Question about Sharp 14U-FM1 14" TV
Sharp 14 the zener in the power suplie is short .it is written as A I 5 is it 15v or 5.1 zener
  • 1 more comment
  • kanags Mar 30, 2008
    i not sure it is .there is yet another problem it seems.no out put though TEA 2261 and the powr D1886 were replaced in the SMPS.i yet to check the SMPS tranformer .thanks for help.(the model 14C-N5 sharp 14 inch TV.can any one supply circiut diagram and pin voltage for 2261,SMPS transforrmer
  • kanags Apr 21, 2008
    there was a 100E resistor which was faulty that showed as high as 15 meg. on replacing the fault was corrected.of course with that zener 15v.but the set went dead again 2-3 minutes.on switching off and again switching again the set is on for again 1-2 min and this repeats again .what is the wrong
  • Anonymous May 07, 2008
    "TV NOT ON
  • 372 Answers
15 volt.
Posted on Mar 30, 2008
    Sniper:
  • 56 Answers
It is 15 v zeaner. check supply voltage fluction at out put pin without connecting d1886. smps trf never get faulty
Posted on Jun 16, 2009
  • saravana kumar
    saravana kumar Mar 15, 2016
    Dear sir...my Sharp crt tv d1886 is short ,then I change it...but it's not turn on..I checked the all resistor and caps on smps side,and I change tea2261 and all electrolyte caps,..then switch on....now same d1886 is short ...wts that problem...how can I rectify short......
In panasonic modeltc-29sf3 pls give me the working voltage of zener diode with color code gray red red and red yellow in power supplyn section
just read the model and then google it, beside, if you short them, you need to replace them with same value, and this will be determined by the circuit, if you did not change the circuit - just buy two new diodes and install them, do not bother with voltages as they have some tolerance and type will determine it.
Jan 27, 2015 | Panasonic Televison & Video
Mitsubishi wd-62628 flashing error code 41 (short) now what?
Short detected in standby power supplies. on pwr PCB check the following:
1)12VS @ connector PD pin 14: possible cause;IC9A23 circuit
Zener D9A41
2)5V @ connector PC pin 8: possible cause;IC9A21 circuit
Q9A12 circuit
zener D9A47
3)4.5V @connector PD pin 16 possible cause: F9E10
F9E11
Dec 28, 2014 | Mitsubishi Televison & Video
Panasonic TV CT-32SX12F won't turn on with switch or remote
i think your power suply is defect.
check fuse , then rectifier, then transistor hf switch.
short circuit i think on the primair side off the sops power suply.
Oct 19, 2014 | Televison & Video
MCS 160 Boston Subwoofer ZD3 Zener Diode Value
ZD3 is a 18v zener. Also check the surface mount resistor on the back of the board that is attached to ZD3, I think it is R9. Should be 10 ohms. This resistor sometimes opens when the diode goes short.
Jul 13, 2013 | Audio Players & Recorders
Polaroid 860-AZ0-GF371H Power Supply Unit. After replaceing all bad caps and and shorted fets Q102,103 I still need to know the value of smd zener ZK2 in Parallel with 3 low value smd resistors. I think...
HZK Series
Silicon Epitaxial Planar Zener Diodes for
Stabilized Power Supply
open the following link and it help you it has all the detail about the mentioned diode
Aug 26, 2011 | Polaroid FLM-3232 Television
Bagian regulator short,kalo power dihidupkan mcb langsung short
hallo anton,
1. Cek dioda bridge di kaki input ac ( tanda ~ ) short ga? klo short ganti .
2. Cek capasitor yg gede di bagian power suplay, short apa ga?. short ganti.
3. Cek IC ato str , pecah ,short atau masih bagus? klo short gnti.
4. Setelah di pastikan semua yg short dah di ganti, cek juga dioda2 zener nya , klo masih ada yg short ganti.
Jika ada pertanyaan, komen aja. jangan lupa jempolnya ya. hehehe.
semoga berhasil .
Mar 25, 2011 | Televison & Video
Tv wont turn on
try to plug in again...if there's no reaction at all, then the power suply section may checked...(I.C. regulator str.... followed the horizontal output transistor or some of the zener diodes regulator or broken PCB line
Jul 30, 2009 | Sony KV-27S42 27" TV
Tv working fine, then suddenly,pop and black screen, sound is ok
The issue here is that the zeners in question are merely like a safety fuse and replacing them before identifying and fixing the cause of the problem will only cause your replacement zeners to blow aswell.... personally if it is a true plasma it likely chews through alot of power anyway so I would take the opertunity to replace the TV with a newer much less power hungry led TV and in doing so save the hip pocket and the environment.
Aug 25, 2017 | Philips Magnavox 27MS343S 27" TV
Sony 52inch projection nothing happens,timer light blinks all the
check powr suply for a sony wite ceramic fuse 0.01 ohm
if open rebuild or replace power suply befor turning on the unit check the H.O.T high v transistor if shorted replace and also replace vdr610 602 and 603, depending on set flyback should be changed also due to a know internal arking problem with sony fly backs.
25% of the time its just the power suply that goes bad.
Jan 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Tv does not power up
I have seen the schematic, d982 is a 13v 1/2w zener
-GR
Jun 28, 2006 | Mitsubishi CS-35503 TV
Sharp 14U-FM1 14" TV Logo
168 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
