Question about RIM BlackBerry Bold 9000 Smartphone
I have to press the ball a couple of times before It will open the comand
  • 343 Answers
Open and clean the phone its like a pc mouse if its not clean dont work properly
Posted on May 14, 2010
How to clear Antitheft program activated message on the screen at ml350
There is an "Anti-theft protection active" message on my COMAND screen
When a COMAND unit is installed into a vehicle (whether during production or as a replacement) it is equipped with a PIN. This PIN will be associated to the VIN and relies on the communication network within the vehicle for validation. The network check from COMAND is performed at startup and if the internal vehicle network is not detected, "Anti-Theft protection active" will be displayed.
It is important to note that this message is NOT related to the vehicle's Anti-Theft alarm.
Either of the below procedures will temporarily remove the message and allow you to resume operation of the COMAND unit.
Please note that these are temporary solutions. We recommend visiting an authorized Mercedes-Benz dealership to have this situation permanently resolved.
· Press and hold down the COMAND power button for about ten seconds
Or
· Restart your vehicle
how to clear Antitheft program activated message on the screen on mercedes...
http://mercedes-benz.custhelp.com/app/answers/detail/a_id/76/~/there-is-an-anti-theft-protection-active-message-on-my-comand-screen
Dec 24, 2017 | Mercedes-Benz Cars & Trucks
The seals on my dyson ball have broken loose in a couple of spots and prevents the ball from rolling freely
How old is your Dyson?
I suggest you contact Dyson Support directly to see what they can do for you. Make sure to have your model number and Serial number handy when you contact them.
Here's the link to their main page; once there, click on "Support" Dyson vacuum cleaners fans heaters accessories spares official site
Jun 17, 2016 | Dyson Cinetic Big Ball Animal Bagless...
Car has high idle when EGR Comanded open. iS AN ethrottle system. E throttle is comanded open 15% at same time. Happens randomly.
The EGR will open when you are cruising over 40 m.p.h., the vehicle is at full operating temperature, and you are not accelerating. The EGR should close when vacuum condition is low (as when you are accelerating), or when your speed falls below the preset (usually around 40 m.p.h.).
If your EGR and E-throttle are open at the same time, suspect a bad EGR position sensor, a bad EGR mounting gasket, or a sticky EGR valve.
May 20, 2015 | Toyota Opa Cars & Trucks
HOW DO I REMOVE THE LOWER BALLJOINT
if it is the lower ball joint it presses out the bottom. rent a ball joint press from local parts store (refundable when tool is returned) and it is simple if you have an impact or electric impact ($75). put the press stud on the ball joint stud and ring underneath. If you never have used one, they will explain how while you are there.
Sep 23, 2014 | 1990 Ford F150
The ball won't press down anymore.
take a cotton stick and dip it in petrol and then clean ur mouse with that cotton stick hope it would work . . .well mine did !!!
Mar 23, 2010 | RIM BlackBerry Pearl 8100
Replacing ball joint on 1997 pontiac grand prix
make sure you get the tool to help you its real easy take the nuts off and take the fork and hammer
hit the fork a couple of times it will sperted and then press the ball joints out and press back in
Jan 27, 2010 | 1997 Pontiac Grand Prix
Front end bushing and ball joint do you need to change upper and lower bushings at same time and how hard is to them
It's not required to change the upper and the lower at the same time. However it will save you time if you do them both as if one is going out the other will soon.
The actual job is not that difficult but you may need a pickle fork or a ball joint removal tool to disconnect the ball joints from the steering knuckle. You will also need a ball joint press to remove/install the ball joints. You may also need a strut spring compressor. You can rent these at an auto parts store.
Basically you have to do the following -loosen lug nuts -jack the vehicle up and place on jack stands -remove wheel -remove upper ball joint cotter pin and nut -remove lower ball joint cotter pin and nut -with pickle fork/ball joint removal tool remove both upper and lower ball joints from steering knuckle -disconnect tie rod end from knuckle (optional depending on clearance) -disconnect strut (be sure to install strut spring compressors) -with ball joint press you will need to press both ball joints out (you also use the press to install ball joints)
Installation is reverse of removal.
For exact instructions you can buy the manual for about $20 or go to autozone.com, register, and view the manual on their site for free.
Jan 26, 2010 | 1999 Chevrolet S-10 Pickup
I need step by step instructions on replacing front lower ball joints on a 1996 GMC JIMMY4X4.
first you will need to buy a ball joint press. first jackup and place jack stand under oneside of jimmy1).remove the tire.2)remove caliper and pads and rotor.3) remove cotter pin out of nut for tie rod end then remove nut. 4) loosen tie rod end from knuckle donot split greese boot or hit top of stud as this will damage it.5)remove axle nut and push back axle may be frozen in hub.6) remove both cotter pin and nuts on ball joints then spin on bottom nut a couple threads as no thave knuckle fall to the ground.7)loosen ball joint from knuckle and remove knuckle.8) remove ball joints with press or by rmoving rivits install in reverse procedure
Sep 06, 2009 | GMC Jimmy Cars & Trucks
Voice comand
Try pushing the button on the headset 1 time to see what happens. We are using Motorola Razors and it works very well after you push the button once but have your phone open to see what you activate after pushing the button.
Jul 28, 2008 | Motorola Mobility H700 Wireless Headset
Front upper ball joint replacement
The dealer's answer (if you are interested).......
The ball joint is pressed into the upper control arm and has a tapered stud for attachment to the steering knuckle. The ball joint stud is attached and locked into the steering knuckle using a special nut. The ball joint is a sealed-for-life type and requires no maintenance. If the ball joint is defective it will require replacement of the entire upper control arm.
Sorry.
Jun 19, 2008 | 2002 Chrysler Sebring
RIM BlackBerry Bold 9000 Smartphone Logo
56 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
