Carrier rooftop rv a/c runs intermentally--cools great when runs but stops like it is being overloaded
    Novelist:
    Champion:
  • 246 Answers
Since the AC is not tripping the breaker off - I'm assuming that the compressor is stopping (the fan continues to run correct).
Sounds like it may be stopping because the internal overload (safety) has opened. If this is the case you can prove/disprove it by feeling of the compressor.
If it is kicking off on the overload it (compressor) will be 'hot to the touch.' - and will not come back on until the it (the compressor) has cooled down.
The reason for this is usually because the compressor is breaking down 'electrically,' and there is not much you can do besides replacing the compressor or the entire AC.
However, there is a chance that it's something minor like a capacitor (run or start) that is bad or the refrigerant charge is not correct.
A bad capactior will usually show a 'bulge' (but not always) - in which case if you were mechanically inclined you could (after making sure all voltage is off) remove the bad capictor (be sure you mark the wires) and take it to a Air Conditioning Supply House and buy a new one and re-install it.
As for the refrigerant charge being incorrect - you will need a Service Tech to check this out.
good luck!
Posted on May 14, 2010
Dometic roof top rv ac not cooling
sounds like it is low on freon have someone check with gage and add more if nedded.
Jul 11, 2014 | Dometic Rooftop RV Air Conditioner
Stops running thermostat
thermostat or relay module issue.
May 19, 2013 | Dometic Rooftop RV Air Conditioner
We are in a 5th wheel RV. We have a factory installed Carrier a/c in the kitchen. Lately, it shuts off during the night and we have to reset it in the am in order for it to work. It works fine during...
If the outdoor temps are cooler than inside, AC's are not made for this and will not work well if that is the situation, it floods liquid to the compressor which will overload. will it reset within 20 mins of going off? if so the board/stat are suspect, if not the compressors the villain and its tired and cant handle the other than design condition of 95 F outdoor/80F indoor.
Sep 09, 2011 | Dometic Rooftop RV Air Conditioner
My dometic duo therm brisk air RV a/c unit is not cooling the RV
I had the sam problem, took the thermostat cover off and tightend and refastend the wires, so far so god
Oct 27, 2009 | Dometic Rooftop RV Air Conditioner
Motor still runs after cool air stops coming out
See if helping the fan turn will get it going thrn let it run awhile.. The fan motors rake a set if not used often enough.
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
Fan Runs, AC Doesnt, Blinks 5 times
Need to look around and should have an error code and give more detail of what the problem is. If you post that i can maybe help you more. I need to know......
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Carrier A/C in RV won't run
check your breakers make sure when running unit this is the only thing on the breaker 15 to 20 amp be sure to keep a window cracked as well unit does freeze over so don't have all the way on cold
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 06, 2009 | Dometic Rooftop RV Air Conditioner
PROBLEM WITH DOMETIC RV ROOFTOP AIR conditioner
Check at the compressor terminals between the Red and the terminal for the overload protector to see if you are getting power to the compressor on startup.
Jul 23, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
