Question about Nintendo Wii Console
My wii won't turn on
My wii will not even turn on when everything is plugged in. what should i do?
    President:
  • 1,382 Answers
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that dosent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not syncronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work.
Posted on May 14, 2010
Wii power light is flashing red
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
Dec 29, 2012 | Nintendo Wii Console
Tip
Everything is plugged in but your Wii won't turn on
Okay so you have everything plugged in, but all of a sudden your Wii won't turn on, right? Maybe there was a power outage or your circuit breaker was flipped, or maybe nothing happened, but the fact remains that it won't work and you don't know why.
There is a decent chance that your Wii's power cable needs to be reset.
To reset the power cable you need to:
1) Unplug the power cable from the Wii and the wall.
2) Let it sit and rest for 10-15 minutes.
3) Plug everything back in.
4) Turn on your Wii.
It should work at this point if that is the problem.
It may sound silly but Nintendo built in the reset mechanism due to power cable failures and it often is the resolution to a Wii not turning on.
on Dec 22, 2009 | Nintendo Wii Console
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
We are having alot of rain in Tennessee from the hurricanes and the power has been on and off a few times. Right now its on. My Wii won't turn on, even if I unplug everything. I really don't wanna...
Wiis seem to have a problem with power surges. I would start by trying to find a replacement power adapter.
http://www.google.com/products/catalog?q=wii+power+adapter&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&tbm=shop&cid=1392311665554088143&sa=X&ei=D2RmTr2ODsTosQL3mvDQCg&ved=0CFEQ8wIwAQ
Hopefully that will fix your issue.
Sep 06, 2011 | Video Game Consoles & Games
The console is not turning on.We checked all plugs and everything appears to be working but the wii console is not even showing a light that it is plugged in.
You can unplug the AC adaptor on both ends for two minutes.
Check if your adapter is a license product of nintendo WII if its not, you can purchase one on nintendo online store
May 28, 2010 | Nintendo Wii Console
My wii console will not turn on at all, the blue light will not come on. I have checked all plugs and cables and everything is connected. We have only had this wii console not even a year yet. what could...
it could be the power suppy mine went wrong after about 18 months, try ebay there the cheapest. you can test if its the power supply if you know someone with a wii and use there power supply or know how to use a multi meter and check if you have a voltage coming out of the wii plug end. if you dont first try replacing the fuse in the wall plug. hope this helps.
Nov 11, 2009 | Nintendo Wii Console
My wii will not turn on
try syncing the wii and the remotes. there is a small red button on the wii covered by a small door. and as for the wii remote, there is a small red button where the batteries are located. hold them down for at least 10 seconds i would say and then try turning it on. good luck.
Aug 27, 2009 | Nintendo Wii Console
Power Outage & Now Wii Won't Power Up...
When this same thing happened to me, I unplugged the Wii power supply from the wall (not just from the back of the Wii) and let it sit unplugged for about 10 minutes. When I plugged it back in, everything was fine.
Nov 11, 2008 | Nintendo Wii Console
Green light stays on, black screen, no sound, no connection w/ remotes
Go to the tv settings and check to see if you blocked any incoming devises. If you did block the devides, your tv will not read the wii
Jun 11, 2008 | Nintendo Wii Console
Wii Console tun off
Turn it off at the mains, wait 10 seconds then plug back in.
If it keeps happenning you might have a scratched Wii Play disc, or your machine may be faulty.
Jan 09, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
116 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
