Question about Brother IntelliFAX 2800 Laser Fax
When faxing, pages will not pick up unless "pushed"
  • 1,110 Answers
The ADF or automatic document feed roller(s) are dirty and need to be cleaned. Just open up the panel where the documents go into and look for the feed roller that feeds the documents in. It is a grey or black rubber tire about 1.5 inches wide and will be i the center when looking from left to right. Use a cloth with a little glass cleaner sprayed on the cloth and clean an area of the tire then rotate the tire to clean the rest of it.
Once done your documents should feed fine again.
Very common problem that I see all the time.
Good Luck and Thank You for using Fixya
Posted on May 13, 2010
I get plain paper or double when I received fax from my uf5300 laser fax.it print one page from 5 pages that sent and I got empty pages and double somtimes
Paper feed rollers and sheet feed pad dirty. Feed roller on top pad should be just below. Clean with alcohol. Papers have clay in them. Recycled is worst. It will glaze the pick up roller and pad.
Sep 21, 2014 | Panasonic PanaFax UF-8000 Laser Fax
FO-3150-won't auto answer, have to pick up receiver to get faxes
renield, that worked perfect!!! Thanks a million!
Feb 06, 2013 | Sharp Fo-3150
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
Mar 21, 2011 | Office Equipment & Supplies
Wrong in receive fax (only one page coming)
Contact the sender and tell them to press STOP when their machine starts to dial.
Jun 28, 2009 | Panasonic KX-FM131 Fax
Canon Faxphone L75 Multiple Paper Fax Problem
There appears to be a problem with the paper separator. This is normally a small piece of plastic topped with a piece of cork and pushed against the paper with a small spring. Either the cork has become smooth from picking up tiny paper fragments and can be remedied by filing a small portion of the cork off (or replacing it). Or the spring may be weakening and may need to be replaced.
May 17, 2009 | Dell OptiPlex GX270 PC Desktop
Fax does not work, and I don't have the booklet for troubleshooting
Cannot receive a fax unless someone is there to push the button to reveive. How can I set up to receive automatically?
Jun 10, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Faulty fax machine
You can try cleaning that roller with a rag and some rubbing alcohol. Scrub it really good all the way around and that should help.
Aug 02, 2007 | Panasonic KX-FHD351 Plain Paper Thermal...
Document feed doesn't
drive gear is wore down on bearing surface good luck finding one
Apr 11, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
88 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
