Question about Sony Cyber-shot DSC-W70 Digital Camera
Error message When the camera is turned on 'access' appears on the screen. shortly after 'turn off and on again' appears and the camera beeps. However, when we do this the same keeps happening
  • 9 more comments
  • Anonymous Oct 30, 2008
  • Anonymous Oct 31, 2008
    I have the same problem
    yup, same thing...
    same here!
  • desertyeti Nov 01, 2008
    same ****
  • Anonymous Nov 02, 2008
    same
  • austinliebst Nov 04, 2008
    I have the same problem.. It's my girlfriends camera and her birthdays coming up soon and I can't think of a better present than fixing that.. If anyone knows how to fix it please Email me or something. Austinliebst@hotmail.com . I would greatly appreciate it!
  • Anonymous Nov 13, 2008
    the camera is a POS. My local sony service centre told me a lot of w40 and w70 cameras come in with the same problem, yet sony will not provide warranty support for this problem. I'm not paying $50 to get a $100 camera fixed.
  • it_takesmeth Nov 18, 2008
    I dropped the camera and when i tried to turn it on, this happened. did anyone else drop it?
  • Anonymous Nov 23, 2008
    i dropped my camera by accident and now it wont turn on, or it will turn on, but automatically turn off in a second!
  • Anonymous Nov 28, 2008
    Access appears on the screen when I turn it on but the lens won't open. It seems to try, but won't work. Then the screen says turn the power off and on again. I do that, but to no avail. Smacking in on a table used to do the trick but it no longer works. My camera is not even two years old.
My camera did the same thing, lens retracts 3 or 4 times, and then proceeded with an error message "turn off and on again". I pressed the power button probably about 10 times, didn't work, so then i gave it a good smack on the top of the frame a few times while repeatedly pressing the power button and it did the trick. Hasn't gave me problems since...hope it helps
Posted on Nov 05, 2008
  • Jason Kahl Oct 28, 2011
    I thought you were kidding...My camera was doing the exact same thing. So, I figured what the heck and gave it a few smacks. Sure enough, it actually worked. Incredible! Just needed an attitude adjustment I guess. Thank you.
AHHH OMG IT FRICKEN WORKED! I SMACKED IT COUPLE TIMES ALL AROUND HAHAHAH. i hope i didnt damage it more. but heyyyy its taking pictures now!!! wooo!!! i soo happy!!! JUS GIVE UM SOME GOOD DIRTY LICKENS AND GIVE UM SOME GOOD SMACKIN!!! HOPE U GUYS HAVE LUCK WITH DAT TOO!!!! AHHH I SO HAPPY I TRIED DOING EVERYTHING I POSSIBLY COULD! AND LOOK WAT HAPPEN! DA FUNNIEST SOLUTION WORKED FOR ME!!!!
GOOD LUCK EVERYONE!
Posted on Dec 05, 2008
Posted on Oct 21, 2008
It put access than after it starts beeping and appears turn the power off and on again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Dec 12, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
Turn the power off and on again message
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
When the camera turns on the screen stays black and the lens will not come out.
Hello, "turn off the power and on again" its a very comman problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: A-1512-913-A LSV-1250A Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
'access' Problem
Hi, I just fixed my daughters camera w/same problem.....I read on another site that you squarely hit it on table while holding in hand....I didn't have to slam it just one slightly firm hit and it works fine now...been broken for weeks and tried resetting and pulling battery to no avail...the hit works! viewing screen side is the side I hit on table, only had to do once, and not that hard.(camera was less than 2yr old dsc-70) good luck!
Oct 21, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Samsung nv3 sd 'card error ! ' message
my camera say card error, can u help?
Apr 04, 2008 | Samsung NV3 Digital Camera
Help
If this error message appears, turn off the camera and remove the batteries for 30 seconds. Afterwards, reinsert the batteries and turn the camera back on. If this doesn't work, perform a manual reset of the camera. If you need an online manual here is a link with troubleshooting http://www.docs.sony.com/release/DSCW40_EN.pdf
Aug 17, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
457 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
