Question about Dryers
My roper dryer is not heating. - Dryers
  • 5,911 Answers
Is this a GAS Dryer? Or, an ELECTRIC Dryer?
If this is an ELECTRIC dryer, and your dryer runs, but does NOT heat, you more than likely have a problem in the heating circuits. Any one of the following could be causing your problem:
1. Heating Element
2. Thermal Cut-Out (TCO)
3. Hi-Limit Thermostat
4. Improper input line voltage
5. Defective power cord. The following link explains how to troubleshoot and diagnose a no heat problem on an electric dryer:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
If this is a GAS dryer, the most common failure for heat related problems is a weak or blown igniter on the burner assembly.
It can take roughly 30 to 90 seconds from the time you start the dryer to the time it takes for the gas to ignite. If you are expriencing longer ignition times, the igniter probably needs to be replaced.
NOTE: This is a designed safety feature of the appliance that prevents free flowing gas from accumulating in your home without ignition. That's why you typically don't hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
You can purchase replacement parts (if required) at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer some excellent exploded view diagrams of the appliance to assist you in locating and properly identifying the parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this can help you. NOTE: Repairclinic.com has a repair manual that you can purchase that will help repair any Whirlpool manufactured gas or electric dryer (such as Roper). The part number is 1159257.
Posted on May 13, 2010
  • 163 Answers
SOURCE: My Roper Electric Dryer will not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
  • 360 Answers
SOURCE: Roper Dryer will not heat
I don't have a picture of the rear panel available, but if you have to remove the exhaust duct to remove the panel, I would be checking to ensure the exhaust ducting is not clogged/restricted. The duct does not have to be completely blocked to cause the dryer not to heat properly.
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Mar 19, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a Roper Dryer Model REX3514PQO. The dryer
Sounds like you have a broken drum belt.
If you have to replace your drive belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the belt is not broken, then I would check to see if the timer switch is working properly, if not then you may need to replace it.
Good luck,
I hope this helps
Posted on Oct 06, 2009
SOURCE: Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Posted on Feb 07, 2010
  • 534 Answers
SOURCE: My roper dryer REX6634pq0 does not heat!!
there is a thermal overload switch that activates the heating element. This switch will be located in the area of the element itself. It is designed to shut off the element in the event the element itself reaches a temp beyond it's designed temp. It is a safety device. If the switch is out it will not allow the heating element to activate. This switch looks like a silver button and has several wires going to it is about the size of a dime. Replace this switch and you should be good to go
Dave
Posted on Mar 17, 2010
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
I have a roper dryer and there is no heat. I changed the heating element and I still have no heat.
thermal fuse, for test purposes only (DISCONNECT POWER) tape the two wire together run dryer it will heat, then order the correct fuses and replace them before operating dryer;
http://www.applianceaid.com/thermo.html
Feb 16, 2011 | Roper Dryers
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer gets hot and turns but the heat is
remove the front cover of the unit and make sure the dryer wheel is hooked and turning,while in there check for any pipe ductwork thats disconnected
Feb 27, 2010 | Roper RES7646KQ Electric Dryer
Jan 11, 2010 | Dryers
Roper gas dryer does not heat.
If the ignitor is not powering , go to the switch. That has to send power to the ignitor, then on to the gas valve.
Jul 22, 2009 | Roper RGX4634KQ Gas Dryer
Dryer won'y heat up
you either have a bad heating element or your limit switches are out..it could be either or both they are what control the heat
Jan 27, 2009 | Roper REX3614KW Electric Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
My roper electryc dryer will not heat I just inheirited a Roper dryer and it won't heat. I don't have a manual and know nothing about where to look for the breaker or heat switch. Can anyone help? Thanks!
I have a roper and I will bet its your heating element. Pry the top up with a screwdriver (pops up) and you will see the element on the back of the dryer. Take it out and it will have a break in it.
Oct 24, 2008 | Dryers
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
159 people viewed this question
Top Dryers Experts
