Question about HP LaserJet CP1515n Printer
The left hand side of each page prints some streaky dark lines. I've tried to clean it and put it in cleaning mode but nothing works. Help please!
  • 1,110 Answers
Remove the toner cartridge. Turn it over and slide open the gate that covers the drum. Do you see streaks on one end of the little colored cylinder? (drum)
If so then the streaks are coming from the cartridge.
90% or better of the time, especially on HP's the print quality issues are coming from the cartridge.
Good Luck and Thank You for using Fixya.
Posted on May 13, 2010
Our HP 4250N Laser Printer is leaving a black line approx 2 inches off left side of paper. Tried cleaning rollers and putting printer into clean mode. Nothing is working. Any advice? Thank you.
This is caused either by the fuser or the tonercartridge.
The most common cause is the tonercartridge.
You can test this by forcing a paperjam to stop the paper just after the toner but before the fuser.
To force a paper jam print you can print a page from the manual feed tray and as the last third of the page enters the printer opening the door causes it to halt.
If the black line is there before the toner is bonded to the paper by the fuser you should replace the tonercartridge..
Jan 04, 2011 | HP LaserJet 4250n Printer
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
I put a new ink cartrige and printer prints low coulour tone.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark Color JetPrinter 5700 InkJet
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Black streaky lines on printed and copied pages
HI,
I think you should change your printers tonner.
Thanks
Feb 24, 2009 | Ricoh Aficio CL7000 Laser Printer
Only top quarter of page is printed
How can a get the # recalled of a document was fax to.
Sep 02, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Ricoh aficio 1515f printing dark line down left side
If the print can be rubbed off then this suggests the fuser unit is not working correctly. It could be that the thermistor is covered with toner and making the machine think the fuser is hot enough when it's not.
The black line could also be caused by the fuser if one of the pick off fingers is coated with toner or has worn into the Teflon of the roller.
Does the machine show the lines when you print a page from memory - such as a counter or config page? If not, this would suggest the optical path is dirty. Try cleaning the glass and look at the mirrors inside the scanner to see if they are dirty/dusty.
Feb 18, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
Pages printing with streaks.
try making a copy on the glass, does it come out with the streaks or clean?
If clean then look at the strip glass on the copier there is a pen dot or white out that 's giving you the streak. clean.
Jan 24, 2008 | Toshiba e-Studio 232 Black and White...
Hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Nov 01, 2007 | HP LaserJet 2420 Printer
HP LaserJet CP1515n Printer Logo
418 people viewed this question
Seeker5211
Seeker5211
