Question about Xantrex Technology Xantrex Xpower PowerPack 300 EP (XPOWERPK300EP) 300-Watt Power Supply
Charging Why Does the Power supply Make a clicking noise while its charging?Does the power switch have to be on while charging?
2 Suggested Answers
willinois
  • 77 Answers
SOURCE: power pack 300 keeps clicking and led light
It sounds like the battery is past it's useful life. Is there any possibility that the unit was activated during a charging cycle? This can damage the battery beyond warranty.
Posted on Jan 12, 2011
How to charge
• IMPORTANT: This unit is delivered partially charged.
Plug into an extension cord FOR 40
hours before using.
You cannot overcharge the unit using the AC charging method.
• To recharge this unit, use only the supplied AC charging adapter.
• All ON/OFF switches should be in the OFF position when the unit is charging or not in use. Make sure all switches are in the OFF position before charging. Here is the instruction book:
http://ecx.images-amazon.com/images/I/81US%2Bom6xKS.pdf
here is the booklet.
Jul 21, 2014 | Stanley Tools 500W Portable Power Station"
Laptop will not charge
Step 1:
Windows 7 Laptop Battery not charging b> Careful management of battery charging and power consumption settings on your laptop computer is essential if you spend a lot of time away from home or the office. To stop your Microsoft Windows 7 laptop from running out of juice at a critical moment, you can change the battery and power settings for the device. Select the battery meter icon from the desktop toolbar to change the laptop's power plan.
Click the battery meter icon in the notification area on the right-hand side of the computer's desktop taskbar. This launches the battery and power plan options dialog box. Find the battery status display at the top of the dialog box. This shows the remaining charge in the laptop battery, and indicates if the battery is currently plugged into a power supply and charging. Click the check-box beside the power plan option that best matches your current activities. Select "High Performance" if the laptop is connected to an external power supply and the battery is charging. Choose "Balanced" if you don't need to save power and you want Windows 7 to optimize the laptop's power settings. Select "Power Saver" if you need to run the laptop on only battery power for as long as possible. Click anywhere on the desktop screen to exit the battery and power plan options dialog box.
Feb 06, 2013 | Samsung RF511 15.6 inch Laptop - Black...
Errore000064 occured
Power supply voltage error (high-voltage error)
The presence of a high-voltage error is communicated by the composite
power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause: The contact has poor connection. The wiring is faulty. The composite power
supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly,
or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller,
developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Jan 19, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Power supply problems
the problem is from the motherboard. One problem with toshiba laptop, is that they overheat too much.
Check if the fan of your laptop is working and make sure you keep your laptop where there is ventilation, so that air can enter into the laptop.
You could also open up the laptop, clean every dust on the motherboard and also the fan and cooler.
That's the area you should concentrate your attention on and not the battery or AC adapter.
Take care.
May 28, 2010 | Toshiba Satellite A75-S226 Notebook
How to charge ups for pc's
Your PC connection must always come via UPS, and your UPS will always keep charging.
UPS Power cable should be connected to DC, and your PC power cable should be connected to UPS.
And this way your PC will always be safe.
Nov 06, 2009 | QVS NetStar (UPS650A) UPS System
LG DU-37LZ30
probably a power supply problem,modern tvs use switching power supplies. these power supplies sometimes fail after a long period of use due to the constant charging and discharging of the capacitors
Jun 07, 2009 | Sony QUALIA 005 46 in. LCD Television
Twinhead Efio 121i dead
It is problem with your laptop's SMPS ie. Switched Mode Power Supply.
Due to which your laptop can't get regulated power supply neither from Power Cord nor from Battery.
Yes, your LED will show charging but its useless because your laptop's Mother Board Chip is not getting power.
So please ask some hardware engineer to replace it.
Rate this solution if it was helpful to you.
With Regards,
Shyny
May 29, 2009 | Twinhead SlimNote N12PI Notebook PC
How to clear E000064 problem in ir3300 model
E064
0000 The presence of a high-voltage error is communicated by the composite
Main cause The contact has poor connection. The wiring is faulty. The composite power
Action
1. Contact
2. Wiring
YES: Yes.
Feb 26, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
2. Wiring
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
YES: Yes.
Feb 24, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Regarding battery problem/battery not charging
Hi Jasbir, Laptop batteries only have a set life span and if your battery does not hold charge the only solution is topurchase another battery. You will find the cheapest way to do this is to search the computer section of ebay [laptop assessories ]
and find the battery for your laptop model.
Regards mistyman
Nov 16, 2007 | Computers & Internet
Xantrex Technology Xantrex Xpower PowerPack 300 EP (XPOWERPK300EP) 300-Watt Power Supply Logo
881 people viewed this question
Top Xantrex Technology Computers & Internet Experts
steve morris
steve morris
Rick Moore
Rick Moore
Are you a Xantrex Technology Computer and Internet Expert? Answer questions, earn points and help others
