Question about Teac A-H500 Amplifier
Power pack failure - Teac A-H500 Amplifier
  • 185 Answers
Replace the power pack
Posted on May 27, 2010
2005 Mercedes Benz C230 Kompressor - Mileage: 110,000+ Experiencing repeated failures with replacement Ignition Coil Packs - failures have occurred at Cylinders 1, 3 and 4. Cylinder 2 still carries...
Try leaving the dress up cover over the coil packs off. It may be engine heat. Also check alternator voltage is not over 14.6 volt when engine running at fast idle. You are not alone with this problem.
Oct 20, 2013 | Mercedes-Benz C230 Cars & Trucks
Back lights won't come on changed bulbs can't find 5he fuse
we need :
mfg name of monitor (vast)
model name (vaster)
product p/n , like viewsonic, VA22xxxxxx ?
there are no 2 monitors alike, and never will be..
be specific.
my guess you are working an old cold cathode florescent tube LCD monitor. (yes, ive mixed many)
it has 3 parts. (a/c power, fuse, power pack, and the tubes)
check for power to the power pack (highvoltage it is)
120vac in (usa) and hv out for the tubes.
if the power to it is good and the tubes are dead, the pack is Dead.
this is the #1 failure mode for all old LCD.
the pack dies. and costs more than a new or used monitor.
but it is true fleabay sellers do rip them out and sell them used.
but usually dont last long. due to Age.
btw too, a full manual (with schematcs) can had, but usually costs $$$
Oct 03, 2013 | Computers & Internet
Malibu 300 watt Power Pack Timer Directions
Copy following link for step-by-step instructions in form of troubleshoot, plus tips for protecting your product rights, protecting power pack from early failure, replacement trippers, product manual, and 5-year warranty claim requires receipt.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Oct 11, 2012 | Malibu Intermatic Inc. ML300RTW 300-Watt...
D4dmx-md5 stop working. No schematic. Problem came slowly then it stop working. Get a bit of light on the led display Maybe a power supply problem
You did not post enough information on symptoms to get a good answer. However, the most common problem with these dimmer packs is a failure of the sermiconductor that controls the amount of power going out to the attached light. In the D4DMX, there are 4 such, of a type class of semiconductors known as "triac", part industry part BT16A (the "A" is important, as it indicates an internally insulated mounting/heatsink tab). When this part fails, the output channel stops working, but the other 3 channels continue to work. Altho rarer, it is possible for multiple channel triacs to fail. The failure of a triac is typically due to (1) attached bulb filament failure (in a manner where a filament fragment shorts across the mounting posts), (2) channel overload (eg, plugging in a greater load (significantly greater wattage) than the D4DMX channel is rated for), (3) AC power line surge. You need to be a trained & experienced ELECTRONICS (ie, NOT electrician) to accomplish this repair safely & satisfactorily, and it involves soldering & specialized test equipment.
The D4DMX series is also known for failures of its control cable interface circuitry, both for Microplex and DMX. Microplex failures is more common, as that type of interface is more sensitive to induced noise from nearby AC wiring, radio signals, and standing wave reflections from varying lengths of control cabling. DMX uses a differential control signal interface, which makes it much more immune to induced noise, but it operates at a lower signal voltage which makes it more sensitive to accidental application of improper voltages on the control cable...which often happens when someone connects the DMX ports on the dimmer pack to a Microplex connector on another pack or the control console. One clue is to look at the single tiny LED right next to the control cable connectors; if it's lit green, then the Microplex signal is detected, if it's lit red the DMX signal is detected, if it's not lit at all (off) then no signal is detected which just may be an interface circuit failure. Such problems are a bit more challenging to troubleshoot internally, and requires a proper oscilloscope or logic analyzer.
In both of the above cases, you will see what may look normal on the LED display, but the dimmer pack will not function properly.
You should describe more symptoms of your problem, such as: Are all light output channels not working, or just 1 or 2? Which control interface are your using (Microplex or DMX)? What is your LED display saying? What are the present settings programmed into your D4DMX? Are any other working channels responding to the control console normally? What is the total length your control cables, including those between serial connected ("daisy-chained") multiple D4DMX dimmer packs? Do you have any non-D4DMX dimmers in the control chain, and are they all connected using the same type of control interface (Microplex or DMX)?
May 23, 2011 | Leviton D4DMX-MD5 4-Channel Programmable...
What will cause the coil packs not to put out spark
faulty cam sensor, faulty coil pack, or coil power circuit failure. Have this checked by an experienced tech. Hopefully this helps!!
Apr 01, 2010 | 2000 Oldsmobile Intrigue
We have intermittent power failure on one of the dual coil packs
replace the pack. its probably faulty in its own right as there are 2 coils that work very hard in each. always pays to do both packs at the same time.
Sep 06, 2008 | Ford Ranger Cars & Trucks
Power
check the power pack to see if it has the required output voltage, usually 12-15 volts. solidstate power packs are prone to failure. The LCD screens require between 2 and 4 amps to power them. A strain on some power packs. Gary(Honkity Hank)
Sep 18, 2007 | AOC LM929 (Black) 19" LCD Monitor
Open Questions:
Teac A-H500 Amplifier Logo
94 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
