Question about Euro-Pro SV736 Bagless Handheld Cyclonic Vacuum
Cordless vacuum will not charge. New battery and charging cord was tested for power and OK. Red light does not come on when charger attached.
    President:
  • 2,468 Answers
If the charging circuit board is inside the vacuum then troubleshoot the internal charging board, if its on the supply charger line and you for sure have output to the vacuum plug jack from the charger,then you may have an internal wire broken inside the vacuum at,on,or near the batteries from this jack on the vacuum
Posted on May 13, 2010
  • David McCalib May 13, 2010
    The charging board is inside the vacuum so may me beyond my ability to test. Any suggestions for doing that?
  • David McCalib May 18, 2010
    Charging board inside unit with apparent loose resistor. Not capable of repairing this.
My Dyson cordless DC59 won't keep a charge.
If you charged the vacuum overnight and it immediately, or shortly there after, your battery is shot...
Apr 09, 2017 | Dyson Vacuums
I just bought a dyson 35... And put the machine on charge. Now that I want to use it, it is not working. It is either the charger or the vacuum itself. Very disappointed.
Hi Zara, it's Jack at Dyson.
DC35 should charge from depleted within 3.5 hours. When your machine is taking in power, you'll see a green light on the charger assembly. When the machine is fully charged, the green light will shut off. Disconnect the machine from the charger cord before testing it, as your DC35 will never run when the charger cord is attached to the machine.
We're keen to help you check that both the charger assembly and the battery are working as they should be. If not, a replacement part should be covered under your 2-year Dyson parts and labour guarantee. We'd just need to talk you through some simple diagnostic checks when you have your machine to hand to pinpoint the cause of the issue.
You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you, and helping you resolve this issue.
Mar 23, 2015 | Dyson DC35
When I press the trigger the green light comes on but motor does not
Hi Peter, it's Jack at Dyson.
From what you're describing, it does sound as if your DC35 needs to be recharged. When the machine is charging, the LED on the charger will illuminate, but the LED on the machine itself will not. When the LED on the charger goes out, the machine is fully charged - this will take 3.5 hours from depleted.
Please try connecting your DC35 to the charger cord and allowing it at least 3.5 hours to charge until the LED on the charger goes out, then test your machine. If it's still not running at this point, we will need to talk you through some simple diagnostic checks when you have your machine to hand. This will help determine whether there's an issue with the main body, battery or the charger itself.
You can reach our experts by calling the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 09, 2015 | Dyson DC35 Digitial Slim Animal Cordless...
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
My roomba mounts up to the charger the light blinks red then after a time it goes green but when I dismount it and push the green button it immediately goes red. It doesn't beep or do anything. It is that...
You have dead nimh (nickle metal hydride) batteries. You will need a replacement. You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new.
Feb 07, 2010 | iRobot Roomba 560 Robotic Vacuum
New battery. Charged for 24 hours. Light is green, but after 20 seconds light turns red and it stops.
There's a chance that the battery you bought is bad. There's a greater chance that the problem is with the charger. If you're using the dock to charge, try plugging the charger directly into the roomba just to rule that out. If that doesn't fix the problem, I would try borrowing or buying a new charger, and see if that works. If a new charger and new battery don't solve the problem, the problem must be with your roomba itself.
Sep 25, 2009 | Roomba Robotic Floor Bagless Vacuum
My iRobot scooba won't turn on after a full charge
Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
Jul 26, 2009 | iRobot 5800 Scooba Vacuum
Euro-Pro SV736 Bagless Handheld Cyclonic Vacuum Logo
160 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
