Question about Reebok 8050 ES Treadmill
Can a treadmill not work because the shed its housed in is too cold ?
    President:
  • Reebok Master
  • 832 Answers
If in a shed I would unplug unit remove motor shroud inspect the motor compartment for moisture or rodent by products causing corrosion or burning any components on the motor control board then replace the board. Check all connections leading to the board. Use a multi meter to see if you are getting AC to the unit if you are but do not get any DC readings on cable ribbon leading to upper electronic console usually 5vdc then replace the lower board.
Posted on May 14, 2010
Testimonial: "thanx for this helpful feedback"
I have an E 01 code on a Bentley treadmill can anyone shed some light as to what the problem is?
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 28, 2016 | Exercise & Fitness
Console working but treadmill not moving
Same thing happens to my treadmill a few times a year, and this is how I got mine working again. I went outside to my main electricity breaker box and reset all the switches. Turn them off then on again. And then did the same thing to my small breaker that's on the wall in my house. Walla...It's working back to normal again!
Oct 07, 2015 | Nordic Track T9.1 Treadmill Walking Deck...
Kenmore 13 (1989) model 253.9103221 has been unplugged and safely stored flat in an non-climatized shed for seven years. I plugged it in outside in the carport, night temps getting in the high 30s low 40s....
Moving it inside will most likely fix the problem. The thermostat is often located in the frige side, so it's basicly too cold outside for the unit to run right.
Oct 26, 2013 | Whirlpool Refrigerators
Healthrider s300i treadmill does not turn on
Check the fuses under the lower hood. One should be a 10 amp fues, the other should be 15 amp fuse.
Replace them if blown. If they should blow again, move the treadmil to an outlet closer to the fuse box/breaker box of the house. the house wiring where you have the treadmill may not be adequate for the treadmill.
Jan 24, 2012 | HEALTHRIDER Exercise & Fitness
The belt on my proform 680LT has an excessive amount of rubber powder rubbing/shedding off. It makes a mess.
Is it rubbing off the sides of the belt? If so, adjust the lateral movement of the belt with the hex bolts at the base of the treadmill. If not, you may need a new belt. See Treadmill Parts
May 03, 2011 | Proform 680 LT Treadmill
ProForm 530x Treadmill runs, but stops when I get on to walk/run
Unplug the unit and pull the motor shroud off and check the compartment it like sound you have dirt and corrosion . If you have a multi meter I'd start checking from the outlet and work my way to the lower board to see if I have power, Your question about the motor casing the problem fine the 2 leads that come form the motor and goes to the board pull them off (after unplugging the unit) and stick the leads into the motor connectors put meter on dcv and have somebody get on the treadmill and with one foot start pushing the belt . You should see dcv being generated for the if that the case then the motor by all rights should be good I would suspect that lower board. Hope this sheds a little light on the problem. Good Luck!!
Apr 10, 2010 | Exercise & Fitness
My nordic track treadmill won't decline
My wife had the same problem with her treadmill. I turned the beast on it's side, and unscrewed the plastic casing that houses the motor, computer, and all the electronics to the treadmill. I unplugged the incline/decline motor. Then on the bottom of the treadmill the long threaded rod that causes the incline needed to be moved. So I unbolted it from the catch, and manually screwed the rod back in with a wrench. Now the treadmill works fantastically, of course the incline/decline mechanism has been disabled, but I would rather have a treadmill with the incline disabled than have one always on 100% incline. Hope you found this helpful :)
Jan 05, 2010 | NordicTrack Exercise & Fitness
Can the tv be left in cold weather
The issue is not so much the temperature, but the moisture present in the air. When these sets are manufactured and transported all over the country, they sometimes are in freezing temperatures without problems. Taking a set from a cold environmetn (shed for example) and bringing it into a warm house would not be good. The cold TV would "sweat" as the humidity in the air condensed on the boards and components. This could cause potential problems. In short, as long as you give the set time to acclimate to the room, it should be fine.
Dan
Oct 19, 2009 | Apex Digital AT2002S 20" TV
Reebok 8050 ES Treadmill Logo
173 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
