Question about Vacuums
No detailed Repair Kit instructions for Edwards E2M5 vacuum pump
Repair Kit for Edwards E2M5 vacuum pump does not give detailed instructions to ''overhaul'' pump. (http://www.capvac.com/store/item.aspx?departmentid=210&ItemId=86) Brief and useless instructions were... ''replace numbered parts from kit using exploded diagram view.'' No details of clearance, fastener torque, alignment, etc. I was unable to locate detailed overhaul instructions using Google, ASK or BING. Will go ahead in next few days with repair. If repair fails, will return for costly over-haul.
  • 112 Answers
SOURCE: fan kit kirby g4 vacuum cleaner
I'm assuming you mean the fan impeller and not the fan that cools the motor...
you can find detailed instructions at this site
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
hope this helps!
Posted on Jan 14, 2008
reddevil6
  • 1673 Answers
SOURCE: VACUUM REPAIR
There are 2 tabs that stick out on the release, they fit in slots, so from the top look down and you can see them, using a flatblade screwdriver that will fit in there, push the side in to release it, which isn't easy, but it can be done. When you get the old one out, then the new one, push down on it until it locks into place.
Posted on Mar 06, 2008
  • 430 Answers
SOURCE: I need a wiring diagram & detailed
Open the vac by removing 3 screws below the handle area and the long screw at the bottom of the cone. If the motor has been removed, you will have 2 motor leads , 2 power head socket leads, and 2 switch leads as well as the cord. Do not twist your wires first when pairing, twist with the wire nut ony and tape afterword as there is metal nearby in the housing area
1 side of the cord goes to the switch only. The opposite side of the switch will go to 1 of each of the motor and Socket. The remaining motor and socket leads pair with the remaining cord lead.
While you are in there change the round filter dic covering the front of the motor and you could change the foam/ felt wrap around the inside of the housing.
There is a insulating disc at the top of the motor to prevent shock between motor and screen. Do not remove it.
Posted on Sep 08, 2009
  • 18 Answers
SOURCE: Dirt Devil Repair
You can use eReplacementParts.com for the detailed diagram or exploded view of that vacuum. You will also find a full parts list, and possibly repair videos to help you out. - Dirt Devil Parts and Diagrams
Posted on Jun 02, 2010
SOURCE: replacement parts
need a charger
Posted on Sep 21, 2010
Where can I get step-by-step instruction for rewiring?
Call our technical support team when you are able. We do not have enough information to give detailed instructions.
Contact Us
RainVac
Nov 04, 2015 | Rainbow E series Canister Wet/Dry Vacuum
My hoover steam vac spin doesnt pump solution
it's probably the pump motor seized and needs oiling this video will give you instructions..
Nov 23, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Won't **** up water
please go to :http://hoover.com/support/video-instruction-guides/
see the instructional videos, and proceed with commmon sense for torubleshooting.
You must clean the tank , maybe is full and need emptied, or blockage.repair. or pump-motor.
God bless you
Jul 15, 2012 | Hoover F5906-900 Upright Steam Vacuum
Bissell pro heat brush is not spinning. the belt is on and spinning but brush is not moving
There are two belts a brush belt and a pump belt. For a kit with installation instructions contact
BISSELL Consumer Services at
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Apr 19, 2011 | Bissell Vacuums
Is it possible to download a manual as I have the machine second hand with no instructions.
We'll try. Please give the detail of your vacuum .
Regards
Mar 07, 2011 | Vacuums
When you start it, it will turn and go backwards but will not move forward, will do this for about 30 seconds then shuts down and gives one beep.
Your bump sensors are malfunctioning. I had the same problem. The best thing to do is order a repair kit. I ordered mine from EESolutions.ca and it worked great. I'd recommend....
Nov 14, 2010 | iRobot Roomba 530 Robotic Vacuum
I robot rumba- does not go forward, keeps backing up and turning
sounds like one of the cliff sensors has gone bad. I think your options are to send it in for repair or buy a replacement sensor and swap it in.
Good luck, immorion check out robotreviews.com for detailed walk through and a great community
Jul 14, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba going in circles
Roomba going in circles. Called irobot and if reseting it (by taking out the battery, unplugging it from the charger, and holding down the power button for 30 seconds), didn't work, turn the roomba over, take a compressor and blow air into the front. Maybe a shop vac would also work. We cleaned out the whole thing while we were at it. And now it works just fine. The tech person at irobot was very helpful.
Mar 14, 2010 | iRobot 530 Roomba Vacuuming Robot, White...
Fan kit kirby g4 vacuum cleaner
hope this helps!
Jan 13, 2008 | Kirby G4 Bagged Upright Vacuum
Loud noise with vibration
make sure there is nothing stuck in the roller brush. Or wrapped around the driveshaft (finger like thing sticking out of the front of the kirby when the powerhead is removed)
Jan 04, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
116 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
