Question about LG LDF6920ST Stainless Steel 24 in. Built-in Dishwasher
My dishwasher, which is about 6 mos old, will not go on. When I press the buttons on it, no lights light up. it is an LDF6920ST
  • 10,515 Answers
Disconnect the Power Supply for Few Minutes, say 30 minutes and the Turn it ON. If the Problem Persists, it could be a Fuse, Control Board or some other Internal Fault.
The reason i am not typing any of the Diagnosis, as the machine is ONLY 6 Months Old. So, Probably it is under Warranty. So, it is always advisable to give Manufacturer a call as it is under Warranty.
If you still wanted to repair, Revert and i would be able to Guide.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 13, 2010
Want to start washer but all panel lights are off.when press normal wash still no lights. only 10 mos old. fully loaded .
Sylvia,RE POST with your make and model# and full question, and I am sure we can help.
show your appreciation by pressing the helpful button and follow me on fixya for more tips and info.
Feb 14, 2016 | Dishwashers
LG dishwasher LDF6920ST - Power button lights up but the cycle buttons stopped working so the unit wont turn on to wash. The Power Scrub cycle button seems to be pressed down farther than the other...
Hi Mark.
Modern LG appliances retain settings even after you disconnect the power cord. The machine is reset opening the door and then pressing and holding the Normal and Delicate buttons at the same time for 3 seconds.
You can also try running the test mode shown at page 12 of the service manual.
If the machine is non responding and there is no code on display, then the problem is likely control module or control pad. Since the control pad looks defective, that is probably the part to replace.
Disassembling is shown in exploded view and service manual available using the links below:
Parts and diagrams are available here.
A copy of the service manual covering several LD models has been uploaded here.
Regards.
Ginko
Dec 01, 2011 | LG LDF6920 24 in. Built-in Dishwasher
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
How do i get my dishwasher to work when the power lights and reset buttons don't work?
there is a power issue. 1. check to make sure 110 is going to unit .use a meter at the terminal box.
2. if you have the correct volts thenthe problemis with machine. check on and off switch,door latch,and module. sounds like an electrical problem.let me know if this info was helpful.
Feb 25, 2010 | LG LDF6920ST Stainless Steel 24 in....
Kenmore Ultra Wash Dishwasher - no lights, won't reset
check wire nuts that were used to install power cord/it is on the right hand side of toe kick if ok there is a fuse on the control that you can replace located top of door
Sep 26, 2009 | LG LDF6920ST Stainless Steel 24 in....
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
LG LDF6920ST Dishwasher won't start
With nothing displaying and only the humming sound, it appears that the main controller card (PCB) has most likely failed.
If it were my dishwasher, I would add a pitcher of water (more than two big glasses full), close the door and start a cycle and listen at the drain. The first thing a dishwasher does is run the pump to empty any standing water before it fills up. If you hear that water drain, (and can see that is has drained from inside the dishwasher) it is not as broken as I think it is.
BUT, this dishwasher should be displaying something from the moment you press the power button.
Please post back with what you find and decide you do. OK?
Apr 17, 2009 | LG LDF6920ST Stainless Steel 24 in....
Clean light flashing Quiet Partner V
do the heated dry and hi temp and then hitr cancel. you know what this means?! you have a bad heating element usually. call for service this should be a covered repair if it is only 6 months old
Mar 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Red Light
Are you pressing and holding the button and does the system still power on and off alright? If the system still works properly then it isnt a huge concern. If it wont power on or off then do an exchange at Wal-Mart.
Mar 29, 2008 | Sony PlayStation 2 (PS2) Console
LG LDF6920ST Stainless Steel 24 in. Built-in Dishwasher Logo
71 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
