Question about Carrier 38CKC036 Air Conditioner
I have a Carrier 38CKC036 Air Conditioner Unit. When I turn the thermostat on cool the compressor comes on but the fan on th unit clicks like it wants to come on but it dont. Could the fan be bad? What do you think the problem is?
  • 82 Answers
Hello, this is one of 2 items...the motor itself, or the start capacitor. The capacitor is responsible for boosting the motor to get it started. Follow the wires from the motor and they will lead to an oval or round cylinder. Check the cylinder for any bulging or leaking oil. When the motor should be running, reach in with a stick or ruler and try to assist the fan to get going. If the it feels resistant...it is most likely bd motor. If it trys to start and feels smooth it is most likely capacitor.
Posted on May 13, 2010
Testimonial: "It was the capacitor."
Carrier 38CKC036 compressor will not cycle after initial run.
Does it have a low pressure switch. It sounds like it is a pressure switch issue
May 16, 2014 | Carrier 38CKC036 Air Conditioner
Which capacittor to use with this unit? Carrier 38CKC036 Air Conditioner
depending on compressor it would be 40uf to 45uf 370v; 5uf/370 for the outdoor fan motor
Aug 01, 2011 | Carrier 38CKC036 Air Conditioner
Carrier 38CKC036350 condensor fan not spinning makes humming noise compressor hot fan can be turned by hand
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | Carrier 38CKC036 Air Conditioner
Carrier air conditioner isn't cooling the house. It is blowing air, but it doesn't seem to be cool air.
Check the outdoor unit to see if it is discharging hot air out of the top ofd the unit, check the insulated suction line to make sure it is cold or sweating. Try to listen to the outdoor fan and the compressor to make sure they are both operating
Jun 24, 2010 | Carrier 38CKC036 Air Conditioner
Neither A/C compressor or fan coming on in ouside unit.
The bulge is a telltale sign of a defective capacitor along with the tripped breaker. Replace it and cross your fingers.
Jun 21, 2010 | Carrier 38CKC036 Air Conditioner
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
Carrier central ac model 38EN036300
If you have an electronic thermostat, they can short out, leaving the compressor running. Also, the big relay that runs the compressor can get its contacts welded together. See if the contacts are stuck closed.
Jul 27, 2008 | Carrier 38CKC036 Air Conditioner
Carrier 38CKC030348 air conditioner
If the capacitor is bad replacing it is just a mater of moving the wires from the old one to the new one and mount the new capacitor securely in place. In replacing a capacitor it is recommended to replace it with the same rating as the one removed.
If the capacitor is bad it will not prevent the compressor from getting power. Is the compressor trying to start at all. If the compressor is running and you have no cooling the system could have lost the charge of refrigerant.
Jul 02, 2008 | Carrier 38CKC036 Air Conditioner
Air conditioning unit not cooling
the problem sounds like a defective capacitor its located on the condensing unit outside, also a contactor that is used can be defective also.
Jun 05, 2008 | Carrier 38CKC036 Air Conditioner
Carrier 38CKC036 Air Conditioner Logo
440 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
