Question about Saeco Vienna De Luxe Espresso Machine
I'm attempting to replace the grinder on my Saeco Vienna Espresso machine and have gotten down to the ring of ball bearings and I don't know how to remove that race to remove the motor from the plastic porftion. Please help, I really need a repair manual but apparently their not available.
  • 1,089 Answers
Hi
If you have gotten to the ballbearings you have gone to far. The motor includes the gear reduction portion, which is what you are working on. If you just bought the motor, you are out of luck on replacing it. It is better to buy the whole grinder than just replacing the motor. You get new burrs with the new grinder. They are already correctly adjusted.
Posted on May 14, 2010
I received a new lower burr grinder part from SAECO for my machine but no instructions on how to replace it. I know how to clean and replace the removable grinder part that fits into this. Do you have...
Hi
If you only got the lower burr it won't work. They should be matching burrs.
If you don't do it right, you will damage the grinder. You need a #10 Torex bit.
Insert the bit into the screw in the middle of a very clean grinder. Turn clockwise to loosen. Once the screw is out, pull the burr out, but be careful. There are ball bearings and springs under the burr. Make sure that everything is clean before reassembly. There are 3 holes in the bottom of the grinder. The springs go into the holes first. Then the ball bearings set on top of the springs. Place the new lower burr on top of the springs. A washer and the corkscrew go in next. Insert the screw in and with the bit in place turn (with a little down force) clockwise until the screw drops into place, then turn counterclockwise. It should turn fairly easy. Once you start putting pressure on the springs, try to turn the corkscrew. There is a notch that it slips into in the bottom of the grinder. Once it locks into place keep turning the screw until you start to turn the burr. That should be tight enough. Now reassemble the top burr and adjust.
May 12, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
May 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Long time for drip coffee.
Grinder is set to too fine. Lower grinder settings. Keeping the machine at current settings with drip extraction will result in brew group clogging, gear stripping, and/or dulling of grinder burrs.
Jan 30, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco De Luxe Coarse Grind
You could have knocked it out of its shaft or worse, Cracked the shaft itself.
Settings could be off too, It fairly common. Recheck the chamber, and make sure the plastic casing isn't cracked and the grinder doesn't wabble at all. It should be fairly firm.
If it isn't firm, bad news, cracked shaft.
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Clogged Saeco Vienna de Luxe
Grinder sound like it is grinding to fine. Increase the grinder size. Remember to only change grinder setting when the grinder is spinning.
Hope this helps!
Sep 11, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
360 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
