Question about Xerox WorkCentre 4118 Network Kit - 1 x 10/100Base-TX - 100Mbps (0095205226850) Print Server
Xerox workcentre 4118 paper jam
There is a jam in the machine that cannot be seen. We have removed everything possible from the machine to check the affected area just below the scanner bed and there is nothing there. We are starting to be suspicious that some small peice of hardware must be broken. What needs to be done.
4 Suggested Answers
  • 39 Answers
SOURCE: Paper size Mismatch on Xerox
HI wat you can do is Most likely the tray setting has changed, Here is what to check. Press the [ Machine Status] button on the Control Panel..
Posted on Jan 10, 2011
graemevm
  • 519 Answers
SOURCE: drivers installation
Here is the web page with your Xerox printer drivers and software:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=WC4118&Xlang=en_US&Xcntry=USA
Regards,
Graemevm
Posted on Apr 28, 2009
  • 2072 Answers
SOURCE: Paper size Mismatch on Xerox workcentre 4118
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until the required tray is displayed, and then press the [Enter] button.
  4. Press the [Left] or [Right] arrow button until the required paper size is displayed, and then press the [Enter] button.
  5. Press the [Stop] button to return to the Standby mode
I am sure you will find one of the tray settings to be incorrect.
If not, click on the printers on your computer, Right click the 4118 and look in the printer properties. One of those settings may be off.
More likely is that the machine settings have changed for whatever reason.
Posted on Jul 09, 2010
How to solve mismatch paper size on xerox 4118
Set the paper size correctly.
http://www.fixya.com/support/t5246564-paper_size_mismatch_xerox_workcentre Paper size Mismatch on Xerox workcentre 4118 cant print
Mar 06, 2016 | Xerox Office Equipment & Supplies
Changed drum on workcentre 4118, and still says change drum
TURN ON MACHINE. PRESS MACHINE STATUS; PRESS ADMINISTRATIONS TOLS;PRESS ARROW HIGHT UNTIL APPEAR M ANUTENCE; PRESS OK; PRESS ARROW HIGHT UNTIL APPEAR "NEW DRUM". PRESS YES.
PRESS OK. THATS IT.
TURN OFF THE MACHINE; WAIT FOR 30 SECONDS; TURN ON.
Feb 12, 2013 | Xerox WorkCentre 4118 Network Kit...
I need need a picture on how to remove a paper jam in xerox 4118 machine right now please
Well open the printer where you can(the closest point to the jammed paper) attempt to remove the jam by attempting to pull the Jamed paper in the direction it would normally exit the machine.thats about as far as I can get you with the information I have--Good Luck.
Feb 01, 2013 | Xerox WorkCentre 4118 Network Kit - 1 x...
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
GOD BLESS YOU
Oct 20, 2012 | Xerox WorkCentre 5765 5775 5790 Fuser...
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
Jan 10, 2011 | Xerox WorkCentre 4118 Network Kit...
My Xerox Workcentre copier gives an error message E2 paper jam and I have cleared every possible jam. The copier still thinks its jammed and won't start up now.
I just had this same issue with my phaser3300MFP. Initially I thought this was a software issue but after careful inspection, there indeed was still a jam. I would check the fuser area of the machine. There is most likely a page jammed in that area and they can be hard to see.
Nov 10, 2010 | Xerox WorkCentre XD155DF Laser Printer
Paper size Mismatch on Xerox workcentre 4118 i cant print
Jul 07, 2010 | Xerox WorkCentre 4118 Network Kit...
Xc 1040 xerox Red light is flashing and the copier will not
On a XC 1040 machine either there is a jam on the fuser, the fuser switch fell out of place, or the sensor swich arm fell off the registration sensor.
Since we cannot see the machine we might understand what is taking place.
If the machine is turned off and back on and there is no red light, then the machine must be able to attempt to make a copy. If a copy does not come out, then there is problely some worn feed rolls.
If when the machine is turned on and there is a red light then th There can be some bad paper feed cluthes as well.There might be a paper stuck at either fuser assemly or paper feed roller areas.
Provide more description about the visuals on the machine.
Good luck.
Jul 15, 2009 | Xerox WorkCentre 4118 Network Kit...
Xerox wc 4118 scan option
You will not be able to send the scan request if you are not inloco.
Jul 24, 2008 | Xerox WorkCentre 4118 Network Kit - 1 x...
Xerox WorkCentre 4118 Network Kit - 1 x 10/100Base-TX - 100Mbps (0095205226850) Print Server Logo
927 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
