dots on each axis, your scope may have broad lines taking place of the 5th mil dot if it is a "modified" mil dot scope. For measuring purposes, 1 mil is the distance from the center of one dot to the center of the one directly above or below it. 3/4 of a mil is the distance from the top of one dot to the bottom of the one above it, or the "space in between dots". 1/4 mil comprises a single dot, the space between the top of one dot and the bottom of that same dot.
A quick calculation is Size of Target (In Yards) x 1000 / Size of target in mils = Range in Yards
Miliradian or "Mil" is an angular unit of measure, so if you were shooting at 1000 yards and moved up 1 miliradian that would be one inch impact moved up.
Anyway lets say you have a 30" target and we need to find the range... using your scope you place the bottom of the target at the CENTER of a mil dot and count how many mils up, good estimation is key... I'll draw a little text diagram, an asterisk * will be the target top and bottom, and parentheses () will be a mill dot
Now lets assume the asterisk on the left is the bottom of your target and the one on the right is the top, I put Ten Hyphens in between each dot so if you count from the left you should get about 1.6 Mils. Its real easy to do it in your head, you already know two whole dots is one mil so you just have to estimate whats to the right (or top if you were looking down a scope).
So we know the target is 30" and we have a Mil Reading of 1.6
30/36= .833 so 30" is .833 Yards
So now we can use the equation .833 x 1000 / 1.6 = 520.6 Yards is the distance of the target
Now you can also use Mil dots to do hold over for when the target moves or for wind and elevation but that gets extremely complicated.
Parallax in Rifle Scopes is explained here
http://www.6mmbr.com/parallax.html
There are many books and websites to confirm what I've said here, but the best way is to go out to your range and talk to some long range shooters and show them your rifle/scope etc and get hands on help.
Mar 16, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Incorrect distance or Calabrated wrong
Sounds like the unit is reading in meters instead of yards....Hold down the mode button on the side for about 5 seconds. It should switch modes.
Jan 12, 2009 | Bushnell Tour V2 Pinseeker Laser...
SkyGolf SkyCaddie SG4 GPS Receiver Logo
50 people viewed this question
Top SkyGolf GPS Experts
Oloyede Monsuru
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
