Question about Asrock K7S41GX Motherboard
I just installed an Asrock K7S41GX motherboard in my HP computer and it won't recognize USB keyboard and mouse or boot up. Any ideas?
  • 147 Answers
Try temporarily connecting a standard keyboard. If it now boots up o.k., the OS should write the prescence of the wireless device to BIOS and you should be able to boot up with your wireless devices only.
Posted on May 13, 2010
Can you elaborate the functions of this product....
NOTE*
The following applies to motherboards such as an AsRock K7S41GX.
It does NOT apply to motherboards supporting the Intel Core i3, i5, i7, and i9 processors.
1) Motherboard diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
A) CPU = Central Processing Unit. Another term is Microprocessor, or Processor for short.
The 'Brain' of the computer.
B) Front Side Bus. Also abbreviated as FSB.
The FSB is the 'Information Highway' between the Processor, and the Northbridge chip.
[Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit ]
C) The motherboard chipset is the Northbridge chip, and the Southbridge chip.
The Northbridge chip handles the faster capabilities of the computer.
It is named NORTHbridge, because on the orientation of the motherboard, it is to the North of the motherboard.
The Southbridge chip handles the slower capabilities of the computer.
D) The Northbridge handles the Processor, Ram Memory, and HIGH-speed graphics.
AGP and PCI Express are high speed graphic technologies.
A graphics card used in a PCI expansion slot, and Integrated Graphics are NOT high speed graphics.
E) The Southbridge handles Integrated Graphics, (OnBoard graphics. Same/same), and the PCI bus.
A graphics card inserted into a PCI expansion slot is one example of Southbridge support.
Any add-in card inserted into a PCI expansion slot, is in the PCI bus.
Therefore handled by the Southbridge chip.
The Southbridge chip also handles IDE (PATA), and SATA harddrives.
Handles USB ports, Ethernet port/s, audio, and the CMOS memory.
F) The Internal Bus is the 'Information Highway' between the Northbridge chip, and the Southbridge chip.
G) The LPC Bus is the 'Information Highway' between the Southbridge chip, and the Super I/O chipset.
The LPC Bus is also the 'Information Highway' between the Southbridge chip, and the BIOS chipset.
H) The Super I/O chipset handles,
Serial port
Parallel port
Floppy Disk Drive
Keyboard
Mouse
2) http://www.asrock.com/mb/overview.asp?Model=K7S41GX
The AsRock K7S41GX has;
A) Socket A processor socket. Also known as Socket 462
http://en.wikipedia.org/wiki/Socket_A
Can use AMD processors that fit in a Socket A processor socket, and have either a 200MegaHertz, 266MHz, or 333MHz FSB.
Here is the CPU Support List,
http://www.asrock.com/mb/cpu.asp?Model=K7S41GX
Supports DDR Sdram ram memory at either 266MHz, or 333MHz.
PC2100 and PC2700, respectively.
Maximum TOTAL Amount of Ram Memory is 2GB
Maximum Amount for EACH ram memory slot is 1GB.
There are two ram memory slots.
Has an AGP (Accelerated Graphics Port) graphics expansion slot, that supports AGP 4X , or AGP 8X graphics cards. (1.5 Volt)
Has two PCI expansion slots
Supports IDE (PATA) harddrive/s. (2 maximum)
Supports IDE optical drives. (CD or DVD, or burners for both)
The motherboard chipset is a SiS 741GX - Northbridge, and the SiS 963L - Southbridge
http://en.wikipedia.org/wiki/Silicon_Integrated_Systems
Regards,
joecoolvette
Dec 01, 2010 | Asrock K7S41GX Motherboard
My keyboard, mouse and USB ports do not function at Startup any more. The keyboard and mouse function perfectly on other machines. The motherboard is ASRock P4i45GV (5.0), with a Celeron. I've used the...
Are the mouse and Keyboard USB varieties? If so, then try plugging in a PS/2 mouse and keyboard and boot the machine up. You can then check your system hardware settings in control panel and reinstall the USB drivers. This would be my first step in solving the problem. If you need any more help then just ask
Nov 11, 2009 | Asrock P4I45GV R5 Motherboard
USB keyboard and mouse not working on startup. Dualboot with xp and vista.
The usb ports might me malfunctioning . Try to use different ports. If that doesnt solve it then there might be a power issue on the board.
Apr 26, 2009 | Abit IC7-MAX3 Motherboard
Windows freezes when shutting down
If you can download the lastest bios for that PC from the internet that should fix your problem if that does fix issue reinstalling windows or does Xp restore from cds will
Mar 18, 2009 | Asrock K7S41GX Motherboard
Asrock K7S41/K7S41GX problem
2 x DDR DIMM slots
- Supports DDR400/333 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
3 beeps is usually either video card related, or memory. be sure your memory is UN buffered, and DDR400 or 333 DIMM not DRam.
Remove and re-seat your video card as well.
there should be a troubleshooting guide in your install manual stating the designation of 3 beeps.
Dec 22, 2008 | Asrock P4VM890 Motherboard
How to disable internal vga on asrock K7S41GX?
GO INTO THE BIOS AT BOOT AND DISABLE/TURN OFF ONBOARD VIDEO .
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
Dec 14, 2008 | Asrock K7S41GX Motherboard
USB ports all seem troublesome
You cannot use wireless keyboard or USB keyboard in setting up the computer BIOS, what you need is a PS2 keyboard, if your motherboard supported USB booting, in Boot section of your BIOS change the Boot Priority to USB Generic Device, after you change the boot priority change the First Boot to Removable Device or USB Generic Device.. and after that save your configuration and restart the computer.. you must put the USB stick first before you configure the BIOS.. TY
HOPE I CAN HELP
Dec 05, 2008 | HP Pavilion (PN153AAR) PC Desktop
Vga problem
There is a problem with your VGA internaly, try to buy a VGA card to replace it. And your mouse not might work beacuse of your BIOS
(Basic Input Output System).
Mar 07, 2008 | Asrock K7S41GX Motherboard
Graphics card
Any idea what the wattage of your power supply is?
Jan 15, 2008 | Asrock K7S41GX Motherboard
Asrock K7S41GX Motherboard Logo
303 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
