Question about Toshiba 1GB USB 2.0 High-Speed Flash Drive 1 GB USB Portable (PA1399U1MEMFT) Drive
Have a new Toshiba 16GB USB Flash Drive (Transmemory) put into USB port and will not work from there. Computer is not recognizing it...
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: usb flash pen drive
Often it is due to electrostatic charges on usb. Unplug all USBs.Unplug PC from power cable for 10/15/ minutes. plug back computer to power outlet and restart. Plug back usb.
If it still does not work , flash memory may be faulty, test it on a different computer.
Posted on Mar 17, 2008
MalKontent68
  • 748 Answers
SOURCE: I have toshiba USB 2.0 flash drive USB-4GTR. I
I would open the drive via My Computer, and copy the files to a folder of your choice (like My Documents -> My Music for example), and then attempt to point WMPlayer to this folder.
Posted on Nov 14, 2009
Geekman
  • 32281 Answers
SOURCE: I have a Toshiba USB Flash Memory (16GB) which
Your USB flash drive maybe faulty or it needs formatting.
Click on this link for details for my details on how to format the USB flask drive :-
http://www.fixya.com/support/r3598107-faulty_usb_flash_drives
Posted on Dec 13, 2009
  • 18 Answers
SOURCE: I have several pictures on my computer on Kodak
Just plug the flash drive in and let your computer recognize it and offer to open the flash drive file up to view. Once it is loaded up then you can simply drag and drop into it. If this is the first time using the flash drive it may need to load some software. When a flash drive is being used a small icon should appear on the lower right.
Posted on Sep 14, 2009
Toshiba 16gb flash drive is recognized by the computer but not by my printer
Are you sure that your printer is able to use such high capacity memory flash drives? You did not mention printer board and type.
a. Use FAT32 format and retry.
b. Use a smaller capacity flash drive.
Dec 14, 2016 | Toshiba Electronics - Others
Usb storage size went down from 8gb to 4mb
First, download this Toshiba flash drive format tool
http://softadvice.informer.com/Toshiba_Usb_Flash_Drive_Format_Tool.html
and use to format your pen drive again with this software.
Nov 06, 2013 | Computers & Internet
New SanDisk 16GB Cruzer not being recognized by computer
Check ur usb port with other devices.It they were not working properly,
ur usb port is damaged,then put ur device to another usb port.if is not working properly then,ur device is damaged,u can do nothing.
Jun 16, 2012 | SanDisk Cruzer Sdcz36-016g-b35 16 Gb Flash...
Flash player doesnt work
Flash Player the software from Adobe (Adobe Flash Player)? or are you talking about when you stick a Flash Drive (Jump Drive) in the USB Port the system does not recognize it?
Apr 06, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
One of two USB drives wont recognize anything
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Dec 13, 2009 | Toshiba Satellite A205-S5804 PC Notebook
Computer with windows 98 does not have a driver
Windows 98 does requires an USB driver for any/all USB devices to work. The flash memory stick should have a driver in CD otherwise you need to download a Windows 98 driver from Toshibe WEB site. Acer may also have USB driver on their support download WEB site.
Sep 16, 2009 | Acer Computers & Internet
My usb flashdrive is not recognized on any of my usb ports on my Toshiba satellite m35x-s163, can you help?
Test usb port with another device,
check in my computer for the drive,
Test usb flash in another Pc,
Manufacturers website for a possible driver.
if still not working then it's faulty,
Regards
Rpf
Apr 14, 2009 | Toshiba Satellite M35X-S163 Notebook
Can't open my sandisk cruzer 16gb
Dont worry about being prompted, that is an OS option and you may of turned off by accident. When you insert the flash drive into your USB port, does th elight on the drive ligh up? If not your flash drive may of gone bad.
If it does light up, click on "My Computer" and see if it shows up there.
Apr 03, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Toshiba drivers
You can go to the best drivers site and find your requirement
http://downloaddriver.com
http://driversguide.com
Only you have to register on it by simply procedure its free
Regards
Balisonu79
Feb 14, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Computers & Internet Logo
2,373 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
