Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Sound no picture
I have sound but no picture. After a few days it came back on, but a few months later it happened again. Sound no picture. Please help!! Thank you!
  • wgafford55 Apr 05, 2008
    the tubes are not on and i would like to know were to get a schematic and /or parts list to order replacement parts.
  • Philips Master
  • 8,617 Answers
Sounds like cold solder at the vertical output IC. Try resoldering the vertical output IC and see if that helps.
Posted on Mar 29, 2008
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
My rca tv hd61lpw62 power button blinks five times and wont turn on tv
i have a rca hd61lpw62 makes loud noise and i lose the picture still have sound tv repair man fixed it once and said he had to soilder ballist one month later doing the same thing this time he said it was the color wheel sounds like he is just guesssing you can wait a few moments and it comes back on help please
May 04, 2010 | RCA Televison & Video
Philips 55PW9363 hd tv has sound but no picture. Was working fine before it was turned off and this happen when it was turned on about an hour later.
You may have a bad, small signal board. Once in a while you may get a picture back....if the TV has been unplugged and plugged in after a few days.
Jan 30, 2010 | Philips 55PW9363 55" Rear Projection...
I have a Samsung HLR6168W DLP that intermittently shuts itself down,the sound stops, the picture disappears, the screen goes dark but not completely off. A few moments later the picture returns, but no...
its the problem of inner lamp that is near to end of its life and it needs replacement.and what the thing is happening is the indication of faulty lamp.
how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 11, 2009 | Samsung HL-R6168W 61" HDTV
Hitachi 53uwx10ba turns on & off when off red flashing light/clic
Same problem. Replaced both convergence ICs about 5 months ago. Worked fince since then and just recently no sound, no video, blinking red on front panel and clicking sound. I suspect that the ICs went bad again and blew a resistor or two. I used cheap Chinese ICs instead of the Sanyo ones and thing this is why. I'll be looking at it again and post solution.
Jan 21, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
Probably a 'cold or detatched' solder joint on a component on that perticular circuit board you are 'wedging' with a plastic rod.
Apr 16, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Picture went off still had sound then i turned off at panel now only red timer/standy stays lit sony 61" projection
First plug in again and look at led light, the amount it blinks tells what is wrong. Then if it stays lite it tells something also. You can try Display-channel 5-volume +- Power(service mode). Then Channel 8-enter(test reset). If this doesn't work then you will have to replace somethings like F601, R607, Q601, IC601, R612, VDR601.
Oct 05, 2007 | Sony KP-61V85 61" Rear Projection...
Picture turns off still have sound
I have the exact same problem with my tv. Unfortunately, I'm not sure what is wrong or how to fix it either. I notice your post is from July. Have you found a solution since then? - Sarah
Jul 30, 2007 | RCA HD50LPW175 50" HDTV
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
