Question about HP Office Equipment & Supplies
Just installed (via internet) an old printer: HP Color LaserJet 2500n on a new computer. It works fine with the exception that it does NOT PRINT IN COLOR.
  • blaise_ann May 14, 2010
    Very Helpful
  • 1,110 Answers
If you can not select color on the driver screen then you may have downloaded the wrong driver. For example if you are using Windows XP and you downloaded the PCL6 driver then that driver only prints in black and white. The PCL5c driver prints in color. So just go to your printer in windows and pull up the properties. Look at the Advanced tab and it should display the driver. Make sure it is not PCL6. If it is then delete the printer entirely and dowload the 5c driver and re-install.
Make sure when you are printing you have selected "print in color" on the setup screen not grayscale or black and white.
Lets start here and let me know if this does not resolve your issue.
Good Luck and Thank You for using Fixya.
Posted on May 13, 2010
    ahhh,, everything is good. However, still wont print in color. Am using Windows 7, downloaded the driver via automatic. Still cant get color. I also try to get the hp toolkit and cant
    yea, I fixed it!! I used the driver "HP 2500C Series Printer" and the port USB0001. The automatic setup was "HP Color LaserJet 250 PCL 5" on o LPT port.
    I still need help on how to locate the HP toolbox software.
    Thanks
My dad just got an HP computer with windows 7 and 64 bit. His HP Color LaserJet 2605dn is working except in Photoshop CS 4. It says he needs to install a printer. Any ideas?
If the printer is working fine for all applications except Photoshop, it isn't a printer problem. Does that version of Photoshop support 64 bit processing?
In any event you should call Adobe and run it by them.
Jan 23, 2011 | HP LaserJet 2605DTN Color Printer
Do the reset chips really work on the cartridges of HP 2500N laserjet printer
Yes, reset chips really work on laser printer cartridges, if you have a know good source for the chips and if you know what your doing, you can't put a new chip on an old cartridge, the chip is what registeres how may prints you will get out of the cartridge if you put a new chip on an old or 1/2 empty cartridge of course it will say it's full but then try and print.It will register as a full cartridge but it can only print with the amount of toner that is actually left in the cartridge, be careful there are alot of remanufactures out there that don't put new chips on or that do but don't fill the cartridge full, or replace all the wipers and drums, they just dump some toner in and say here you go, Only buy your remanufactured cartridges from a reputable company, do your research on them first or you'll be sorry
Aug 14, 2010 | HP LaserJet 2500N Printer
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
How do i clean the print heads on my HP Laserjet 2500 on my Mac 10.5?
There should be a print utility tab when you bring up your printer to print a document. Click on it and then there should be a nozzle check option.
Dec 31, 2009 | HP LaserJet 2500N Printer
When i send a file to print from my mac (OSX 10.4.11) i get the error message in the printer box ''Printer not responding''I am using the HP 2500 Color LaserJet printer. It was working fine and just...
Connect the computer via fire wire to another working one.. and remove the two sleep files. Start your MBP holding down the T key The issue is a corrupt sleep file. once deleted your computer will work perfectly
Nov 11, 2009 | HP Color LaserJet 2500L Laser Printer, up...
Strange Printer Issue - HP Laserjet 2600n
The last time I checked, you cannot set up a local printer using a TCP/IP port. A local printer is physically connected to a computer via a parallel, serial (very old), or USB cable. If the printer is connected to a switch, hub, or router via an Ethernet cable, it is by definition a network printer and the driver install must reflect this. I don't understand why it is able to print out the test page after the install. If you open up Control Panel -> Printers and double-click on the HP Laserjet 2600n in there, it will bring up the local spooler for the printer. You may have a bunch of print jobs queued up in there that it cannot currently send to the printer. You may want to clear the queue first (cancel all print jobs). Let me know if you have problems clearing the queue & I can give you instructions on how to do that one too.
Apr 23, 2009 | HP Color LaserJet 2600n Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Print Problem in 2600n and Laserjet 1000
Just install 2600n manually and define as USB Virtual printer port!!!
Jan 24, 2008 | HP Color LaserJet 2600n Printer
Seeker5211
Seeker5211
