Question about 3ware Electronics - Others
I have an old computer running windows millenium. I used to be able to access my flash drive but now a message pops up that says that i need to format my flash drive. I format the flash drive and try to access it but another message pops up that says please insert a removable disk.
  • 493 Answers
Would you try to format your flash drive using this software which I uploaded HERE. Download and unzip the file. Then run the exe file.
Do the followings:
- First plug in your micro-sd card into you PC using USB cable.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your flash drive).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
- Then restart your computer to recognize your flash drive. Or from control panel, go to Add devices menu and search your flash drive to find and add.
Hope this helps.
Posted on May 13, 2010
How to Make a Flash Drive Work in Old Windows Systems?
follow this steps
  1. Insert the flash drive into the computer. The "Found New Hardware" Wizard should appear promptly.
  1. Click "Next". No need to select a different option.
  2. After scanning the computer for the flash drive's drivers, it should say that they were not found. Next to that message, it should display the names of the missing drivers. (Drivers are files that let hardware interact with the software.)
  3. Take out the flash drive and memorize or write down the missing drivers' names. It is necessary you know what to find on another computer. The most common drivers for simple flash drives are: usbstor.sys, disk.sys, and partmgr.sys.
  4. Go to another (preferably more advanced) computer and go to "C:\Windows\system32\drivers" and locate the needed drivers. If the computer runs on a 64 bit OS, go to C:\Windows\SysWOW64\drivers. All the computer's drivers are there.
  5. Copy them to a CD, email them, or find any other means of transferring the drivers to the older computer. Then copy them to an easily accessible folder. We'll use C:\My Documents\Drivers.
  6. Reconnect your flash drive. Again, the wizard will appear.
  7. Choose "Install from a list or specific location", then click "Next".
  8. It will ask for the location of the driver. Simply do what it says. (C:\My Documents\Drivers.)
  9. The flash drive should be functioning now. If not, go to your flash drive manufacturer's website for more information or try to find the drivers online.
Oct 20, 2016 | Computers & Internet
I need help in accessing the memory of my 32GB flash drive to transfer files into it or to retrieve files.
Depending on the computer you have but it should be the same
first insert the flash drive in to the usb port
a window will pop up that say open to view or transfer photos or use as space to speed up your computer you can choose which ever you find that you need. now when you are working on any project and are finished go to the top left corner and click save as and then click on the drive the flash is plugged in to name it and save. It will be saved on the flash drive now when you want to get something form the flash drive click on the drive and choose hope this helps.
Jun 30, 2012 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
Trying to use an old computer using Windows 95 as a storage device for photos. When inserting photo disc into drive the following message pops up: D: forward slash is not accessible. The device is not...
Well, the "D:/" means your cd drive isn't reading or recognising your photo cd's. It's possible that if you've a very elderly computer, that the cd drive is also pretty ancient and can't handle writeable or rewriteable cd's ..only commercially produced ones. This is quite common with old cd drives. Hope this helps you understand the message, though no help in resolving it! Regards, Nicam49
May 07, 2011 | Computers & Internet
I always have a problem to download the yahoo messenger because my compute are to old what i have to do
If that will be the case, the best suggestion is for you to use a flash drive.
The flash drive is a small removable gadget that you may use to store files in it. It acts as a memory card that you can attached to any computer you like and save files to it.
Go on any computer shop or use any of your friend's computer and download the yahoo messenger on the flash drive. After that insert the flash drive to any usb socket on your computer and start accessing it. The removable flash drive usually prompt on your windows as drive (F:) removable device. Double click the yahoo messenger installer file to start installing.
Jul 23, 2010 | Yahoo Messenger
I want to install xp on the slave HD but i cant...
DFI is the board manufacturer. They may or may not offer support since this is a really old board by computer standards. Hope this helps.
Mar 04, 2009 | DFI CA61 Motherboard
I have a Dell system with microsoft windows XP. The last 2 days I have gotten a message that a file is corrupt and unreadable and to run a chkdsk utility. I have tried to on two fronts but it refuses to...
use this one:
chkdsk /r
box will come up saying your drive is locked.
Type "Y" for yes. press enter.
Restart the computer and let the disk check process run.
Pay attention towards the end you'll get a two second flash telling you if there were any problems, etc.
Let me know what happens.
Mar 02, 2009 | Microsoft Windows XP Professional for PC
How do I use USB 2 Flash Drive -EZCool
If you running xp or vista
Plug drive into usb, it will be recognised in one minute or so.
Probably a window will pop up asking you what to do , in this case chose open folder to view file.
To access the drive at any time you can go to my computer, it will be listed as an additional drive called 'removable drive' or with the name given by factory.
If you are using windows 98 or ME you will need to run disk first
Apr 22, 2008 | Computers & Internet
Error - Kernel32.dll
Microsoft defines Kernel32 errors as follows: "The Kernel32.dll file is a 32-bit dynamic link library file that is found in Windows 95, Windows 98, or Windows Millenium Edition (Me). The Kernel32.dll file handles memory management, input/output operations, and interrupts. When you start Windows, Kernel32.dll is loaded into a protected memory space so that other programs do not take over that memory space. On occasion, you may receive an invalid page fault (IPF) error message. This error message occurs when a program tries to access the Kernel32.dll protected memory space. Occasionally, the error message is caused by one particular program, and other times the error message is provoked by multiple files and programs."
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Electronics - Others Logo
67 people viewed this question
Top 3ware Electronics - Others Experts
Are you a 3ware Electronics - Other Expert? Answer questions, earn points and help others
